Icon expansion pack gave me 5"
Discussion in 'Suspension' started by wexttxco, Nov 2, 2021.
  1. Nov 2, 2021 at 12:17 PM
    timsp8
    NY
    Yeah that doesn’t look right. Did you install it or have a shop do it? Have you tried to call icon? I’ve called them before and they were helpful.
  2. Nov 2, 2021 at 12:44 PM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    If you're worried it's the shocks holding up the rear then unbolt the bottom eyelets and let truck just sit on the springs. Should be a simple 10 min experiment.
    JLS in WA and wexttxco[OP] like this.
  3. Nov 2, 2021 at 12:50 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Are your rear shackles torqued so tight that they cannot cycle? Did you torque them with the truck in the air?
  4. Nov 2, 2021 at 12:50 PM
    wexttxco
    wexttxco [OP] New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Thanks yall. Waiting to hear back from icon. Emailed pictures just now. 26.625 and 27.25 are my hub to fender measurements.
  5. Nov 2, 2021 at 12:51 PM
    wexttxco
    21 SR5 DC 4x4
    Are they supposed to cycle? I torqued them to 77lbs, on the ground. Upper and lower shackle bolt, plus bolt on other end of leaf spring.
  6. Nov 2, 2021 at 12:52 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Hmm that sounds right. They move slightly as the spring compresses
  7. Nov 2, 2021 at 1:08 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Face down ass up, that’s the way I like it.
  8. Nov 2, 2021 at 1:22 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Did you take both leaf springs off at the same time and happen to switch them when reinstalling? The driver side leaf spring compensates for driver and gas tank weight. If they were switched (driver on passenger side, while passenger is on driver side) then it could explain the difference.
    wexttxco[OP] likes this.
  9. Nov 2, 2021 at 1:26 PM
    wexttxco
    21 SR5 DC 4x4
    Great idea but I did them one at a time so that I'd have a reference in case I screwed up. Are the factory springs symmetrical?
  10. Nov 2, 2021 at 1:27 PM
    wexttxco
    21 SR5 DC 4x4
    It's not an awful stance but I don't want to ruin shocks or springs
  11. Nov 2, 2021 at 2:06 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Half of the people that install those get a tiny bit to no lift. Something is up
  12. Nov 2, 2021 at 2:42 PM
    wexttxco
    21 SR5 DC 4x4
    Hmm.
    Maybe 2021 changed something?
  13. Nov 2, 2021 at 3:33 PM
    timsp8
    NY
    It’s the same underneath since 07.
    GODZILLA likes this.
  14. Nov 2, 2021 at 3:36 PM
    wexttxco
    21 SR5 DC 4x4
  15. Nov 2, 2021 at 3:37 PM
    wexttxco
    21 SR5 DC 4x4
    Looks normal to me
  16. Nov 2, 2021 at 3:55 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It gave you a ton of arch. It does look normal. I’ll bet it settles a lot over time
  17. Nov 2, 2021 at 4:33 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Maybe take it over some curbs or large rocks (at low speed) to get each pack to fully cycle. This is really weird and seems to point to the wrong pack from Icon.
  18. Nov 3, 2021 at 11:49 AM
    wexttxco
    21 SR5 DC 4x4
    Icon says the overload is upside down. Sure looks flat to me.
  19. Nov 3, 2021 at 11:54 AM
    #49
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It does look like there’s a slight curve to the overload in your pic. Here’s what mine look like, much closer to the other leafs:
    F0491856-280C-4945-A537-E7192C7FEEBB.jpg B7295C31-BF01-456A-B663-306A63D83F92.jpg
  20. Nov 3, 2021 at 12:02 PM
    #50
    wexttxco
    21 SR5 DC 4x4
    We might just have a winner then!
    Thanks for taking those pictures, that convinced me.
  21. Nov 3, 2021 at 12:19 PM
    #51
    wexttxco
    21 SR5 DC 4x4
    Thanks, that must be it.
    Question, what does it hurt if I leave them in as-is? With my stuff in my bed, I probably am at 3" of total lift now.
  22. Nov 3, 2021 at 12:22 PM
    #52
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I wouldn't leave it like that. I'm not smart enough to know what the overload spring actually does, but I'm guessing you're putting some unexpected strain on the rest of the pack with them that way.
    wexttxco[QUOTED][OP] likes this.
  23. Nov 3, 2021 at 12:25 PM
    #53
    wexttxco
    21 SR5 DC 4x4
    Copy that, great points.
  24. Nov 3, 2021 at 12:41 PM
    #54
    wexttxco
    21 SR5 DC 4x4
    Anyone else have pictures they can post to show if their overload is flat or curved upwards? I just don't see how my flat overload spring won't still be flat when I flip it over.
  25. Nov 3, 2021 at 12:56 PM
    #55
    wexttxco
    21 SR5 DC 4x4
    I know the overload wasn't upside down, but wondering if there is a left/right or front/back.
  26. Nov 3, 2021 at 1:02 PM
    #56
    wexttxco
    21 SR5 DC 4x4
    Could those be other tundra leafs they make?
  27. Nov 3, 2021 at 2:04 PM
    #57
    NoCoToyo
    NoCoToyo New Member
    Northern Colorado
    2019 Long Bed 4x4
    it's coming
    The way the song goes, and the way we say it around here, it's supposed to rhyme...
  28. Nov 3, 2021 at 2:28 PM
    #58
    wexttxco
    21 SR5 DC 4x4
    Ase certified mechanic buddy helped me (actually I helped him)
  29. Nov 4, 2021 at 12:56 PM
    #59
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  30. Nov 4, 2021 at 1:19 PM
    #60
    wexttxco
    21 SR5 DC 4x4
    Mine definitely isn't flipped. Waiting on a response from Icon. Thanks for the pictures
