Icon AAL vs custom build Deaver, shackles?
Discussion in 'Suspension' started by trayday, May 4, 2017.
  1. May 4, 2017 at 5:22 PM
    trayday
    trayday [OP] New Member
    Oregon
    2015 limited CM 5.7
    I'm looking to replace my leaf springs. This is my daily driver that I regularly take off road through the sand dunes at higher speeds and washed out rutted roads at slower speeds. I also want to be able to tow 3-4k pounds. I was thinking of just having a custom Deaver set built to my needs, then I remembered about the Icon's. I called Deaver and they said that I need to use shackles for the leaf springs and that I could use the set that I have now from BDS. I also called another shop about the custom built Deaver's and they said that I don't need to use shackles. Which springs and with or without shackles?
  2. May 4, 2017 at 5:29 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    My understanding was that it's required to run 3/4" shackles if you're running the Deaver K37 pack. It equals out to somewhere around 1.5-2" of lift. And from what I've been told you can still tow around 3k or so with the K37'a without them squatting. I've never seen anything say you HAVE to run shackles with the Icon pack. This question is really @Hattori's area of expertise.
    Law323 and trayday[OP] like this.
  3. May 4, 2017 at 5:54 PM
    trayday
    Oregon
    2015 limited CM 5.7
    When I talked to Deaver, they said that I shouldn't use the K37 for the weight I'll be loaded with and that the best option would to be a custom build. My shackles from bolt to bolt is 6"
  4. May 4, 2017 at 6:12 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  5. May 4, 2017 at 6:44 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Why not get the icon progressive leaf pack?
  6. May 4, 2017 at 6:54 PM
    trayday
    Oregon
    2015 limited CM 5.7
    Isn't that the AAL?
  7. May 4, 2017 at 7:03 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    AAL is add a leaf, the icon progressive leaf pack doesn't make your ride stiffer like AAL's do. It retains your main leaf (not sure if that's what it's called) and replaces most of your stock leaves. AAL just adds one for more rigidity.
  8. May 4, 2017 at 7:18 PM
    trayday
    Oregon
    2015 limited CM 5.7
    Got you, that seems like a better option for what im trying to gain.
    Law323[QUOTED] likes this.
  9. May 4, 2017 at 7:20 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    That's the route I'm going once I upgrade to bigger tires. 1.5 inches would be too much for my puny 275/70's LOL
  10. May 4, 2017 at 7:49 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    The Icon pack retains the main and overload leafs from your stock set, I believe its the top and the very bottom springs.
    Law323 likes this.
  11. May 4, 2017 at 7:56 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Thank you Zach! Overload springs, not main leaf LOL
  12. May 4, 2017 at 8:07 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Maybe its the fact that I spent all day in the sun, and haven't consumed enough beer yet, but I'm confused lol.
  13. May 4, 2017 at 8:13 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I thought they were called main leaves. See post #7 LOL
  14. May 4, 2017 at 8:16 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Ha now I gotcha. Just a bit slow right now.
  15. May 4, 2017 at 8:21 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    No worries brother! Been there more times than I care to count! LOL
  16. Mar 6, 2018 at 12:50 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Did anyone install the Icon progressive leaf pack?
    Any feedback?
    Looking for options, planning to swap out my 1" block in the rear.
    831Tun likes this.
  17. Mar 6, 2018 at 12:53 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I've got it. There's considerable space between the leafs. I'll probably switch it out for the U748 pack.
    dcsleeper408 and TheBeast like this.
  18. Mar 6, 2018 at 3:29 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    Considerable space? How so?
    Pictures of what you're experiencing?
    831Tun[QUOTED] likes this.
  19. Mar 6, 2018 at 4:18 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Gaps, both sides, top leaf is OEM. The picture is taken from behind the rear wheel.
    joonbug, GodlessPro and dcsleeper408 like this.
  20. Mar 6, 2018 at 5:07 PM
    PMR
    PMR New Member
    Patrick
    South East Tennessee
    2017 White 1794
    Icon Stage 6 Lift w/ Billet UCAs Icon RXT Leaf Pack Icon Six-Speeds w/ BFGATKO2 285-70-17 TRD Exhaust TRD Sway Bar TRD Skid Plate TRD CAI TDR Shift Knob Weathertech Floor Mats & Window Visors 2018 Tundra LED Headlights Interior and Exterior LED Upgrade
    Get the Icon RXT leaf pack. Trust me
  21. Mar 9, 2018 at 12:51 AM
    zackbremer
    zackbremer New Member
    Da Z
    Icon_Adrian likes this.
  22. Mar 9, 2018 at 2:22 AM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    The progressive pack sucks, go Deaver or Icon RXT. @14burrito and myself are having issues where they have flattened out and lost lift. To me they ride just like stock leafs except they cost an extra $275. I’ll be swapping mine out eventually and I’m leaning towards the Icon RXT pack.
    14burrito likes this.
  23. Mar 9, 2018 at 5:33 AM
    PMR
    PMR New Member
    Patrick
    2017 White 1794
    Word!!!! You will love them.
  24. Mar 9, 2018 at 5:49 AM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    No one runs OME leaf packs on tundras?i had them on my tacoma and they were great
  25. Mar 9, 2018 at 6:46 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    i do. ome drakar and coach shackles per coachbuilders suggestion. cost effective (bought springs on Amazon) and fantastic results. call david @Coachbuilder1
    speckmon likes this.
  26. Mar 9, 2018 at 7:07 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    what shackle did you go with?
  27. Mar 9, 2018 at 7:31 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    i'm a 6 inch bracket lift. plus 3. call coachbuilder awesome guy.
  28. Mar 9, 2018 at 7:51 AM
    speckmon
    Thornton, CO
    anyone have his number?
  29. Mar 9, 2018 at 7:55 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    (801) 635-4872
    PO Box 711892
    Salt Lake City, Utah 84171
    Ekstrom Design LLC. "A Coachbuilder Company
  30. Mar 9, 2018 at 7:56 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    thats his cell. i was able to reach him via text and phone. he assisted me during install after hours and on sat. spent a lot of time talking to me about options.
