Icon 2.5 series
Discussion in 'Suspension' started by Tundra174x4, Feb 29, 2020.
  1. Mar 5, 2020 at 5:10 AM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    https://state48overland.com/collect...der-steering-kit-bds-4-5-7-procomp-6-7-zone-5
    Kinda a long story, I had the pro comp 6 inch lift put on when I bought the truck new in "15, they put a cheap spacer kit. Tires wore great but on pavement every time I turned they would screech, Didn't really like that cause it was kinda embarrassing. I also lost a lot of my turning radius. Anyways, when I upgraded from the spacer lift to these ICON's, I still had the screeching, My mechanic told my problem to Eric at State 48 Overland, he called me and told me about the tie rod ends. Put them on and problems are gone, plus I got 30% of my turning radius back. I also think that they made the steering easier to turn, smoother.
  2. Mar 5, 2020 at 6:07 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Strange, i have screeching but only in parking garages. @Coachbuilder1 would the tie rods fix this?
  3. Mar 5, 2020 at 6:47 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Erick @state48overland is the man!!
    state48overland likes this.
  4. Mar 5, 2020 at 6:48 AM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    It cured mine. Now one must keep in mind, you have to make sure your rims will allow for enough room to fit. Coach Builder says a 20 inch rim is needed, that is not 100% the case as mine are 18 inch with a +4 offset
  5. Mar 5, 2020 at 7:21 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    1st gen guy checking in. My ICON 2.5's also ride rougher than I expected. I agree with your assessment. They don't handle bumps well but they do feel sporty around curves. I wish I had splurged on ADS instead.
  6. Mar 19, 2020 at 7:13 AM
    coTony
    Tony
    Montrose, CO
    What preload do you have it set at?
  7. Mar 19, 2020 at 7:37 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I've got it at the factory setting. Never adjusted them up or down. Gave me exactly 2" of lift on my 2002.
  8. Mar 19, 2020 at 12:14 PM
    coTony
    Tony
    Montrose, CO
    Just surprised at the ride
  9. Oct 10, 2020 at 8:10 AM
    McCrapper
    McCrapper New Member
    Running a stage 3 Icon kit, is there any concern with a 200lb bumper up front?
  10. Oct 14, 2020 at 7:54 PM
    bamelanc
    bamelanc New Member
    Orange, Texas
    2018 Magnetic Grey Platinum 4x4
    Addictive Desert Designs Stealth Fighter bumper w/ 40" Baja Designs Onyx6 arced dual control combo light bar and Smittybuilt X20 Comp 10k winch. Baja Designs S8 10" amber fog lights. sPod Control for lighting and compressor. ICON Stage 3 Suspension with tubular UCA set at 3". ICON Alloys Six Speed 17" machined/satin black wrapped in 285/75/17 Nitto Ridge Grapplers. TRD Performance Intake. TRD Cat Back Exhaust. LED Kit inside and out. ARB onboard compressor. Amp Research Power Step w/LED kit. Retrax XR Pro bedcover. Armadillo Bed Liner. Tint - 35/5/5 ceramic. Center Console Safe. Weather tech mats.
    I run the stage 3 icon, set for a 3" lift...not sure what preload that is, 34" ridge grapplers, C rated at 33 PSI cold. I believe the ride to be firm, but not harsh at all. It's what I expected a premium aftermarket shock to feel like..
    With a 200lb front bumper, you may want to call ICON and see if the coils are appropriate for that extra load.
    McCrapper likes this.
  11. Oct 14, 2020 at 9:31 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Icon 2.5 front 3" lift SPC UCA 2.0 rear with 1" block rides nice.Stage one. The guy at shop says he wish he did not waste all the extra money on his fox set up.
    Could not tell you personally it is just what he said. It is hard to gauge people's perception of what they expect from products.
  12. Oct 15, 2020 at 10:31 AM
    McCrapper
    Thanks for the reply, I did talk to ICON and they said it would just ride lower than expected, which is fine for me. I dont want to slam much larger tires under it yet.
