ICON 17" Vector 5 wheels
Discussion in 'Wheels & Tires' started by TheBeast, Jan 28, 2020.
  1. Nov 25, 2020 at 6:11 AM
    #121
    nks1007
    nks1007 New Member
    Nick
    2018 SR5 Cement CM
    None...... Yet
    dobinsons 2.5 in the front and a toytec shackle at 1.5 rear with a dobinsons shock.
    I ordered the 3in heavy load on accident which gave me a pretty good amount of reverse rake which I hated.
    2.5 still clears the cab mount which I’m very stoked about.
  2. Nov 25, 2020 at 6:23 AM
    #122
    nks1007
    nks1007 New Member
    Nick
    2018 SR5 Cement CM
    None...... Yet
    I don’t think a C rated is a bad idea personally. I run an E because that’s all you get at 35x12.50 lol.
  3. Nov 25, 2020 at 8:43 AM
    #123
    68bellaj
    68bellaj New Member
    Andrew
    sorry stupid question - what did you guys do about the spare wheel & tire size when you went down to 17s?
    Did you keep the original spare rim (I think it is 18" ) and mount it with a tyre of the same OD as that on the 17s?
    Does it matter that offset is different?
  4. Dec 3, 2020 at 12:27 PM
    #124
    68bellaj
    68bellaj New Member
    Andrew
    First part of my BF package from SDHQ arrived today
    Hopefully my Vector 5s will arrive at the weekend :)
    BravoDeltaRomeo likes this.
  5. Dec 14, 2020 at 7:44 PM
    #125
    Tundraofnv
    Tundraofnv New Member
    2020 Cement Crew
    #68bellaj: Did you get your wheels?
    I received my lug nuts too, but got an email telling me the wheels are 6-8 weeks.
  6. Dec 17, 2020 at 6:55 PM
    #126
    68bellaj
    68bellaj New Member
    Andrew
    I did get my wheels - they came a week after Black Friday.
    One was damaged and when I contacted SDHQ they did tell me they were on back order for 6-8 weeks
    so that sounds correct.
    I must say SDHQ were VERY responsive to help me and ICON will send out a new wheel :)
  7. Dec 30, 2020 at 12:52 PM
    #127
    Tundraofnv
    2020 Cement Crew
    Well according to FED-X I should get my set tomorrow?
  8. Dec 30, 2020 at 1:52 PM
    #128
    68bellaj
    68bellaj New Member
    Andrew
    That sounds correct.
    I got an email saying my replacement wheel
    has been shipped.
  9. Jan 11, 2021 at 4:21 PM
    #129
    Tundraofnv
    2020 Cement Crew
    Thank you to everyone that provided information and direction!!!
    Front: 6112 (3rd setting), Passenger side 2 CB shims, Drivers side 1 CB shim, CB bumper spacer, removed front Wind flap.
    Back: stock
    Tires: AT3 285/75/17 "C"
    316KS_Runner, FISHN43, Skey44 and 9 others like this.
  10. Jan 22, 2021 at 9:31 AM
    #130
    red3
    red3 New Member
    Los Angeles, CA
    2019 Tundra CM 4x4
    TBD
    Has anyone mounted the Vector 5 wheel as a spare using the under carriage hoist? I’m wondering if the bracket will fit through the center bore of the wheel. Looks like it might be too small.
  11. Jan 26, 2021 at 7:36 AM
    #131
    mossmanfj40
    mossmanfj40 New Member
    Craig
    Pittsburgh, PA
    2014 Tundra CM 1794 version
    Toytec/Eibach 3/1, Vector 5 wheels with 295/70/17 Coopers
    Sure hope they do as I am waiting on all 5 of mine to show up. These are hub centric right, so if the old spare worked I would think these would.
  12. Jan 26, 2021 at 7:56 AM
    #132
    red3
    red3 New Member
    Los Angeles, CA
    2019 Tundra CM 4x4
    TBD
    You and me both. Mine should be in this week. I called Icon and they measured the inner diameter of the center cap hole; it’s about under 75mm. I measured the bracket and spring for the hoist and the height is about 2.25” which should fit. We will see.
    mossmanfj40 likes this.
  13. Feb 8, 2021 at 10:43 AM
    #133
    970KOM
    970KOM New Member
    James
    18 TRD
    91113F37-D051-48E8-877C-FF935F3445F3.jpg Best $2300 Iv spent yet! E87F0B30-400B-4B97-ADDE-EB5C20F91737.jpg 285/70/17. Stock suspension
    Tjn361, big_green_tundra, KWC and 9 others like this.
  14. Feb 8, 2021 at 2:03 PM
    #134
    DedDucks
    DedDucks New Member
    Brett
    Tatum, TX
    2021 Cement SR5 Crewmax TSS 4x4
    This is the exact setup I’ve been looking at. Not many pics on stock suspension and 285/70/17 out there. Looks great!
    Bama likes this.
  15. Feb 8, 2021 at 3:09 PM
    #135
    nks1007
    nks1007 New Member
    Nick
    2018 SR5 Cement CM
    None...... Yet
    35x12.50
    AggiePhil, pvmike, Mr_Kane and 7 others like this.
  16. Feb 8, 2021 at 5:43 PM
    #136
    Tundraofnv
    2020 Cement Crew
    @nks1007 : Nice! What’s your set up to fit 35”?
  17. Feb 8, 2021 at 5:58 PM
    #137
    nks1007
    nks1007 New Member
    Nick
    2018 SR5 Cement CM
    None...... Yet
    Just a 3/1 dobinsons
    Skey44 likes this.
  18. Feb 8, 2021 at 6:00 PM
    #138
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    @nks1007 tire model? And you need the leaf pack ;) 35’s definitely look meaty on there.
    AggiePhil likes this.
  19. Feb 8, 2021 at 6:02 PM
    #139
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    This is on point, and lookin good! Thinking Icon Vectors in the gray when I tire replace. Can’t go C-rated due to my FWC, but I bet those ride nice.
    Tundraofnv[QUOTED] likes this.
  20. Feb 8, 2021 at 6:24 PM
    #140
    nks1007
    nks1007 New Member
    Nick
    2018 SR5 Cement CM
    None...... Yet
    Sorry it’s actually a 3 and 1 1/2. Toytec shackle on the back set at 1 1/2. And I am running the 2.5 dobinson on the front but it actually gave me a touch over 3in.
    Skey44[QUOTED] likes this.
  21. Feb 8, 2021 at 6:27 PM
    #141
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Yes, I think their front lifts can be a little higher than claimed. I’m sure with shackles and springs you’d be level. Are those duratracs? They look really aggressive and true to measurement in the 35”
  22. Feb 8, 2021 at 6:51 PM
    #142
    nks1007
    nks1007 New Member
    Nick
    2018 SR5 Cement CM
    None...... Yet
    They are duratracs. The best tire I’ve ever used in the snow.
    Im pretty much perfectly level at this point. I wouldn’t like to get a touch of rake back. Might get a leaf pack.
  23. Feb 8, 2021 at 7:00 PM
    #143
    Elduder
    Elduder New Member
    How do you like the Dobinsons?
  24. Feb 8, 2021 at 7:02 PM
    #144
    nks1007
    nks1007 New Member
    Nick
    2018 SR5 Cement CM
    None...... Yet
    They are great for the price. I mean they aren’t the BP51 I ran on my runner but overall I’m happy with them.
    Skey44 and Elduder[QUOTED] like this.
  25. Feb 11, 2021 at 4:43 PM
    #145
    red3
    red3 New Member
    Los Angeles, CA
    2019 Tundra CM 4x4
    TBD
    Vector 5s wrapped with Toyo At3s (285/75R17). 2.5” up front and 1.5” in the back.
  26. Feb 11, 2021 at 9:51 PM
    #146
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Can you do a shot down the side of the truck to show the poke of this setup? Lookin good! ​
    red3[QUOTED] likes this.
  27. Feb 12, 2021 at 2:40 AM
    #147
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Hmmmmm this thread is interesting....
  28. Feb 12, 2021 at 7:56 AM
    #148
    TFTundra
    TFTundra New Member
    I’m curious to see the side profile of this truck.
  29. Feb 13, 2021 at 8:44 AM
    #149
    red3
    red3 New Member
    Los Angeles, CA
    2019 Tundra CM 4x4
    TBD
    Here you go.
    ccress83 and Skey44[QUOTED] like this.
  30. Feb 13, 2021 at 8:34 PM
    #150
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Thanks, perfect!
    red3 likes this.
