I want to change my own oil
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rockanock, Jan 10, 2020.
  1. Jan 11, 2020 at 10:17 AM
    15whtrd
    15whtrd Mr. Blonde
    Like a FYI I won’t be coming back for anything unless I have to because you guys are pigs. LOL
    sask3m[QUOTED] likes this.
  2. Jan 11, 2020 at 10:54 AM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    They would hand me those 3 Phillip's head screws that go on the front of the skid pan or somebody might get the sheet knocked out of them
  3. Jan 11, 2020 at 4:23 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    I’m going to start doing my oil changes too. Every six month or 5k. For me it’s 6 months. Don’t Drive that much, but I do idle a bit. I’ve considered amsoil Oe oil at 5.75 a qt. M1 ep high mileage ( high zinc and tbn) cheap at Walmart 30.00 per 5 liters and oem Toyota 7.75 pert qt. The dealer is close to my house so I’m going to buy the oil there. Also consider the trd filter.
    I had the dealer install a trd a while back And with the trd filter my oil stayed clean for 4k miles and at the six month the oil still looked great before the change .I ordered a couple and the aluminum housing. When Do it this month it is what I’m going to use from now on. Hell I could change the oil and not the filter if I wanted with this filter. 734BBEC6-3AE0-4BFB-B712-2206136FE893.jpg
  4. Jan 11, 2020 at 4:35 PM
    Voyagermike
    Voyagermike New Member
    California
    Do you have the part number on the trd filter?
  5. Jan 11, 2020 at 4:37 PM
    Tiamat
    Tiamat New Member
  6. Jan 11, 2020 at 4:38 PM
    Voyagermike
    California
    Thank you :thumbsup::thumbsup:
  7. Jan 11, 2020 at 5:16 PM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    I change my oil in the wife’s 4Runner and my Tundra right around September and around March.
    The aluminum filter housing, motivx kit, and fumoto valve are all must. I also use AFE pro dry S filters. Been running them for years. They are expensive initially but 100% reusable/washable
  8. Jan 11, 2020 at 6:31 PM
    Big_Ed
    Big_Ed New Member
    Spring, Tx
    2016 Tundra
    It looks like the TRD filter has the center tube integrated. I guess that means you remove the tube that is attached to the filter housing?
    I just changed the oil today on my recently acquired used Tundra. That housing was on way too tight of course, and it cracked when I was removing it. Broke off one of the tabs that the filter wrench grabs, causing a hole in the housing. Luckily I already had the metal housing that I got to replace it.
  9. Jan 11, 2020 at 7:43 PM
    tstieb
    tstieb New Member
    2014 CM TRD
    Been there. Sucks big time.
  10. Jan 11, 2020 at 8:04 PM
    Tiamat
    Tiamat New Member
    The tube in the housing I think holds the spring loaded valve.
  11. Jan 11, 2020 at 9:11 PM
    Big_Ed
    Big_Ed New Member
    Spring, Tx
    2016 Tundra
    Sort of...The tube in the housing is attached to a disk that holds the spring. It can be detached from the disk.
  12. Jan 11, 2020 at 9:33 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    The tube in the housing stays in place whether you're using the standard filter or the TRD filter.
    You won't experience the stuck housing with the aluminum one as it won't swell with heat like the plastic one. Just make sure that you swap the tube from the plastic housing over to the aluminum housing.
    Voyagermike likes this.
  13. Jan 12, 2020 at 3:12 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Yup, if you don't your filter will come out looking like this
    duece292[QUOTED] likes this.
  14. Jan 12, 2020 at 4:40 AM
    mofferman
    mofferman New Member
    Windsor, CO
    2019 double cab
    Wow, good to know. I would be a little freaked out to pull the filter out and it looked like that!
