I want 110 volts in the bed
Discussion in 'Lighting' started by Eclipsed & Floating, Sep 24, 2017.
  1. Sep 24, 2017 at 5:20 PM
    Eclipsed & Floating
    Eclipsed & Floating [OP] Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    Has anyone installed a 110 outlet in the bed?
    What do I need to power these items?
    • charging ports
    • small space heater w/ auto shut off
    • electric blanket
    • Small Bluetooth speakers
    Some might say to get a pop-up or travel trailer. I've been down that road before and am not interested in another at this time. I like my agility.
    Any guidance would be great. I assume I should start with a supplemental battery...or two. @Spvrtan has a supplemental battery setup
    4x4_Angel likes this.
  2. Sep 24, 2017 at 5:24 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Do you mean like the Tacomas have. :jellydance:
  3. Sep 24, 2017 at 5:39 PM
    Eclipsed & Floating
    Voluptuous Whitey
    That's the only thing I miss from my Tacoma
    MaTundra NYC and big_jarv like this.
  4. Sep 24, 2017 at 5:42 PM
    Here is a quick solution. Only issue I would have is the possibility of draining your battery overnight and being totally screwed in the morning. A way to get around this is having a second battery, mount it under the bed in the wheel well, and have an isolation switch from the truck. Deep cycle RV batteries at wally world is around 79.00 and are pretty good. Disconnect switch at wally world is around 6.00. Then you could do the math on what heater or whatever you want to run will draw and go from there on what size inverter you want and what size battery(s).
    https://www.target.com/p/duracell-400-watt-high-power-inverter/-/A-16746822
    https://www.target.com/p/duracell-1...tpdph1|related_prods_vv|adaptpdph1|16746823|0
    Another option is buying one of these. I use my generator (honda 3000Ui Handi) more for everyday stuff than camping.
    https://www.farmandfleet.com/produc...qQIjD9EcuWRs8H-874jQQKVU50h49VGwaAmAxEALw_wcB
  5. Sep 24, 2017 at 5:46 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    This.
  6. Sep 24, 2017 at 5:47 PM
    Eclipsed & Floating
    Voluptuous Whitey
    A generator would be too noisy for me. My work truck had an inverter I could run power tools off of :thumbsup:
    I want something quiet that can power my heat. In doing much stationary camping so I want something to operate on the fly with much less weight. Your first suggestion is more what I'm going for, and iwanna hook up to the alternator so it'll charge on the road. I almost bought the dual setup @Spvrtan had but couldn't part with the money at that time
    4x4_Angel and ColoradoTJ[QUOTED] like this.
  7. Sep 24, 2017 at 5:54 PM
    Eclipsed & Floating
    Voluptuous Whitey
    @mdavis remind me how to calculate how much power I need
  8. Sep 24, 2017 at 6:00 PM
    Eclipsed & Floating
    Voluptuous Whitey
    As for the generator/inverter you posted....its gas powered but does it run loud like all other generators I've used. I've only used em for construction sites on 100 ft power cords to run all sorts of saws. Since i'm not a familiar with output and horses I'm wondering if this lightweight one you posted would be as loud. 50 lbs works but I'm stillconcerned about volume
  9. Sep 24, 2017 at 6:03 PM
    That one runs at 53 dB. That is pretty quiet bud. Mine runs at 59 dB and usually cannot hear it.
    Here is a chart to compare to.
    http://www.noisehelp.com/noise-level-chart.html
  10. Sep 24, 2017 at 6:11 PM
    Eclipsed & Floating
    Voluptuous Whitey
    That is quiet. According to the chart the heater I'm thinking would be louder that that. Thanks for the qdvice. Now, can I borrow $469? You can go camping with me :D
  11. Sep 24, 2017 at 6:15 PM
    Absolutely!!
    So if you woke up after a night of camping, Vaseline around your starfish and butt hurting a little, would you tell anyone?
  12. Sep 24, 2017 at 6:19 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Does bragging count as "telling anyone?"
  13. Sep 24, 2017 at 6:23 PM
    Wanna go camping?;)
  14. Sep 24, 2017 at 6:24 PM
    Eclipsed & Floating
    Voluptuous Whitey
    You get the vasoline...I'll pick up the aloe
    ColoradoTJ likes this.
  15. Sep 24, 2017 at 6:25 PM
    Perfect.
  16. Sep 24, 2017 at 6:25 PM
    Eclipsed & Floating
    Voluptuous Whitey
    I charge $469 plus sales tax
  17. Sep 24, 2017 at 6:28 PM
    Well you're cheaper than a wife...sounds good to me.
  18. Sep 24, 2017 at 6:34 PM
    mdavis
    Michael
    Rock Hill, SC
    Not much math to be done here. Just a little addition. You'll have to spec out all the items you would want to run at the same time and add their wattage usage to find out what size inverter would work best for you. The higher wattage inverter, the higher the price.
  19. Sep 24, 2017 at 6:38 PM
    Eclipsed & Floating
    Voluptuous Whitey
    The items I listed above are what I'm looking to use primarily. Power tools will be an occasional usage. Thanks for the beta. I'm the plug and use kinda guy. Output detail is my weakness. Thanks bud!
    mdavis[QUOTED] and 4x4_Angel like this.
  20. Sep 24, 2017 at 6:56 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  21. Sep 24, 2017 at 6:56 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    The real question here is, why haven't the vendors in here designed an aux batt setup? Seems like plenty of guys would be jumping on that.
  22. Sep 24, 2017 at 6:57 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I bought this off Amazon. Wasn't too much, pretty quiet and you can get another and run it in parallel if needed. Fully fueled it weighs about 40 lbs. pretty happy w it. A lot less expensive than Honda. I would've gone w a Honda if I could've at the time. This one is pretty quiet though. You can stand next to it and still have a conversation. IMG_1335.jpg
  23. Sep 24, 2017 at 6:57 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    When you talk about running heating elements, you are using a lot of power. I believe you will drain your battery bank way too quickly to be a reasonable solution. I did not do a lot of research but based on what I saw, I would guess you will burn through a fully charged 100 AH battery in between 4-6 hours running a less than 1000 watt heater. Small propane heater with an O2 sensor may make more sense.
    You can get a 12 volt electric blanket that only draws about 5 amps but I don't know if it really going to help much.
  24. Sep 24, 2017 at 7:10 PM
    This is exactly what I have for nights in my truck with the softopper. Get a truck bedz inflatable mattress and stay warm. The right gear helps as well, and knowing how to use this gear in colder weather is key.
  25. Sep 24, 2017 at 8:33 PM
    Eclipsed & Floating
    Voluptuous Whitey
    It's a small tent. I don't think k I'm iterated in a propane heater. I'm interested in the electric blanket and I'm going bigger on my sleeping bag temp rating. I don't want to stop camping over the winter aND it gets balls cold where I live.
    I'm starting to think a small portable generator/inverter would be great for what I'm doing
  26. Sep 24, 2017 at 8:42 PM
    Eclipsed & Floating
    Voluptuous Whitey
    So check it's out...
    When I was in Alaska camping in the winter we would build a super hot fire on top of a foot deep hole filled with decent sized rocks. Take TE rocks out and put them in a trench to cover with dirt. Setup a tent over the warm dirt and the insulated rocks would keep us warm in negative temps in -15 degree bags. It's like sleeping on an oven in the winter
  27. Sep 24, 2017 at 8:43 PM
    Tundra Fan
    Toby
    Balls is not a measurement of cold, only hot.
    mdavis, TXMiamiFan, aperezsh and 2 others like this.
  28. Sep 24, 2017 at 8:46 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Guys like me are more affected by cold balls, at least it's more noticeable :frusty:
  29. Sep 24, 2017 at 8:54 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    :eek:
  30. Sep 24, 2017 at 8:54 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    :confused:o_O
