I shorted something... door locks not working. Help!!!!!!!!!
Discussion in '1st Gen Tundras (2000-2006)' started by Kameleonmax, Sep 27, 2014.
  1. Sep 27, 2014 at 10:28 PM
    Kameleonmax
    Kameleonmax [OP] New Member
    Ralph
    2006 Toyota Tundra 4wd double cab
    I was adding some led strip lights to illuminate my side steps then i was fiddling around some wire harnesses to check for a best possible area to splice my wires. I tried testing some wires with my dmm and i shorted something. Now my remote door lock/unlock doesnt work, i cant lock/unlock it from the door panel. Can someone help me please!!!!!!
  2. Sep 28, 2014 at 9:06 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Sounds like a fuse hopefully. Pop your covers off the fuse boxes and look for an accessory power with blown fuse and pop a new one in.
    Bob likes this.
  3. Sep 28, 2014 at 5:23 PM
    Kameleonmax
    Ralph
    I Checked all the fuses. They all looked good. Unless there were hairline breaks that i couldn't see. Hope its not a relay.
  4. Sep 28, 2014 at 5:56 PM
    Relentless
    Eric
    Did you check both fuse boxes?
  5. Sep 28, 2014 at 6:14 PM
    Kameleonmax
    Ralph
    Yes. I checked above driver kick panel and engine compartment. Are there any other places where there's fuses? I hope its not a relay.
  6. Sep 28, 2014 at 7:28 PM
    Mike Tread lightly.
    south carolina
    while you where fiddling around did you not plug something back in correctly? If all the fuses are good.. unless your shorted the door relay box out...
  7. Sep 28, 2014 at 9:31 PM
    Kameleonmax
    Ralph
    Soooooo guys, it was a fuse that i missed 7.5a. So i replaced that. Everything's good now. As for my lights, how can i hook up that when i open each door, each designated light would light up at that side step?
    KK6PD, T-Rex266, Bob and 1 other person like this.
  8. Sep 28, 2014 at 9:58 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Use a new relay and tie into the wire that leads to the cab light. You might be able to tie in right at the switch for the cab light.
    Relay and harness here: http://www.oznium.com/wire-12v-and-relays
    Set it up so that when the cab light goes on then the relay is met. This will close the loop and turn on the door lights.
    Not sure if you can do each door separate without adding a separate door switch pin: http://www.oznium.com/pin-switch
    T-Rex266, Bob and Relentless like this.
  9. Sep 29, 2014 at 1:57 PM
    googlydoodle
    googlydoodle New Member
    Geoffrey
    Lucy
    100% stock
    hope this helps... This should be your cargo lamp and courtesy switch wiring diagrams
    NewImprovedRon likes this.
  10. Oct 5, 2014 at 2:02 AM
    Kameleonmax
    Ralph
    Got it done. Will have a video/pic on the finished product...... ;)
  11. Oct 19, 2014 at 8:58 PM
    Kameleonmax
    Ralph
  12. Oct 20, 2014 at 7:47 AM
    csuviper
    Broomfield, CO
    That is awesome man. Going to have to do something like this to mine eventually.
    Kameleonmax[OP] likes this.
  13. Oct 20, 2014 at 7:48 AM
    csuviper
    Broomfield, CO
  14. Oct 20, 2014 at 4:51 PM
    Kameleonmax
    Ralph
    Thanks.....
    Since the door switches are the grounded type, i wired the (-) side of each of the strip lights so each one operated separately for each door.
  15. Oct 20, 2014 at 5:26 PM
    csuviper
    Broomfield, CO
    Negative of the light to the door switch and the positive side to where?
  16. Oct 23, 2014 at 1:07 PM
    csuviper
    Broomfield, CO
    Can you post up the light strips and relays etc that you purchased for this project? Would help me and others out if we choose to do this?
  17. Oct 25, 2014 at 12:21 AM
    Kameleonmax
    Ralph
    Positive to a constant source
  18. Oct 25, 2014 at 12:28 AM
    Kameleonmax
    Ralph
    I only purchased the light strips from Amazon. Like these:
  19. Oct 2, 2021 at 7:27 PM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD
    My apologies for necro-posting, but thanks for this! Saved my a$$ from buying a new remote module. I too was troubleshooting and let the sparks out at the junction fitting in the passenger footwell. A quick search found this and I checked all my fuses again... yep, 7.5A!
    Darkness likes this.
  20. Oct 3, 2021 at 12:01 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @bmf4069 we need thread revival memes
  21. Oct 3, 2021 at 12:11 AM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    How 'bout this? Courtesy of @BubbaW
  22. Oct 3, 2021 at 12:15 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Back on my cellular device!
  23. Oct 3, 2021 at 12:47 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    To be fair, it is nearly Halloween, despite the fact that Xmas is going on in Lowe’s right now, so necromancy is cool.
  24. Oct 3, 2021 at 2:18 AM
    Desert Dog
    I can dig it for thread revival memes any time of the year.
  25. Oct 3, 2021 at 2:40 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    shifty` and Darkness like this.
  26. Oct 3, 2021 at 8:53 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    As Heather would say...
    Tundra2 likes this.
  27. Jan 31, 2023 at 12:49 PM
    threeroundpro
    threeroundpro "Here to f*ck sh!t up!" and then fix it...
    Ed
    2006 DC SR5 4.7L
    SAIS bypass, GMRS radio, everything else still stock
    This thread has heald me . Just ran into the same problem, lol
