I picked up this 2004 for $550
Discussion in '1st Gen Tundras (2000-2006)' started by jmohn6, Dec 31, 2022.
  1. Jan 2, 2023 at 8:37 PM
    jmohn6
    jmohn6 [OP] New Member
    OK after investigating more found out this is the A.D.D. Actuator, what I haven't found oy=t yet since it's cold out here and the wire is burnt to a crisp. does the wire from the A.D.D acuator go to the Actuator at the end of the transfer case or uo to the wiring harness any help please
  2. Jan 21, 2023 at 3:38 PM
    jmohn6
    Okay guys need aliitle help here please beside the acuator getting fried and the wire from the fire. I not sure but it goes into the front muffler system and although it doesn't look fired from the fire upper more it didd melt the wires I'll send pictures and any help please, also looks like the actuator housing was the cause of the
  3. Jan 21, 2023 at 3:39 PM
    jmohn6
    Here is other unit I pretty sure the wire got fried from the fire
  4. Jan 21, 2023 at 4:48 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    that’s an O2 sensor.
  5. Jan 21, 2023 at 4:55 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Damn, I hope that’s dirt. It looks like it’s rust welded in place.
    Kinda looks like you need a new bung hole. :eek2:
    bmf4069 likes this.
  6. Jan 21, 2023 at 5:37 PM
    I'm confused, where's it burned up? I don't see the burnt up spot.
    O2 sensors can be a little finicky when it comes to splicing on the wires. Make sure whatever you use is solid, and water-impenetrable.
  7. Jan 22, 2023 at 11:49 AM
    jmohn6
    Thanks guys, yes it's rust and I'm going to replace the O2 Senor and replace the the manifold and the muffler system
    Jack McCarthy likes this.
  8. Jan 22, 2023 at 5:17 PM
    Careful which cat you go with if you choose to replace. There are only a couple of brands known to be compatible, and not throw codes consistently.
