I need help with air bags
Discussion in 'Towing & Hauling' started by 510Krish, Nov 29, 2018.
  1. Nov 29, 2018 at 11:22 PM
    510Krish
    510Krish [OP] New Member
    2018 Toyota Tundra Platinum 4x4
    so I have a 2018 CM 4x4 lifted 6in. So from what I know procomp lifts them 6in in the front and 4in in the back. So the problem is that I don’t know what size spacers to use. Do I use the 6in spacers or the 4in? Can someone link me the correct spacers and what I’m planning to do is have a wireless one and then have the bags on a cradle with the spacers. I would appreciate it if someone could link me the correct spacers and let me know if what I’m trying to do will work or not.
  2. Nov 30, 2018 at 8:57 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
  3. Nov 30, 2018 at 10:25 AM
    510Krish
  4. Nov 30, 2018 at 10:29 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
  5. Nov 30, 2018 at 10:36 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
  6. Nov 30, 2018 at 11:12 AM
    510Krish
    Just what I’m looking for! Do you also have a 6in lift? And how do I install the spacer?
  7. Nov 30, 2018 at 11:41 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    yes. I have the ProComp 6 inch. The spacer bolts on to each bag. Super simple, you can install the whole system in 45 mins.
  8. Nov 30, 2018 at 12:28 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    If the back end is lifted with just a block, you shouldn't need a spacer under the bag, as the leaf springs stay in the same place relative to the frame. You will need the extended support that extends the support leg down to meet the axle tube.
    15whtrd likes this.
  9. Nov 30, 2018 at 12:59 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    The OP is specifically asking about a Procomp 6 inch lift which does indeed contain a AAl and a block. Based off of my own experience of installing it, if you don’t use the spacer the bag will be stretched 2 inches in the normal resting position of the suspension. It won’t look right and I’m positive unless you have Superman fingers you will not be able to stretch that bag to install it. If by the slim chance you can get it installed, you have just created the situation that we all with bags avoid when we take it in for a wheel rotation,( hanging by the bags ) That’s why people who off-road prefer the cradles..
  10. Nov 30, 2018 at 3:40 PM
    510Krish
    Hey so I was just looking at the bags, so will the bags you linked work with my 2018 tundra? Because it says it only works with the 07-13 models.
  11. Nov 30, 2018 at 3:44 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I’m not sure if they changed anything on the rear. Somebody on here knows though..
  12. Nov 30, 2018 at 5:31 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
  13. Nov 30, 2018 at 6:01 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I know the op is asking about spacers for the bags. But I read today, that if you use the Daystar cradles with the Firestone bags, it voids the warranty on the bags from Firestone. Just a little fyi for the guys/gals with the cradles.
    jeremyd likes this.
  14. Nov 30, 2018 at 7:44 PM
    510Krish
  15. Nov 30, 2018 at 7:46 PM
    510Krish
    But how is Firestone going to know? When it goes bad just take the cradle off and then send them over a picture or how ever it works for the warranty.
  16. Nov 30, 2018 at 7:51 PM
    easleycrawler
    Travis
    Good point. Have no clue how they would know.
  17. Nov 30, 2018 at 7:57 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Not me ! I bought mine used for 100 bucks ! lol
  18. Dec 1, 2018 at 7:09 AM
    Cuzican
    Cuzican New Member
    Louisiana
    If rhe pro comp lift uses a 2" AAL and a 2" lift block, then you should have a 2" spacer under the bag and a 2" support leg extension. Without the support leg extension you are at risk of the lower bracket bending on you. I've attached a pic of the leg extension I'm talking about, you can see the original bracket, behind the leg extension, is no longer even close to resting on the axle tube.
  19. Dec 1, 2018 at 7:44 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    The Procomp 6 inch lift doesn't use a 2 inch block. But Ok..
    I'm pretty sure you would have to jump this truck to bend that lower bracket.
  20. Dec 1, 2018 at 8:14 AM
    Cuzican
    Cuzican New Member
    Louisiana
    OK..., regardless if the block is 1" or 5", it will space the support leg off of the axle tube and open up the possibility of bending the lower bracket. You do what you want, I'm just saying that the proper install would result in the support leg actually making contact with the axle tube. So, however much lift the AAL gives will require a spacer that size between the bag and bracket and however big the block is, will require a leg extension that size. This all due to the fact that the firestone kit does not place the bag over the leaf springs, so any weight will need to be supported properly, a small 1/4" gap, maybe 1/2" might be ok, if it bends the bag can accept some articulation. Depending on how it bends though, you do have a small risk of tearing a bag, or if just one side bends, the truck will no longer sit level when supporting weight.
    15whtrd likes this.
  21. Dec 1, 2018 at 8:20 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I agree, the support bracket wouldn't hurt. Mine has been on for 4 years so I'm leaving it. And I still believe you would have to jump this thing to bend that bracket.
  22. Mar 10, 2022 at 11:28 AM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    Reviving this thread.
    So what do I need to do as far as airbags go if I have a Pro Comp 6 inch lift and have replaced my rear leafs with custom Alcans
    and Coachbuilder +3 shackles?
  23. Mar 12, 2022 at 9:34 AM
    vtdeuce
    vtdeuce New Member
    2013 Black Tundra RW
    I have the bags with the CB shackles and the BDS 7in lift. At one point Firestone made a bracket that would work with this loft but discontinued it. They believed it was unnecessary from their analysis. I proved otherwise as I bent the bottom bracket towing a trailer. I wish they would fabricate the extension brackets again as these bags really do need them as they are offset from the spring. They sent me new bottom brackets but I am hoping at some point to get a local shop to fab me the extension brackets.
  24. Mar 20, 2022 at 10:43 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Odd. If I remember correctly from the Firestone install instructions, they mention that the support “leg” may not rest on the axle tube and it’s not necessary.
    My setup uses Daystar cradles, and I have Deaver U748 springs. With no load and minimal air pressure, the bags are just sitting in the cradles. Put any (10+ psi) pressure in them, and they’re starting to lift up the rear and support added weight. For reference, the Deavers are still about 3” over factory height, and the packs are much thicker than OEM. Meaning that there is about 2” more space between airbag mounts than with a stock rear suspension.
  25. Mar 28, 2022 at 10:53 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    They still make the brackets for 2 and 3” block lifts and the spacers for the bags themselves. E trailer sells the support brackets. Would either work for ya?
    https://www.firestoneip.com/content/dam/fsip/pdfs/ride-rite-pdfs/lift-spacers.pdf
  26. Apr 20, 2022 at 5:25 PM
    vtdeuce
    vtdeuce New Member
    I had a local shop fab the bracket extensions (and straighten out the bottom bracket) as the bottom bracket was bending again. Unless you are hauling a trailer with leaves, then I highly recommend the extensions. It was definitely the weak point in my setup. I tow a heavy two axle dump trailer and ~9K camper.
    kparrow likes this.
