I have successfully swapped a 3rd Gen (2015) Instrument Cluster into my 2nd Gen (2007)
Discussion in '2nd Gen Tundras (2007-2013)' started by Jeff_5_7, Apr 1, 2021.
  1. Apr 17, 2021 at 7:47 PM
    #61
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    That is so cool. Nice work.
  2. Apr 18, 2021 at 8:27 AM
    #62
    TXTundraFan
    TXTundraFan New Member
    Does the 3rd gen dash mount easily in place of the 2nd gen dash or do you have to do a lot of modification to make it work?
  3. Apr 18, 2021 at 11:32 AM
    #63
    Jeff_5_7
    Jeff_5_7 [OP] New Member
    Jeff
    Houston Tx Area
    Quick answer that 99% of the bolt holes lined right up. I pulled the old bolts out and put them right back in holding in the new dash. I did have to do some minor modifications. The biggest issue I saw was the brackets the radio bolt to are 3-4 inches to far toward the passenger side console. The steel brackets mount to the dash support steel tube. The newer radios are shifter left closer to the driver.
    I pulled the passenger side air bag and wiring out of my 2007 dash and layed it all in the 2015 dash. The harness and everything inside will be 2007 with a 2015 cover on top of it. I am repining some connectors and switches right now.
    Just working on finalizing the install, mainly wiring. I have a 2018+ steering wheel and gauge cluster coming and am working on wiring in the steering wheel controls and newer gauges. After that the radio is all that will be left and I can decide if I go stock or aftermarket.
  4. Apr 18, 2021 at 2:12 PM
    #64
    TXTundraFan
    I really like the 2014+ dash and actually prefer it over my 2010, but don't like the prices of the newer trucks. :) I'll be curious what your thoughts are on difficulty once you are all done.
  5. May 17, 2021 at 1:34 PM
    #65
    fish2keel
    fish2keel New Member
    Any update on this?
  6. May 17, 2021 at 1:41 PM
    #66
    Jeff_5_7
    Jeff
    Houston Tx Area
    Yes, I am like 95% done with a full interior swap. I installed the center console and new carpet over the weekend. Seats are set in the truck mocked in place and doing wiring now.
    The dash is essentially done with a factory nav unit for the radio. The glove box is currently not installed but I do have it. I got all the bugs worked out so no warning lights or anything on the dash. All the dash buttons have the correct leds for color with lights on and they all work properly.
    Just a bunch of loose ends to tie up and it will be a complete 3rd gen interior in a 2nd gen truck.
    Wynnded likes this.
  7. May 17, 2021 at 1:47 PM
    #67
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Dude, this is really impressive work you're doing here.
  8. May 17, 2021 at 2:27 PM
    #68
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Wow really nice work!
  9. May 21, 2021 at 8:27 PM
    #69
    TXTundraFan
    Looking forward to seeing the finished product! Do you have any pics you can post of the progress?
  10. May 28, 2021 at 2:51 PM
    #70
    Jeff_5_7
    Jeff
    Houston Tx Area
    Sorry I read this and forgot to come back and add some photos. Anyway I just went through my picture collection and grabbed a few to share quickly. I have ALOT of photos for my entire build. When the truck is done I want to make like a youtube video that cycles through all the progress/photos
    I have made more progress since these were taken. Have new carpet, seats, and full center console installed.
    2007 Dash coming out
    Dash fully removed, It only took a few hours to get it out.
    News dash out of a 2015 Work Truck Tundra
    Top is 2015, Bottom is 2007
  11. May 28, 2021 at 3:27 PM
    #71
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Impressive
  12. Jun 3, 2021 at 4:46 PM
    #72
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    There's a guy on youtube that has videos of the work he's doing on the conversion to 3rd gen on their 2nd gen.
    Here's part 1 of the video but if you look in their channel, you can see the other videos.
    https://www.youtube.com/watch?v=1gcC8te9qi0
  13. Jun 3, 2021 at 7:05 PM
    #73
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    This is awesome. Is there a difference on the gauge cluster connector/ pin outs between 2013 and 2014? What about up to '17?
  14. Jun 4, 2021 at 12:26 PM
    #74
    Jeff_5_7
    Jeff
    Houston Tx Area
    I stumbled across his videos when I was doing my front end swap in March. He was taking his front end apart and I was putting my new one on. I guess I could have waited for more of his videos but I never went back to see if he posted more updates.
    omgboost[QUOTED] likes this.
  15. Jun 4, 2021 at 12:30 PM
    #75
    Jeff_5_7
    Jeff
    Houston Tx Area
    It is my understanding the wiring for the 2007-2013 trucks are the same at the connector into the panel. I would have to double check a diagram from a 2013 to be sure. When I did mine I used a 2007 wiring diagram and a 2015 diagram.
    Then the 2014-2017 ones should all be the same also, but these are different from the 2007-2013 ones. It is the majority of the same wires, they are just in different pin locations.
    In 2018 the cluster was upgraded again when Toyota added the Safety Sense system to all the Tundras. The 2018+ wiring is different from the 2014-2017, matter of fact the 2018 cluster has 2 wiring plugs in the back. All the older models only have 1 single plug/connector.
    Wynnded and e30cabrio[QUOTED] like this.
  16. Jun 4, 2021 at 12:34 PM
    #76
    e30cabrio
    Thanks.
    I put a 13 Optiron in my 10 Tundra.
    I'd like something newer without the "portholes" in my 13 Sequoia.
    There is a 14 Tundra cluster on eBay for 80 bucks maybe I'll gamble.
    Thanks
    #76
  17. Jun 4, 2021 at 4:03 PM
    #77
    Jeff_5_7
    Jeff
    Houston Tx Area
    I have had guys ask me a about making a plug and play harness to put the 14+ cluster in an 2007-2013 truck. The wiring is easy. The problem is mounting and the difference in dash trim ect
    #77
    BlueCrushSC16 likes this.
  18. Jun 4, 2021 at 4:17 PM
    #78
    e30cabrio
    I'd buy one.
    The Sequoia dash should work.
  19. Jun 4, 2021 at 4:22 PM
    #79
    Jeff_5_7
    Jeff
    Houston Tx Area
    The 2014 sequoia cluster mounts the same as the 2014 Tundra cluster?
    if so that would be an easy swap
  20. Jun 4, 2021 at 4:54 PM
    #80
    omgboost
    East Coast
    I think the 2008-2017 Sequoia dash is the same as the 2007-2013 Tundra. If you got the 2014-2017 Tundra cluster to work on the 2nd gen Tundra, it should work on the 2nd gen Sequoia (pre 2018) too.
  21. Jun 4, 2021 at 5:07 PM
    #81
    Jeff_5_7
    Jeff
    Houston Tx Area
    No I removed my 2nd gen dash 2007 dash and swapped in a Full 2015 3rd gen dash
  22. Jun 5, 2021 at 5:43 AM
    #82
    Crizzlej5
    Crizzlej5 New Member
    If you ended up that deep into it with the wiring diagrams and harnesses and etc, did you happen to find a way to have the dash be permanently illuminated? Also looks good by the way
  23. Jun 5, 2021 at 5:46 AM
    #83
    Jeff_5_7
    Jeff
    Houston Tx Area
    You mean where the dash is like your headlights are on 24/7? It seems almost all of the lights run on an illumination circuit. I dont think it would be hard to put that circuit on a separate toggle switch or a relay that turns on with the ignition switch. As soon as the key comes on everything lights up and stays that way day or night.
  24. Jun 5, 2021 at 6:49 AM
    #84
    Crizzlej5
    Exactly gauge cluster lit up all the time and headlights off, I've seen a bunch of threads on it for a long time, don't think anyone has found a solution yet
  25. Jun 6, 2021 at 1:12 PM
    #85
    TXTundraFan
    Very nice!! How hard was it to get the new dash mounted up to the existing brackets? Any gotchas?
  26. Jun 7, 2021 at 9:57 AM
    #86
    Jeff_5_7
    Jeff
    Houston Tx Area
    No it snapped right in place where the old one came out. As I mentioned earlier, the steel brackets for the radio have to be removed as the newer dash center stack is shifted closer to the driver.
    Kind of hard to tell but the radio location it further to the right in the 07-13 trucks.
    These two brackets in the red circle will be in the way of the new dash.
    Wynnded likes this.
  27. Jun 7, 2021 at 1:01 PM
    #87
    Caruso
    Caruso New Member
    Thank you OP for taking the time to post this.
    Any chance you recall the correlating pins between the 07 climate control harness and 15 climate control?
  28. Jun 7, 2021 at 1:16 PM
    #88
    Jeff_5_7
    Jeff
    Houston Tx Area
    Sure, 2007 is 16 pin connector. The 2014+ is a 8 pin.
    The hazard switch is on the newer AC control panel so you have to wire that in. Also you will need to change the AC amp.
    The 2007-2013 trucks have dual zone AC which means the blend doors for driver and passenger side operate on their own individual servos. The 2014+ AC is only single zone and the driver side servo controls one blend door for both sides of the cab. As of right now the 2014+ AC controls and AC amp do not control the passenger temp settings in my truck. Mine is just stuck on full Cold AC since it is summer time. I will fix this eventually, just not sure how yet.
    If you can you might want to swap the full HVAC box inside the dash. This might be the easiest solution.
    Wynnded likes this.
  29. Jun 7, 2021 at 1:28 PM
    #89
    Jeff_5_7
    Jeff
    Houston Tx Area
    I still want to look into this. I think it will be a relatively simple fix. I was driving my truck around this weekend thinking how nice if would be if the cluster was lit up and I could see it better during the day.
  30. Jun 7, 2021 at 1:40 PM
    #90
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    Is there a build thread for the whole truck, I need pics of this truck.
