I have a clicking noise behind the radio.
Discussion in '2.5 Gen Tundras (2014-2021)' started by TheTripleLindy, Jan 28, 2019.
  1. Jan 28, 2019 at 12:38 PM
    TheTripleLindy
    TheTripleLindy [OP] New Member
    I have a clicking noise that sounds like a fan or something winding down. It does not always do it. Nearest I can tell, the noise is not relate to AC being on or off or heater running. Best way I can describe the noise is a baseball card in the bicycle spokes and you are coming to a slow stop.
    I do not want to deal with Toyota service if I can avoid it.
    Anyone have a similar problem or know what it might be?
    I have looked behind the radio several times, but with the ac panel off, and I have not been able to get the sound when it is all torn down.
  2. Jan 28, 2019 at 8:16 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    Someone will chime in and maybe confirm for me but I am fairly certain that noise is normal.
  3. Jan 29, 2019 at 3:31 AM
    Adam New Member
    the dash plastics are notoriously noisy. Try wedging a business card between some of the joints in the dash to see if it goes away. My spot was on the right of the radio trim. After you figure out what makes it stop, you can come up with a permanent solution. Otherwise, try turning off your fan and see if it goes away. Something could have gotten past the cabin air filter when changing it out. A blower motor with bearings going out can sound like that...did on my wifes Pilot.
    FlashCulprit and 15whtrd like this.
  4. Feb 1, 2019 at 6:26 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Plastic gears perhaps? Maybe the mixer?
  5. Feb 2, 2019 at 10:29 PM
    Fastestcolor
    Fastestcolor New Member
    Blue Ribbon Limited CM
    I’ve heard this noise. I looked under the hood. I popped off the big plastic trim on top of the engine and reseated it. Noise stopped. Could be a complete coincidence.
  6. Feb 3, 2019 at 2:54 PM
    TheTripleLindy
    sounds like it is a fan blade or something behind the radio, but i will give it a shot
  7. Feb 3, 2019 at 2:55 PM
    TheTripleLindy
    maybe, i changed out the radio and it is still under warranty; i figured they would try and blame it on the radio change and try and fix it myself
  8. Feb 3, 2019 at 2:56 PM
    TheTripleLindy
    no filters have been changed; only 10k mileage on it; it is not the dash, was making the sound before and after i tore it apart; will mess with the fan settings and see
  9. May 25, 2023 at 11:12 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    Did you ever solve this? I have it on my 17
  10. May 26, 2023 at 8:35 AM
    SD Surfer
    Bruce
    So Cal
