I have 98k miles on my 2013 5.7. And all the lights just came on out of no where. 4lo blinking chec,
Discussion in '2nd Gen Tundras (2007-2013)' started by 2013 trd limited, Aug 19, 2021.
  1. Aug 19, 2021 at 8:32 PM
    2013 trd limited
    2013 trd limited [OP] New Member
    Does anyone know if Toyota is still warranty the problem that causes these three lights to illuminate(trac off, check engine, and 4lo blinking)? Or is it somthing I could possibly fix myself? I had auto zone check for codes and only p0175 code c1201 code came up.
  2. Aug 19, 2021 at 10:37 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    P0175 has a lot of causes, have you had any work done to the truck recently?
    2013 trd limited[OP] likes this.
  3. Aug 20, 2021 at 12:15 AM
    kanger328
    kanger328 New Member
    Anchorage, Alaska
    2012 DC 4x4
    Is it in "limp mode"? Sounds very much like the secondary air injection pump failure. If it's this, the repair is like $3K, but you can buy a Hewitt bypass kit for like $400.
    BenAZ likes this.
  4. Aug 22, 2021 at 10:50 PM
    2013 trd limited
    No sir it is not in limp mode hopefully it won’t go in it! I don’t t know if it is just coincidence that it was just in body shop to get the front driver side bumper fixed. When I got it out the shop all the lights came on. Or if it is something they could have messed up doing body work.
  5. Aug 23, 2021 at 10:36 AM
    audiowize
    Paul B.
    It's probably not a coincidence. I would be carefully inspecting the area around the air box for unplugged wires. It might be worth pulling apart the air box and checking to be sure there isn't some piece of masking plastic or something stuck in the air intake.
