I have 2017 4.6 v8 crewmax shortbed , can I pull trailer 29ft dry weight 4850 what is the max weight
Discussion in 'New Member Introductions' started by willyferg, May 18, 2021.
  1. May 18, 2021 at 12:40 PM
    willyferg
    willyferg [OP] New Member
    william
    2017 4.6l v8 tundra crewmax
    Prostar 190 likes this.
  2. May 18, 2021 at 1:31 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Welcome from Alaska
    Have you checked out the towing/ hauling forum.
    Probably have all the answers you looking for in a thread there.
  3. May 18, 2021 at 1:41 PM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    2017 5.7L Crewmax Blazing Blue
    Not sure about your engine, but the 5.7 L tows up to approx 10,000 lbs. Payload is typically the limiting factor. Doubtful in your case because a 5,000 lb trailer should only have a hitch weight of 500 lbs or so. So you should be fine weight wise.
    29 feet is pretty long though. That is a lot of side force blowing on it while you are cruising down the highway. Be sure to get an anti sway hitch, weight distribution would be good too.
  4. May 18, 2021 at 1:44 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I’m not a trailer expert but from what I’ve seen, 10% may be too conservative. Once you add on propane tanks, batteries, WDH, you’re probably at 15%.
  5. May 18, 2021 at 6:47 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  6. May 18, 2021 at 7:41 PM
    Welcome from Ohio
  7. May 18, 2021 at 8:57 PM
