I hate to do this
Discussion in 'Suspension' started by Theyfzman, Apr 11, 2017.
  1. Apr 11, 2017 at 3:14 PM
    Theyfzman
    Theyfzman [OP] New Member
    Pa
    08 TRD
    Ok I know I know use the search button but this is more fun !!!
    So I put my TRD exhaust on today and once I was all done and lower it to the ground and crawled underneath to make sure there were no clearance issues I noticed that my leaf packs look kinda nasty and they almost look like there arching in the opposite way right in the center, so im thinking its time for a new pack, here lies the prob. which leaf pack to go with, my truck is used mostly for a pleasure ride, not much wheeling, so some comfort would still be nice, but I do haul a 6x12 enclosed trailer total weight loaded is around 3700lbs I have the toytec shackles on already but def. noticed the rear looks to be sagging lately, so what are your guys thoughts on what I should go with
    thank you much
  2. Apr 11, 2017 at 3:29 PM
    15whtrd
    15whtrd Mr. Blonde
    Stock
    GNTundra likes this.
  3. Apr 11, 2017 at 3:34 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Either get some OEM ones or maybe deavers
    FlashCulprit likes this.
  4. Apr 11, 2017 at 3:37 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Is this normal for people with shackles? Seems like mine is losing its arch also. I'm on CB's+3.
    Thinking when it's time to just ditch the CB's and use a full leaf pack to get my rear lift.
    dcsleeper408 likes this.
  5. Apr 11, 2017 at 3:48 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    If you have the stock leaf packs, and don't want to break the bank, get the Roadmaster Active Suspension kit. It's like ~$300 and mounts on top of your leaf packs. They're great for your needs, especially if you're not really wheeling the truck, such as daily driving and occasional towing. Because they're an "active" suspension, you also don't need to do anything between loading down the back like you would with having to air up air bags.
    BlueBottle likes this.
  6. Apr 11, 2017 at 4:05 PM
    Theyfzman
    Pa
    08 TRD
    If I can I would like to get rid of the shackles if I can just get a heavier set of leafs to give me the lift I'm looking for I would like a slight rake to it right now the way the leafs are sagging it's almost higher in the front
    I have the full toytec 3-1 ultimate lift on it now
  7. Apr 11, 2017 at 4:10 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Toyota springs are fairly flat from the factory.
    dcsleeper408 and BlueBottle like this.
  8. Apr 11, 2017 at 4:14 PM
    csuviper
    Broomfield, CO
    Hattori and CM-LENNY like this.
  9. Apr 11, 2017 at 6:23 PM
    Theyfzman
    Pa
    08 TRD
    Thanks Brian
    I think that's the route I will, go the OME's
    Couldn't I use my toytec shackles and just set them on the lowest setting ?
  10. Apr 11, 2017 at 8:25 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    OEM with Icon AAL is my vote
    MIM likes this.
  11. Apr 11, 2017 at 8:49 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    @mtntop has alcans on his 1st gen they look really good. @LOTSOFTOYS I think has alcans too. Both said they ride nice and smooth but can handle a lot. My leaves look like they are curved backwards from the axle back. Like the shackles just push the rear half of the spring down.
  12. Apr 11, 2017 at 8:58 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Do you have them on yours? Or another truck? I was looking at the roadmaster before I got the shackles, sway bar and bags. But I couldn't find anyone else that had any experience with them.
  13. Apr 11, 2017 at 9:51 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    Dakar or Deaver. :thumbsup:
  14. Apr 12, 2017 at 7:45 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I run Deaver on mine but that's not rated if you're adding excessive weight, they'll sag on ya. K37 btw.
  15. Apr 12, 2017 at 5:38 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Do you mind telling us where you found the RAS @ $300. Cheapest I found it was around $4-450. Nice kit though. Definitely looking into this. Thanks
  16. Apr 13, 2017 at 8:19 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Per coach's recommendation I have some drakars and +3shackles to go on my truck when I get a free afternoon. Replacing the lift block was my goal.
