I got rear ended
Discussion in 'General Tundra Discussion' started by l3LUEFALCON, Mar 30, 2018.
  1. Mar 30, 2018 at 8:14 PM
    l3LUEFALCON
    l3LUEFALCON [OP] RIG MECHANIC
    Josh
    North Houston Area
    2014 5.7 FFV MGM CM SR5 4WD TSS-OR AKA: MILDRED
    (DIY) CB Radio, Tool Box, ESP Under seat storage, Husky front/ Weather tech rear floor mats, (DIY) Console Safe (Bio-metric), 275/60/R20 Conti Terrain Contact, Magnaflow Exhaust, Katskin leather seat covers, LRA 46 gallon replacement fuel tank, TRD Pro shocks Front/Rear.
    So, I got rear ended. Luckily I had my trailer hitch attached. The truck that hit me, did so with his front passenger tow hook. It hit directly on my hitch. There was no panel damage or anything like that. With that being said, it did bend my whole bumper downwards. I looked at it and found that the brackets that attach the bumper to the frame were bent and you could see the bolt markings on the bracket to where the bracket fastened to the frame. It was like it shifted.
    So, I took it to the collision center and all they wanted to do was bend the bumper back up and replace the hitch. I just find that crazy. From what I understand those brackets are rated for a certain load. If it is overloaded by a force, the metal will bend. You have just exceeded the safe working load... right? Shouldn't the brackets and fasteners be replaced for safety reasons?
    ColoradoTJ likes this.
  2. Mar 31, 2018 at 7:06 AM
    l3LUEFALCON
    Josh
    North Houston Area
  3. Mar 31, 2018 at 7:11 AM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Sorry man, can’t help you but hopefully someone with knowledge will chime in.
  4. Mar 31, 2018 at 7:35 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I'm not a metallurgist but your concern makes sense to a layman like me. Also find it interesting they're willing to replace the receiver hitch but not the bumper brackets. I guess the receiver hitch is expected to experience heavy tow forces while the bumper and its brackets are expected to experience the occasional weight of a human using it as a step. Maybe that's why?
    Sunnier, ColoradoTJ and DalTee like this.
  5. Mar 31, 2018 at 7:37 AM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    Just demand new brackets. I’d climb under there and look real close for ripples/ bends in the frame from the back to in front of the rear wheels. Check for pinched wiring, bent/kinked fuel/brake lines...
    ColoradoTJ and NewImprovedRon like this.
  6. Mar 31, 2018 at 8:10 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    My concern would be the bracket(s) that hold the hitch here:
    https://youtu.be/myn4Nio-dj0?t=9m47s
    If they're warped in any way, it might not pull straight, you might get uneven tire wear and uneven stress on components after towing over time, etc.
    I'd demand a proper fix as it's not just cosmetic, mention you plan to tow heavy, safety etc.
    Sunnier likes this.
  7. Mar 31, 2018 at 8:19 AM
    15whtrd
    15whtrd Mr. Blonde
    These are my feelings also.
    Im in the @RowdyRon fan club. Which also means I’m a @SouthBoundSteve loyal follower.
    Sunnier and NewImprovedRon like this.
  8. Mar 31, 2018 at 8:24 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I would ask for a replacement. How it behaves depends on the type of metal it is. Most metal actually gets stronger after it is plastically deformed - it work hardens (up to a point - if you go beyond the ultimate strength it will just fail). However, this comes at the price of losing ductility.
    Again, it really depends on what flavor of metal it is. Regardless, I would ask for replacement.
  9. Mar 31, 2018 at 8:33 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  10. May 3, 2018 at 6:33 PM
    texascolt45
    texascolt45 New Member
    mike
    future
    none
    if you had the ball in and it pushed the bumper down it probably kinked the frame.have it checked close.
    equin and ColoradoTJ like this.
  11. May 3, 2018 at 6:47 PM
    LML 3500HD
    I would go to a different body shop.
    Moon Puppy and Sunnier like this.
  12. May 17, 2018 at 10:40 PM
    l3LUEFALCON
    Josh
    North Houston Area
    Just to give everyone an update. They replaced the brackets with new ones.
    equin and Sunnier like this.
  13. May 18, 2018 at 5:54 AM
    Vizsla
    Vizsla ☠️☠️☠️
    I know a lot of people think having a hitch in the receiver provides more protection. It does not, just provides a lever to bend your hitch, bumper, and worse your frame.
    alyosha01 and BlueBottle like this.
  14. May 18, 2018 at 7:29 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    NewImprovedRon and jewsNbrews like this.
  15. Nov 22, 2018 at 11:11 AM
    alyosha01
    alyosha01 New Member
    completely agree. That hitch receiver sitting so low is a powerful lever. I just got rear ended, and the frame got bent... at least 5k in repairs, it seems.
    equin likes this.
  16. Nov 22, 2018 at 11:33 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    ^ ouch, hope repair goes well
    I've since installed a Putco blade, bright day or night when brake applied. I left my recovery hitch on, people are less likely to bump me when parking.
    equin, NewImprovedRon and alyosha01 like this.
