I got my passenger cats cut off. Will these work?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erick, May 16, 2022.
  1. May 16, 2022 at 9:11 AM
    Erick
    Erick [OP] New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
  2. May 16, 2022 at 9:24 AM
    These trucks DO NOT like aftermarket cats. They will throw a CEL.
    ColoradoTJ and Rocko9999 like this.
  3. May 16, 2022 at 9:28 AM
    Rocko9999
    Rocko9999 New Member
    2 options. Only option for no CEL is OEM. Second option is if you live in a state without inspections, go aftermarket and live with CEL. Your insurance will cover cat theft.
  4. May 16, 2022 at 9:44 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Magnaflow is the best option from what I've read but yes they can also throw codes. Use a Denso sensor and cross your fingers. At the least you'll be able to drive your truck and not have it sit on a dealer's lot for 3-6 mos.
    reywcms likes this.
  5. May 16, 2022 at 9:45 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Option 3, go catless and liberate yourself from the stress of cat shields and cat thieves :headbang:
  6. May 16, 2022 at 9:47 AM
    Then the Fkrs would hit the gas tank. I hate thieves.
  7. May 16, 2022 at 9:50 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    My 38gal is still intact :fingerscrossed:
  8. May 16, 2022 at 11:55 AM
    showtime240
    showtime240 New Member
    You can always just go LT Headers, custom midpipes with after market cats, and eliminate the rear cats.
    Then get a tune to eliminate the CEL.
  9. May 16, 2022 at 12:05 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You said it. If you're gonna do headers then kill the cats altogether. Avoid the future potential for cat theft. There are guys getting hit 2 or 3 times on the same vehicle.
    showtime240[QUOTED] likes this.
  10. May 16, 2022 at 1:55 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Go to walker exhaust and type in your year and vehicle make and find out which cat will work for your state, or call them up. Replace oxygen sensor with Denso pen type. Really pretty simple except for paying for it. Mine were stolen in 2018 and I live in California , the toughest smog state. I did it myself for around $600
    showtime240 and texasrho83 like this.
  11. Oct 9, 2022 at 2:46 PM
    Big_Ed
    Big_Ed New Member
    Spring, Tx
    2016 Tundra
    So, an aftermarket cat with this type of O2 sensor wont throw a check engine light? What does 'pen type' mean?
  12. Oct 9, 2022 at 4:16 PM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    Make sure you buy cats that will pass smog form your state or you will never pass smog
