I got my NSV LED hood bulge in today!
Discussion in 'Lighting' started by 1UPPER, Feb 28, 2017.
  1. Jun 4, 2018 at 8:08 AM
    #241
    tinyt1553
    tinyt1553 New Member
    Tom
    Cypress, TX
    2017 1794 CM - Magnetic Gray
    Exterior: POP & Lock Power Tailgate lock BakFlip MX4 Tonneau Cover Rhino Bed Liner Swapped OEM Halogen Fogs with Formula-J87 LED 6000k bulbs Rough Country 60" Tailgate LED lightbar 6" rubber stub antenna Interior: Front Emblem Camera with anytime backup cam, Crux Vimty-05 for Vehicle in Motion Override Center console wireless charging Verizon Hotspot in center console Chromecast to OEM head-unit display ESP Rear Seat 3 Compartment Storage 5% Ceramic tint on rear window and rear doors 18% Ceramic tint on front doors Weathertech rear seat cover (try to take Hank (boxer/pointer mix) with me everywhere I can) In The Works: Upgrade to 2018 OEM LED Headlights VLEDs throughout the rear (turns, brakes, highmount 3rd brake and cargo) GRT Lighting LED's to replace all interior bulbs Future Wishlist: Swap OEM Head-unit with Kenwood DNX994S and use iDataLink Maestro RR to integrate OEM backup cam, OEM USBs, OEM Aux input, etc AMP-Research Power Sidesteps Train (air) horn
    Dpedending on how long you've had it installed and due to heat, you might notice that it takes a couple days to reshape. Park it in the direct sun for awhile if the gap is still there.
    mtTundra[QUOTED] likes this.
  2. Jun 4, 2018 at 9:13 AM
    #242
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    What plastic supports? Pics?
  3. Jun 5, 2018 at 10:20 AM
    #243
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    This shows how much higher the drivers side is. I took it out to remove the plastic supports on each side (did not eliminate the gap for me) Tried to adjust height but no luck.
  4. Jun 5, 2018 at 12:31 PM
    #244
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    @tinyt1553 what plastic supports did you remove? Do you have pics?
  5. Jun 10, 2018 at 8:22 AM
    #245
    tinyt1553
    Tom
    Cypress, TX
    I don't have pics. but here's the youtube link that will take you to the point in the install video that shows them to you. There are 4, remove the one on each side that is closest to the outside ends of the hood bulge. https://youtu.be/cuMsVpeOMdA?t=4m30s
  6. Jun 10, 2018 at 8:25 AM
    #246
    tinyt1553
    Tom
    Cypress, TX
    Man mine took about a week, parked in the sun to reshape back to the hood right. I never could get my driver side to level with the passenger side (it's annoying as F*@&)
  7. Jun 27, 2018 at 5:01 AM
    #247
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    Any specials for 4th of July on this light bar. Thinking I want one!
  8. Aug 7, 2018 at 1:39 AM
    #248
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    Anyone know how many kelvin the light bar is ? 5K? 6K?
  9. Aug 9, 2018 at 3:56 PM
    #249
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    No idea but it’s the same as morimoto bx fogs and 2018 led headlights. 76E8AA6C-1BC4-4493-B5C0-3D26024C89EC.jpg
  10. Aug 25, 2018 at 10:19 PM
    #250
    explore more
    explore more New Member
    2018 Tundra
    Has anyone figured out a way to wire it so it works with a simple on/off seitch, and doesn't require the high beams to be on?
    I just received mine. I dont have a use for the swipe feature or the drl. I just want the on/off switch to work regardless of high beams. I also dont want to tie the t taps onto my drls. I want to leave my stock headlight qir3ong 100% stock.
    Ive taken apart the loom and documented what everythong does. Ill be attempting to figure out a way to make it work without the hi beams. Any pointers would be great.
  11. Aug 26, 2018 at 6:30 AM
    #251
    1UPPER
    1UPPER [OP] Not A New Member
    TEXAS
    Flux capacitor!
    Mine has done the same thing since I’ve had mine. It drives me nuts! Maybe I’ll see if I can find a way to adjust it.
  12. Aug 26, 2018 at 7:04 AM
    #252
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Have you tried contacting Headlight Revolution?
  13. Aug 26, 2018 at 10:11 AM
    #253
    1UPPER
    TEXAS
    Flux capacitor!
    I bought mine direct from NSV. I called them and they recommended to check the screws to make sure one is tighter on one side versus the other. I haven’t even messed with it since. When I cool down below 70 degrees I’ll try and adjust it.
    Sas[QUOTED] likes this.
  14. Aug 26, 2018 at 10:27 AM
    #254
    Sas
    OKC, OK
    May have to try this because mine does it too. With all of us having the same issue I'm doubtful this will fix it. I'm pretty particular about installation and it was like that in both the chrome and paint-matched hood bulge.
    1UPPER[QUOTED][OP] likes this.
  15. Sep 24, 2018 at 5:40 PM
    #255
    dolfandon
    dolfandon New Member
    2016 Double Cab Limited
    So I see a few of you had to move pins in the connectors. How the hell did you get them out? Is there an extraction tool I can get to remove the pins? Specifically it's the 8 PIN one that comes through the firewall. I need to swap pin 1 and 2 but can't get the pin out to move it.
  16. Sep 24, 2018 at 6:28 PM
    #256
    Sas
    OKC, OK
    You have to remove the white, plastic piece from the plug end of the pins first, then you can use a de-pin tool or small, straight pick tool on the back of them to get them out. Put it in on the underside of the back of the pin and push down gently while pulling a little on the pin. It'll come right out. It may take a few tries to find the sweet spot at first, but once you get a feel for it they are pretty easy.
  17. Sep 28, 2018 at 7:50 AM
    #257
    explore more
    2018 Tundra
    I'm absolutely loving my nsv lightbar. I got mine from headlight revolution. Their install videos are fantastic.
    I didnt want to t-tap into my factory headlights or to require them to only work when high beams were on, so i wired mine to just be a simple on/off operation. I dont have strobe, swipe, drl, or any flashing when i lock/unlock my truck. My light bar is either on, or off, regardless of high beams. Ill be posting a video of my install soon.
  18. Sep 29, 2018 at 8:35 PM
    #258
    Shap66
    Shap66 New Member
    kendall
    2018 Platinum Crewmax
    Just purchased a new 2018 Platinum this week and am new to the forum. Lots of new mods on the to do list. Will likely buy the NSV hood light bar but am wondering is anyone has swapped out the red switches or knows who is the manufacturer of the switches. Love the clean look of the NSV panel but would like to have black switches that match the Tundra interior. Thanks!!
    What other must have mods do I 'need"? :)
  19. Sep 29, 2018 at 9:00 PM
    #259
    1UPPER
    TEXAS
    Flux capacitor!
    Welcome to the forum. The switch for the NSV are made by NSV. The switches have a cover plate that has a hinge on top. So you can flip the cover plate down to cover the switches from being pushed. You can easily spray the covers over the switches black or spray them with plasti-dip.
    Photo with switch covers down.
    Photo with switch covers up.
  20. Sep 29, 2018 at 9:13 PM
    #260
    Shap66
    Shap66 New Member
    kendall
    Thanks so much for the quick reply. Are the covers removable to make painting easier? The other switches you have in the picture are custom printed right?
  21. Sep 30, 2018 at 5:33 AM
    #261
    1UPPER
    TEXAS
    Flux capacitor!
    I’m not sure how easy or if you can remove the switch covers. I would just mask off the main switches and paint the covers before you install it in the truck. Yes my other switches are custom done. You can order them from otrattw.com
  22. Sep 30, 2018 at 8:38 AM
    #262
    1UPPER
    TEXAS
    Flux capacitor!
    Looks great! Which backlit Toyota logo did you use? It looks very clean.
  23. Sep 30, 2018 at 2:54 PM
    #263
    explore more
    2018 Tundra
    I recommend headlight revolution's interior led kit, as well as led headlight bulbs, reverse lights, and cargo lights. Those mad e a juge difference to my truck.
    DaddyPete likes this.
  24. Oct 17, 2018 at 5:03 AM
    #264
    jmav91
    jmav91 New Member
    SE Texas
    2015 metallic grey TSS off-road 5.7
    Bull bar and running boards
    I acquired my 2015 tundra in June of this year and it came with a light bar and it was hard wired with my low beams, until today I’ve not been told anything as it is just accent like LEDs in the daytime running lights the officer told me it was illegal. Does your bar run when your headlights are on ? Also lol sorry an off topic post within another post I just didn’t know if people would understand my post haha
  25. Jan 13, 2019 at 12:44 PM
    #265
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Anyone know how to install the light bar to work with a switch pros?
  26. Apr 6, 2019 at 11:39 PM
    #266
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    Lookn at the (date posted) it’s about years now, so how’s it holding up?
  27. Apr 7, 2019 at 12:55 AM
    #267
    RoninPro
    RoninPro Abecedarian BASTRD
    East Bay
    17 CM TRD Pro
    I contacted Headlight Revolution if they had instructions on how to connect with a SP. They didn’t and referred me to this forum. Funny thing is before buying the bar i asked them if it worked with the SP and they said it did.
  28. Apr 7, 2019 at 4:35 AM
    #268
    1UPPER
    TEXAS
    Flux capacitor!
    It’s done great! I’ve had no issues with the light bar. It’s still my favorite light bar for light output. ED1BD0EA-EDB4-417A-ADEF-DD6BFBE05EB0.jpg
    hi_rawb[QUOTED] and Toyotoholic like this.
  29. Apr 7, 2019 at 4:42 AM
    #269
    1UPPER
    TEXAS
    Flux capacitor!
    I’m sure you can wire it to the switch pro. My first thoughts is you will need to take the main lead connections that typically get crimped onto the high beam wire and drl wire and run them to a constant power or accessory power lead. Then your wires that are currently going to your switches will need to go to the switch pro connection block in the engine Bay Area. Have you called Switch Pro yet?
    I have an sPOD unit and they explained how I could wire my Adapt 50” directly into the switch if I wanted to. So I’m sure there is a way.
  30. Apr 8, 2019 at 8:17 AM
    #270
    RoninPro
    East Bay
    17 CM TRD Pro
    Yes, it would have required cutting the harness and using the attached switches was easier, so I went that route for now. The swipe function is more of a cool factor. The DRL & high's are useful.
