I got my NSV LED hood bulge in today!
Discussion in 'Lighting' started by 1UPPER, Feb 28, 2017.
  1. Apr 8, 2019 at 12:12 PM
    #271
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I'm at a little bit of a x-roads.
    I have installed my nsv and love it. I had a little gap and I believe it to be the connecting brackets between the inner and outer bodies of the nsv bar itself. I haven't tried adjusting it because the Gap is minimal and doesn't really draw my OCD to a boil so I'm focusing on wiring.
    My goal is to have individual control over all lights at all times. Plus the ability to combine multiple lights simultaneously with a single trigger. I also have a 40" stealth bar and backlight Pro letters. So say a high beam pulse will turn EVERY light on if the combining control is engaged. I believe the Switch Pro is programmable in this manner but only has positive output switch legs which just means more relays to invert polarity for the negative trigger switch outputs of the NSV. I would like the nsv to function as normal as possible without loss of drl and swipe with lock/unlock.
    I have a good handle on how to wire this (I think lol) but haven't dove into it yet. Still looking for the simplest solution, and I think it is in the NSV harness. I wonder does anyone have the wiring schematic for the NSV with all pins identified at the steering column connectors.
    Any ideas?
  2. Jul 30, 2019 at 9:29 PM
    #272
    explore more
    explore more New Member
    2018 Tundra
    Thanks to the help of some people in this forum, I have been able to wire it without requiring the lights to be on. I didn't have to t-tap into any factory wiring, apart from the 12v cigarette lighter. Hopefully this helps someone.
    https://www.youtube.com/watch?v=dUawgO1g1vY
