i-Force Badge potential issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jengel451, Jan 29, 2019.
  1. Jan 29, 2019 at 10:22 AM
    Jengel451
    Jengel451 [OP] Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    just a simple PSA.
    This week I decided it was time to swap the chrome emblems to black. As I pulled the chrome 5.7 iForce badges off, a bunch of water came out from underneath both of them. I hadn't been in a car wash or rain in some time. After I removed all the adhesive what I was left with was a spot of discolored paint, not the entire area, but just a 1x2 inch area on one, and a bit larger on the other door . I decided to buff it out and let it sit for a bit and see what happened, sure enough after 24 hours the spots disappeared.
    Just something you all should keep an eye on. The way they put the emblem on is leaving a big bubble under the adhesive that is catching water and holding it there. The fact that the paint was discolored says that it's absorbing it. In time, I think it would've started to rust under the paint.
  2. Jan 29, 2019 at 10:30 AM
    15whtrd
    15whtrd Mr. Blonde
    When installing the new badges make sure there is a void in the bottom of the 3M tape along the bottom edge of the badge. Makes me want to go and poke a hole in the bottom of my 3M tape on the badge to see if I can get water to drain out.
    Mnorris1206 and NewImprovedRon like this.
  3. Jan 29, 2019 at 10:33 AM
    Jengel451
    The Bitterroot, MT
    I just decided to not replace that badge. Looks cleaner without it.
    Even if you do poke a hole you'd have to get up about half way, that's about where the bubble stopped.
  4. Jan 29, 2019 at 11:29 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 Gasser
    Thanks for the heads-up. I just ordered black badges and will be swapping once Roman gets them to me.
  5. Jan 29, 2019 at 11:39 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I decided to take of these badges. I sprayed them with Plasti Dip back in June but I think it's looks better without them. I also had a bunch of water come out on the passenger side. Under the badge, there were three chips in the paint and an unusual rectangle spot in the paint the length of the badge where the adhesive was.
  6. Jan 29, 2019 at 11:42 AM
    15whtrd
    15whtrd Mr. Blonde
    Sure it works out great for guys that like to remove badges, because of the 3M tape makes it easy. But remember when a badge wasn’t a piece of shit held on by a sticker? It actually had locating tabs.
  7. Jan 29, 2019 at 11:54 AM
    Jengel451
    The Bitterroot, MT
    Ah yes, an evening of spot welding bullet holes all the way down the side of car.....
    15whtrd[QUOTED] likes this.
  8. Jan 29, 2019 at 11:55 AM
    15whtrd
    15whtrd Mr. Blonde
    :rofl:Exactly! Quality shit! But a huge pain in the ass if you didn’t want your badges.
  9. Jan 29, 2019 at 11:59 AM
    Mnorris1206
    08 tundra
    Thats exactly what I did with my new badges.
  10. Oct 9, 2019 at 9:22 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Hmmmmm, that's good info. I always figured it would cause rust and we had rust on an old Mazda Protégé 5 under the emblem.
    Why is it trucks feel the need to put badges all over the sides? You rarely if ever see them on cars, vans and suv. Low end, mid range or high end, they are all pretty clean on the sides.
  11. Oct 9, 2019 at 11:14 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Meanwhile, in the Deep South.....
    57a33111-d83e-4577-be5f-428a153f23b5-ori_40b8951921b75e0038306f99099a65ccf04b0529.jpg
    15whtrd, CementGen3 and GODZILLA like this.
  12. Oct 9, 2019 at 11:54 AM
    gratefuljed
    gratefuljed New Member
    john
    Land of Enchantment
    2019 TUNDRA SR5 LB
    Holes, ah yes! On my super white f350 back in the day I stuck a reflector over one and plugged the rest with those black rubber plugs. In Mexico they took it for a military vehicle without all the frikkin badges!
    I found no water or discoloration under my 19 tundra but they were off in pretty short order lol
  13. Oct 9, 2019 at 4:53 PM
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    Well crap. I just plastidipped mine this past weekend. Guess it it time to remove them. Hopefully there is no damage underneath. :fingerscrossed:
  14. Oct 9, 2019 at 5:03 PM
    Niceguy
    Niceguy New Member
    19 Cement Limited
    I was looking for justification to get rid of those ugly I-force badges. With only 900 miles on my truck, sounds like the perfect excuse to do it now. Thanks
