I flooded the tundra
Discussion in 'General Tundra Discussion' started by pgilparra, Jan 18, 2021.
  1. Jan 18, 2021 at 5:43 PM
    pgilparra
    pgilparra [OP] New Member
    so i got deep in a water pit and water got inside the cabin. now i hear water moving around under the carpet while im driving. its gotta be somewhere between the frame and the carpet. How do I drain it out
  2. Jan 18, 2021 at 5:46 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Better have pictures! If you live where it’s dry enough just leave the windows or doors open for a bit. Maybe pull a rocker plug and see what drains out. If we have rocker plugs.
    JohnLakeman and Darkness like this.
  3. Jan 18, 2021 at 5:50 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Itll likely be in the channels under your door sills, they just pop right off
  4. Jan 18, 2021 at 5:55 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    Reg Cab Gang
    You need to pull the carpet up and look, you may need to completely remove it and let it dry out
    2mchfun, Txexplorer23 and Wynnded like this.
  5. Jan 18, 2021 at 5:58 PM
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    Going that deep, I hope you had a rear diff breather kit installed. If not, you might want to check your rear diff fluid.
  6. Jan 18, 2021 at 6:03 PM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    If you're gonna pull the carpet up, might as well buy some sound deadening mats and put them on the floorboard.
  7. Jan 18, 2021 at 6:19 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I got into some deep water today with my 19 Pro. Maybe a little over halfway up the tires for about 20 seconds. What are the odds I got water in?
  8. Jan 18, 2021 at 6:42 PM
    Wyoming
    Here's a pick of the rear diff breather port. It sits a bit above the rear axle, so if the water isn't over the axle isn't likely to get sucked in. For the short time and relatively shallow water you went through I would think you would be ok. If you are worried you can still check the fluid pretty easily, and if you plan to do similar activities you can get a rear diff breather relocation kit. Lots are available, and there are even DIY guides on the forum. Here's a DIY link that the pic came from. https://www.tundras.com/threads/diy-rear-differential-breather-mod.5253/
    WFD473 and YotaBro like this.
  9. Jan 19, 2021 at 6:34 AM
    pgilparra
    is there a drain under it? is definitely in the channels. i pulled the sills and saw the hole where the water got through . well... i womt be taking big girl through deep puddles anymore
  10. Jan 19, 2021 at 8:06 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Yeah, I thought that would be really short-sighted of Toyota to have no drains on the sill chambers. I just checked my 2017. If he has a Gen3, he has rocker plugs...like every 9 inches on the bottom of the sill.
    OP, you should pry out one of those plastic "caplugs" and see what drains out. If you've got water inside your rockers (sills), then you need to get it out. The interior steel is likely primed, and there might be some anti-rust treatment, but it definitely is not painted inside.
  11. Jan 19, 2021 at 8:07 AM
    T-Rex266 Moderator Staff Member
  12. Jan 19, 2021 at 9:12 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Zero
    GodlessPro likes this.
  13. Jan 19, 2021 at 1:35 PM
    pgilparra
    yea. that worked. thanks brother. she still needs a deep shampoo cleaning but at least got the water out
    JohnLakeman[QUOTED] likes this.
  14. Jan 19, 2021 at 1:43 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    How deep did you go and for how long? And did you figure out where the water got in? That's alot of water to get in for you to hear it swishing.
  15. Jan 20, 2021 at 6:35 PM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Always measure with stick before driving in water. Drove across a washed out low water crossing once and found myself nearly dead in the middle of a river. One nice truck with bent rod and a crankcase full of chocolate milk. Was a 93 Ranger xlt 4x4 rc
