I finally have one gripe about my truck
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra 2019 tss, Mar 10, 2020.
  1. Mar 10, 2020 at 5:22 AM
    Tundra 2019 tss
    Tundra 2019 tss [OP] New Member
    Jerry
    2019 tundra TSS
    okay I finally have one gripe about my truck. last night I had a friend that got stuck in the mud. I came out to help pull him out. I put the truck in four high and turned off all the safety stuff on my truck so I though. hooked up to him and started pulling him out. after about 30s of pulling my tires started to slip and low and behold my truck quite pulling like I lost any and all control of the engine and the ability to shift. would not go would not do anything. This happened three times. I needed to keep from getting stuck myself, so I unhooked from my friend and played with the controls on my truck. I had to turn it off to reset it. I restarted it and then turned off all TSS stuff and put it in gear got myself out. what little I did pull on my friends truck got him up out of the hole he was in but not unstuck. Being the good friend I put my truck in four low and hooked back up to him found that all my safety stuff turned off in four low. here is the problem in four low with the mud here. I could not get the mud to sling off the tires to be able to keep covering ground. so guess what happened I got stuck. fortuitously another friend was there and we had to use a com-along to get us both out. I understand why Toyota keeps the safety sensors active in four high but they need to make so that when you want to go off road you can turn it off.
    okay rant over
  2. Mar 10, 2020 at 6:07 AM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Agreed
  3. Mar 10, 2020 at 6:13 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    Can't you hold the traction control button below the AC for a few seconds to disable it and allow wheelspin?
    Tundyfundy and Boerseun like this.
  4. Mar 10, 2020 at 6:18 AM
    15whtrd
    15whtrd Mr. Blonde
    You can, but you need to do it twice. Hold it for three seconds and then you’ll see LSD and trac off. Then release and hold again for three seconds. But this doesn’t turn it completely off. Pretty close. Need to pull the fuse if you want no nannies.
  5. Mar 10, 2020 at 6:35 AM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    Where is the fuse located?
    Toyokuhl and Tundra 2019 tss[OP] like this.
  6. Mar 10, 2020 at 7:01 AM
    Tundra 2019 tss
    Jerry
    2019 tundra TSS
    for sure where is the fuse located for next time
  7. Mar 10, 2020 at 7:37 AM
    15whtrd
    15whtrd Mr. Blonde
    To be honest, I’ve only heard of people talking about it. Never really looked deep into it because I haven’t found a need for it yet. So I’m unsure if you would pull the ABS fuse or what. There is a fuse box under the hood and in the cab on the driver side. I would imagine it’s under the hood but also unsure if it’s going to throw codes.
    Tundyfundy likes this.
  8. Mar 10, 2020 at 8:54 AM
    Sunnier
    Sunny
    San Diego, CA
    @joonbug
  9. Mar 10, 2020 at 9:15 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    There’s a guy on here that makes a button that you can install and you can kill all nannies with a flip of a switch.
    Somebody help me out in that members name!
    SC_TRD and Jim LE 1301 like this.
  10. Mar 10, 2020 at 9:17 AM
    :popcorn:
    Must have missed that post.
  11. Mar 10, 2020 at 9:18 AM
    mttjdy
    mttjdy New Member
    Why I got a ‘17
  12. Mar 10, 2020 at 9:19 AM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    :popcorn: Definitely interested in knowing more in case I get into that o:poking: Moment
    Cpl_Punishment likes this.
  13. Mar 10, 2020 at 9:19 AM
    Tundyfundy
    Bay Area, CA
    Nothing changed with 2017. Still has all the nannies just no TSS. Or maybe it does have TSS. Point is it still needs the two button presses to shut off nannies.
    joonbug and plinyyounger like this.
  14. Mar 10, 2020 at 9:20 AM
    mttjdy
    mttjdy New Member
    Right. Didn’t want the TSS
    Tundyfundy[QUOTED] likes this.
  15. Mar 10, 2020 at 9:26 AM
    Tundyfundy
    Bay Area, CA
    https://www.tundras.com/threads/automatic-traction-control-disabler.20523/
    Here you go gents and ladies.
    As @15whtrd said, you can turn off nannies with two 3 second button pushes. Or you can get this but generally I don’t mind 6 seconds of operations every time I off-road in 4hi. I shut them off on the street for fun about once a month but like them on as I’ve felt them work in an emergency and they are amazing!
    Black Wolf, Sunnier and 15whtrd like this.
  16. Mar 10, 2020 at 11:50 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Pulling the ABS fuse won't do anything that turning off the nannies won't do, other than turn the ABS braking off. And you turn the nannies off with the Traction Control button. It has nothing to do with any of the TSS stuff. Even turning off all the nannies just doesn't help too much when your wheels are slipping because our trucks don't have a true LSD or locker. Here's a great thread by @KevinK . Everyone should read and understand this. Traction Control on our trucks are ridiculously complicated. Can't remember if Kevin talks about the Atrac on this thread, but if he does, read it. That maybe the only way to really get unstuck when your wheels are slipping.
    https://www.tundras.com/threads/traction-control-everything-you-want-to-know.21697/#post-515055
  17. Mar 10, 2020 at 12:55 PM
    Tundra 2019 tss
    Jerry
    2019 tundra TSS
    thanks for the info
    joonbug[QUOTED] likes this.
