I feel like I am sinning!
Discussion in 'New Member Introductions' started by JTP, Apr 26, 2017.
  1. Apr 26, 2017 at 8:13 PM
    JTP
    JTP [OP] The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    You will have to school me on what an SC is.
  2. Apr 26, 2017 at 8:15 PM
    Super Charger ..you'll need that or some gears with the 37's, Imo.
    CM-LENNY, Law323 and JTP[OP] like this.
  3. Apr 26, 2017 at 8:17 PM
    JTP
    The Big Black Moose
    Well the SC will have to wait. Im hunting / tracking down / researching what to do on the gears right now. Saw a post from another guy who said that the Tow Package 4.3's were fine. Will drive mine a bit to see what I get without then make a decision. Lots of very flat ground here in Texas.
  4. Apr 26, 2017 at 8:18 PM
  5. Apr 26, 2017 at 8:19 PM
    JTP
    The Big Black Moose
    :thumbsup: Thanks!
    T-Rex266[QUOTED] likes this.
  6. Apr 26, 2017 at 8:21 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Welcome to the dark side. I had an '06 Taco 6spd too, and an '83 and '84 4x4 pickup before that. Never thought I'd join the automatic crowd.
    Y0TA PR0 and JTP[OP] like this.
  7. Apr 26, 2017 at 8:24 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome to the forum.
    JTP[OP] likes this.
  8. Apr 26, 2017 at 8:24 PM
    JTP
    The Big Black Moose
    My left leg is not knowing how to handle this. It grabbed some break at a traffic light this afternoon a bit hard un intentionally.
  9. Apr 26, 2017 at 8:32 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Welcome to the forum! That's a great looking 2gen Tundra! I'm currently running 37s with the stock 4.30 gears. I'm changing my gears to 4.88 next month to help bring it back closer to the stock specs. Best of luck to you.
    JTP[OP], Law323 and zcarpenter92 like this.
  10. Apr 26, 2017 at 8:35 PM
    JTP
    The Big Black Moose
    :thumbsup: Can you give me the reasons why your going ahead with the 4:88's
  11. Apr 26, 2017 at 8:38 PM
    JTP
    The Big Black Moose
    I see that your also running the stock front bumper. Are you having any clearance issue with those 37's? I looked at mine and it looks like I might get into the bumper and the body mounts whith 37's
  12. Apr 26, 2017 at 8:45 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Lol this is my fist auto too. When I first got my tundra, my left foot was looking for the clutch when I turn it on lol.
    JTP[QUOTED][OP] likes this.
  13. Apr 26, 2017 at 8:47 PM
    JTP
    The Big Black Moose
    I keep reaching for the parking brake too when I shut mine off.
    Y0TA PR0[QUOTED] likes this.
  14. Apr 26, 2017 at 8:54 PM
    1UPPER
    TEXAS
    Flux capacitor!
    When you go with larger tires like 37s you loose exceleration and towing performance. By regearing the truck it will make the truck excelerate, tow and drive more like it's on the stock size tires. Another large advantage is it will help prolong your drivetrain since it won't have to work as hard to turn the oversized 37" tires. My front bumper has been cut and I also had the body mount cut and a welding plate installed to fill the cut. Fitting 37s will depend on your offset of your rims and the size of the lift. My particular setup was more challenging because my rims are a -51 offset.
    What size lift do you have? Do you know what your rims size and offset are?
    JTP[QUOTED][OP] and Law323 like this.
  15. Apr 26, 2017 at 9:06 PM
    JTP
    The Big Black Moose
    My lift is 7" and I am not sure on my offset. Looking at it with the current 325x60x20 Nittos and it looks like its going to be tight with the 37x12.5x20's. They are 1.4 taller and a bit narrower. I figured I would have to do something with the bumper and body mounts. My Taco was the same way when I stuffed big tires on it. Ive got a new front (and rear) bumper on the way and the 37's should clear it but I am pretty sure that I will have to get out the grinder on the body mounts.
  16. Apr 26, 2017 at 9:06 PM
    JTP
    The Big Black Moose
    What gear kit are you going with? Whats the cost and who/how are you going to get it installed?
  17. Apr 26, 2017 at 10:08 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Once you've gone BLACK (tundra) you never go back
  18. Apr 26, 2017 at 10:27 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Back in Black ...hit the sack..WELCOME from Oregon....Black Beauty !!!!...Best COLOR !!!!....Period !!!!...SWEET TRUCK BRO
    757TUNDRA, JTP[OP] and TheBeast like this.
  19. Apr 27, 2017 at 1:35 AM
    #49
    scurdyness
    scurdyness One thing is sure, uncertainty is certain
    William
    Fort Smith, AR
    2017 MBM Platinum_BlackOps
    TRD CAI, TRD Dual Exhaust, TRD rear sway bar, TRD shift knob, T-Rex Sport grilles upper and lower, full window tint and brow, de-chromed, powder coat OEM wheels, blue LED interior, Winjet Tails, Retrofit headlights
    Helloooo from AR and welcome
    JTP[OP] likes this.
  20. Apr 27, 2017 at 7:54 PM
    #50
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    100% agree with Sean. Dirty Deeds will fill your head with gearing and exhaust knowledge that your head will spin. Take it from me, I have 37's, and the truck and yourself will be thanking you for a re-gear. 4:88's are the only aftermarket gears at this time and you're looking around 2K-3K for front and rear installed.
    JTP[OP], 1UPPER and T-Rex266[QUOTED] like this.
  21. Apr 28, 2017 at 8:32 AM
    #51
    Bmedic50
    Bmedic50 New Member
    Brandon
    2017 TSS Crewmax
    Man you stole the thing! Well done. If you're looking for a cheap but extremely good looking mod, Search for blacked out badges. I think you would be really happy with it.
    JTP[OP] likes this.
  22. Apr 28, 2017 at 8:45 AM
    #52
    SlickRick2013Tundra
    SlickRick2013Tundra #10
    Rick
    Mandeville, LA
    13 TRD CM MGM 4x4
    Toytech Boss 3in Lift kit Iron Cross side step TRD Sway Bar TRD Cold Air Intake Blacked out Badges Blacked out front and rear bumpers
    Welcome from MO great looking tundra
    JTP[OP] likes this.
  23. Apr 28, 2017 at 9:25 AM
    #53
    B_brand
    B_brand New Member
    Brandon
    2017 White SR5 4WD DC
    NFab Steps, LEER Shell, BedRug
    Great looking truck! I just moved up to a Tundra as well. I've had 3 Tacomas before the Tundra!
    JTP[OP] likes this.
  24. Apr 28, 2017 at 9:28 AM
    #54
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    Welcome from Virginia! Sweet truck and great color. Black is making a comeback on here! :)
  25. Apr 28, 2017 at 9:31 AM
    #55
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Nice Find. Welcome!
    JTP[OP] likes this.
  26. Apr 28, 2017 at 1:00 PM
    #56
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    That feeling of abandoning your Taco will soon go away once you get used to the interior space and power of the Tundra. Especially when its one clean looking Tundra that you have!! Congrats and welcome!
    JTP[OP] likes this.
  27. Apr 28, 2017 at 2:03 PM
    #57
    3RsDad
    3RsDad New Member
    Roger
    17 Tundra TRD OR
    Welcome from Indy. She's a beauty! Got some bitchen trailer candy too:taco:
    JTP[OP] likes this.
  28. Apr 28, 2017 at 2:08 PM
    #58
    3RsDad
    3RsDad New Member
    Roger
    17 Tundra TRD OR
    I've always been a two footer because of sprint cars and midgets. Maybe give that a try
  29. Apr 29, 2017 at 2:09 PM
    #59
    JTP
    The Big Black Moose
    Got the 37"xIMG_0522.jpg IMG_0519.jpg 12.5x20's on today. FRONT END DOSE NOT RUB AT ALL. :)IMG_0518.jpg
    CM-LENNY likes this.
  30. Apr 29, 2017 at 2:12 PM
    #60
    JTP
    The Big Black Moose
    I was coming out of a convince store the other day and a lady passing by said "Nice looking Dodge Ram"
    :mad:
    So I ordered a Toyota Tundra badge, drilled and counter sunk it, and used stainless screws and nuts to mount it on the M1 Grill.
