I did it. Broke my oil filter housing
Discussion in '2nd Gen Tundras (2007-2013)' started by D4x4TRD, Feb 16, 2023.
  1. Feb 23, 2023 at 6:11 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
  2. Feb 23, 2023 at 6:21 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Jowett. Love mine.
  3. Feb 23, 2023 at 6:37 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
  4. Feb 23, 2023 at 6:53 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
  5. Mar 5, 2023 at 8:56 PM
    4x4WarriorOfRocks
    4x4WarriorOfRocks New Member
    2010 Tundra 4x4 Rock Warrior
    Hello I just wanted to chime in and ask something. I noticed a small oil leak and narrowed it down to the filter housing, so I got the Toyota brand aluminum oil filter housing, went in and removed the plastic housing, and I noticed an o-ring at the top where the filter meets the engine. Does anyone know if that's supposed to be there? Or did some tech mess up when I was getting oil changed at the dealership?
  6. Mar 5, 2023 at 9:49 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Yes, there is an O-ring on them. The problem is that sometimes it gets put in the wrong groove on the housing causing it to leak.
  7. Mar 6, 2023 at 7:51 AM
    4x4WarriorOfRocks
    Right I understand that part. The filters come with a large one for the housing threads, and a small one for the drain plug on the housing, but this one I noticed sits at the top on the engine side of things. (I'll try and get a picture uploaded today). I have never heard anyone mentioning this after a search across this forum and all the rest of the interwebs, so I am wondering if it supposed to be there or not? Thanks for the help!
  8. Mar 15, 2023 at 8:54 AM
    4x4WarriorOfRocks
    Well I switched to the Toyota aluminum housing, made sure all o-rings were oiled up and in the correct spots, and so far no more leaks! :thumbsup:
  9. Mar 24, 2023 at 1:37 PM
    Randy2013 Tundra SR5
    Randy2013 Tundra SR5 New Member
    Randy
    2013 Tundra SR5 double cab 5.7
    Front receiver, access door in skid plate but basically stock
    If you switch to the Toyota aluminum oil filter housing, which is basically the same housing used in different Toyota engines, just be sure to use the perforated inner tube from the plastic housing, or make sure that the inner pipe on the aluminum one is the same length as the one in the plastic housing one. The housing may be teh same but that perforated inner tube varies in length for different engines. That inner perforated pipe functions when the oil filter element becomes clogged---its a bypass but apparently only works if it is the correct length. It is held in place by 2 tabs and can be removed easily enough. There is a spring that also has to be placed under it.
    I also installed a Fumoto oil drain valve on my oil pan and it works well. I installed a front trailer receiver on my Tundra for accessories, which blocks the bolts for the skid plate, so I cut a hole in the metal skid plate but made my own cover for the hole which bolts in with 4 sheet metal bolts so I dont have to remove the front receiver when changing my oil.
  10. Mar 27, 2023 at 7:31 AM
    Randy
    PS dont remove the 2 tabs that hold the perforated pipe in place, just bend them gently and only enough to remove the one pipe and spring and then install the proper length pipe and spring and bend them back toto the position they were in originally.
    NewImprovedRon likes this.
  11. Mar 27, 2023 at 7:46 AM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    But is valve rated to 100 PSI?
    I can't imagine it failing, just saying it was intended for the pan where the pressure is just a few pounds and I'd hate to see someone lose an engine/crash over this.
    As you were...
  12. Mar 27, 2023 at 9:13 AM
    KeepOnTruckin
    Randy
  13. Mar 27, 2023 at 9:30 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Having held one of these in my hands / soon to install it, I can tell you the valve's gonna have no trouble with 100psi continuously. Nice stainless steel top-entry swing full-port ball valve.
  14. Mar 31, 2023 at 10:56 PM
    Sierramare’
    Sierramare’ New Member
    Ted
    Alaska
    2007 SR5 DC 4wd
