I despise the Oil filter choice
Discussion in 'General Tundra Discussion' started by kenomouth64, Sep 9, 2017.
  1. Sep 9, 2017 at 10:33 PM
    kenomouth64
    kenomouth64 [OP] New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Does anyone have any recommendations for how to make the job of changing oil, less 'annoying'.
    To start with, I despise the plastic oil filter housing... this is the 4th time I have changed the oil on it and it drives me insane. Why could we have not just gone with a spin-on oil filter? It makes me wonder if there are any aftermarket solutions for this terrible engineering (in my opinion). Perhaps there is a conversion kit which would allow someone to use a spin-on oil filter, that would be AMAZING.
    Then the skid plate... it is a nightmare to try and get it back on, I ground those hooks off, I wanted to smash them after that but did not have time. I am thinking about cutting an access port, has anyone done this with it working?
    Now for my rant...
    A job that should take 30 minutes took 5.5 Hours, WHY?
    To begin with, three of the five bolts holding the skip plate on rusted out, then stripped the threads. I had to drill out the holes and go up to a larger size, after getting "the little boogers out". My drill bit also snapped inside one of the holes, so that was a 45 minute ordeal. Finally I got the damn skid plate off and prepared the holes for larger bolts, that hopefully will not rust...
    Then I notice the oil pan gasket is leaking again, Fuck my life, I thought I fixed that last time, I ended up not messing with it (looked like it leaked 1-2 oz per oil change).
    Then I move on to the "true nightmare", the oil filter housing, so many tears... I will not go through the whole spiel, I will just say at one point, I was considering chiseling out the entire plastic housing, then buying a new one at the dealer Monday. However what saved me were shop towels ( I swear I come up with so many uses for these!). I layered 4 shop towels inside of the oil filter housing removal tool, then used a mallet to seat the tool on the housing tightly. WOOLAH, it came off.
    Then while trying to get the tool off of the housing, I break the "spindle and associated components" out of the inside of the housing. I spent a good our getting everything bent and put back into place correctly.
    Then it was cake from there on, until it came to putting the damn skid plate back on, this took way too long, AS USAUL.
    Nevertheless, I completed the job and added a new engineer or engineering team to my shit list. Seriously is there a good reason why they did some of this, that I am not aware of?
  2. Sep 9, 2017 at 10:43 PM
    TRD Pro skid plate would help you out big time.
    I don't know of any cartridge filter bypass kits. I never had an issue changing out my oil and removing the skid plate. The hooks you cut off help out a bit. Hook them in, install rear bolts and then do the fronts.
    15whtrd likes this.
  3. Sep 9, 2017 at 10:56 PM
    Yikes! No bueno hope it gets better for you
    4x4_Angel likes this.
  4. Sep 10, 2017 at 3:21 AM
    Whocares
    Whocares Member
    Rci also offers a skid plate with access to the oil filter via 2 Allen bolts. Install a fumuto oil drain valve and your concerns should be limited.
    Backslider likes this.
  5. Sep 10, 2017 at 5:51 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I feel your pain @kenomouth64 , which is why I haven't even tried it myself, yet. With my previous vehicles (except one commuter car) I was sure to do each oil change myself. After hearing what a pain it is with our trucks I have decided I'm OK with paying the dealer to do it until I can get a different skid plate with an access door.
    I plan on scooping up a TRD Pro skid or an RCI skid, as they both have an access door, however they are pricey new and I haven't found any used locally, and probably never will. I did see that someone made their own access door on the stock skid. It didn't look to pretty but it definitely got the job done.
    Also do you recommend we replace the skid plate bolts with SS bolts to prevent any rust issues?
  6. Sep 10, 2017 at 7:17 AM
    Stig
    Stig New Member
    How long since the last oil change? Did you buy brand new. I just find it odd that the Skid pan bolts would seize when it's something you should remove for oil change at least twice per year.
    You can replace the plastic filter cartridge with a metal one, but I've never had a problem. Actually with the right tools, this is the easiest oil change I've done on any vehicle. I can drain the oil directly into a container without a drop on the floor.
    Ericsopa and Bprose like this.
  7. Sep 10, 2017 at 7:29 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I'm sort of liking it too. Just did the wife's Camry yesterday. It's the same sort if cartridge, just a little shorter. I get the filters off Amazon, buy about 3 at a time.
    Op, what part of country do you live in? You might try putting a little anti-seize on the bolts.
  8. Sep 10, 2017 at 7:33 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    You can always leave the skid plate off if its a issue.
  9. Sep 10, 2017 at 8:12 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I stopped doing my own oil changes once it became a PITA like this and the hassle of dealing with recycling the used oil. Something to be said about doing your own maintenance, but it this case, more cost/time effective for me to just have the dealer do it.
    Black Wolf and BOBONTUESDAY like this.
  10. Sep 10, 2017 at 8:32 AM
    willrun4fun
    willrun4fun New Member
    2000 Limited 4wd
    Oil change takes like 10 minutes on my 2000. Easy spin on filter that you can reach from under the hood no issues.
    Plastic housing? Is it similar to the aluminum spin on canister my 2007 RAV4 3.5L has but plastic?
  11. Sep 10, 2017 at 10:54 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Yeah our trucks come with plastic oil filter canisters. I replaced mine with the aluminum one on the first oil change. Just bought an aluminum one for my wife's Camry after cracking the plastic one during the last oil change. Dealer had that thing on there so tight it wouldn't budge. Ended up having it towed to them. $240 oil change... I was pissed.
    Sefferston likes this.
  12. Sep 10, 2017 at 1:05 PM
    Stig
    Stig New Member
    And that is why I will never let a dealer change my oil. My wife's Lexus was purchased as a CPO vehicle, so not brand new. The first oil change I did on it was a messy one because I couldn't use the drain tool for the filter since the dealer tightened the filter drain plug cap so tight that the whole filter assembly just spun with it. It was so tight in fact, that I couldn't even get the drain cap loose after putting the canister in a vise and cranking with a cheater bar. That thing is supposed to be installed at a pretty low torque.
    Many other reasons not to let the dealer do it too, like the big waste of time it takes. I let them rotate my tires once, made an appointment for the first of the day at 7:30am, got there on time, but they didn't touch my truck until 8:30 and it was not done until 9. When I first brought it, I asked when it would be ready and I was told 15 minutes!
    mdavis[QUOTED] likes this.
  13. Sep 10, 2017 at 1:17 PM
    hillbillytoyo
    hillbillytoyo Just a country boy
    Daniel
    WV
    21 Limited Cement CM TRD OF
    My truck is still new so I haven't changed my oil yet. But I have been checking out what tools I will need and looking at the process. I previously had an 08 Tacoma and the oil filter was right on top of the engine. My wife has a Volvo XC 90 and that's her filter is located on top as well. I really don't understand why some filters are in such a hard place to access.
  14. Sep 10, 2017 at 2:06 PM
    SailorRocco
    SailorRocco New Member
    New York
    2012 Mgm Tundra 5.7 TRD Off Road
    I cut a 6x6 hole in my skid plate, bought a metal cap and use the oil drain tool. It has made oil changes a lot easierIMG_3227.jpg
  15. Sep 10, 2017 at 2:10 PM
    mdavis
    Michael
    Rock Hill, SC
    Yeah it was so tight I ended up breaking the little tabs off that the tool fits around. Had to use a cheater bar to manage that. But when they broke off they cracked the housing as well and was leaking oil like crazy so I couldn't even drive it to the dealer, had to have it towed. I have no idea how they got it off.
    kenomouth64[OP] likes this.
  16. Sep 10, 2017 at 2:48 PM
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    This. I did it on my last Tundra, and doing it on this one when it's time for oil change.
  17. Sep 10, 2017 at 5:00 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Damn, and I thought my first oil change went bad. I was planning on cutting an access door in my skid plate when I did mine. I was saved that step. I may add the RCI skidplate down the road.
    I totally agree with you on the oil filter housing design. There are way to many pieces in that little bit of engineering. Spin on oil filters for the win.
  18. Sep 12, 2017 at 1:42 PM
    crishard
    crishard Occasional Member
    Cris
    2014 Barcelona Red CM
    3" level in front, ICI Bumper & Skid, 12k lb winch, UCAs, Radtech 2.5s, Kenda 35s, Dual Batteries, 3500w inverter
  19. Sep 12, 2017 at 1:56 PM
  20. Sep 12, 2017 at 2:18 PM
    I always used to change my oil. Not anymore. I've owned my Tundra over 3 years now. My neighborhood Grease Monkey has been doing the oil changes during that time with never an issue. I know the owner. Good guy. They did my rear diff gear oil change last year. Going to have them do the front diff and T case in a couple of weeks. I supply fluids..
    ChucklesToy likes this.
  21. Sep 12, 2017 at 6:11 PM
    kenomouth64
    Tetrus
    Nice! It is difficult to find shops that will let you supply them with the parts/fluids. None of the shops around where I live will do it. They all want their markup on the price...
  22. Sep 12, 2017 at 6:20 PM
    kenomouth64
    Tetrus
  23. Sep 12, 2017 at 6:25 PM
    crishard
    Cris
    It's ************** where all the asterisks are. The forum won't let me paste it in without doing that to the link. Looks pretty slick. I'd pay $200 to never have to deal with those frickin cartridges again.
    warrlong and kenomouth64[OP] like this.
  24. Sep 12, 2017 at 6:26 PM
    crishard
    Cris
    ok. Lets try this: b p adapters dot com
  25. Sep 12, 2017 at 7:40 PM
    kenomouth64
    Tetrus
    Very nice find! I might invest in one of these... bookmarked the page. For those who just got here the link is listed below:
    http://www.shop.+++/Spin-On-Oil-Filter-Adapter_c2.htm - Remove the +++ symbols and replace with the following (do not include spaces): b p adapters .com
    warrlong likes this.
  26. Sep 13, 2017 at 5:12 AM
    crishard
    Cris
    A more expensive but much more convenient option would be these two gems. Relocates as well as converts to spin-on. With hoses it would be around $500 for the mod.
  27. Sep 13, 2017 at 10:03 AM
    Stig
    Stig New Member
    You're doing it wrong if you think the spin on kind is so much easier.
  28. Sep 13, 2017 at 10:26 AM
    15whtrd
    15whtrd Mr. Blonde
    The center plug got stuck on mine the last oil change. So taking out the first Plug it would try to and spin the entire filter housing. I took my 1/4" impact to it and I got it off without removing the entire housing with it.
  29. Nov 23, 2017 at 8:45 AM
    Ragecage92si
    Ragecage92si New Member
    Josh
    17 blue TRD
    7" BDS lift kit,3” body, King 2.0’s, Mammoth Guards, Custom powder coating, Nitro 5.29, D.A.P. Tuned, Coachbuilder shims, Coachbuilder Steering kit, Wether Tech vent visors, and hood protector, spray in bed liner, Bakflip, Fuel wheels, 38” TOYO tires, Bushwacker fender flares, Dirty deeds exhaust , TDK front bumper, Rigid light bar/floods/spots. Husky fronts, Weather Tech rears, ESP under seat storage, PowerX2 battery, Android Tesla unit, AJT chrome delete, Horn Blasters, Custom switch cluster, Interior leds, Revere leds, 19 pro headlights, Rocklights, Custom MAYHEM projector
    Anybody have a link to the aluminum oil filter housing?
  30. Nov 23, 2017 at 9:11 AM
    trainracer
    trainracer New Member
