I bought a 2010 Tundra 10/2/2010 because they are a towing tanks.
Discussion in 'General Tundra Discussion' started by MikeCook22, Oct 4, 2018.
  1. Oct 4, 2018 at 8:42 PM
    MikeCook22
    MikeCook22 [OP] New Member
    Toyota tundra SR5 4×4
    Factory 6 inch lift kit with 35s
    My 2010 tundra RS 5 has a 6 inch factory lift on 35s . I pulled a 32 foot 7500 lb travel trailer yesterday like it was nothing. The next day my 4Lo . Track light and my check engine light are coming on. This really pissed me off . Can someone help me with this problem , it doesn't effect the running of the truck that I can tell yet. What should I do. I love my truck.
  2. Oct 4, 2018 at 8:46 PM
    Welcome to the site Mike.
    I would get the code(s) read and start there.
    Your problem could be a few things. No reason to speculate.
  3. Oct 4, 2018 at 8:59 PM
    MikeCook22
    It started this morning when I started it,I drove about 8 miles to the parks store to get the codes read. I turned the truck off an went in, took about 3 minutes.to get the code reader. Came out an turned the truck on the the lights was off. Ran the truck on an off all day an late this evening they appeared this evening.
  4. Oct 4, 2018 at 9:58 PM
    Thee_Oddball
    Thee_Oddball New Member
    Eric
    Chicago
    2013 Double cab 4x4 5.7L, 78,000 miles, Nautical blue.
    did this happen after you unhooked the trailer? if so starting looking at the connection for the trailer brake and make sure it is not shorting out.
    Grumpy Uncle likes this.
  5. Oct 4, 2018 at 10:21 PM
    MikeCook22
    The break box was installed the day before, about 3 days ago.
  6. Oct 11, 2018 at 9:35 AM
    Giants3890
    Giants3890 New Member
    14 tundra
    I got same thing also looking for answers. I got code p0717 for turbine speed sensor
  7. Oct 11, 2018 at 2:10 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Go back and check the grounds and ensure they are good grounds and they are tight.
