I am Lost.. Cranks but won't start
Discussion in '2nd Gen Tundras (2007-2013)' started by namib, Mar 26, 2020.
  1. Mar 26, 2020 at 4:53 AM
    namib
    namib [OP] New Member
    David
    2007, 4.7 V8 Tundra, Double Cab Ltd
    Please , can anyone shed some light here. I've done timing belt w/ pump replacement, all went smooth, belt lines up on "I" marks, turned by hand a few times. Problem is, it cranks, but will NOT start at all, since I have no spark, none. Tested Crank sensor, it's good, where to from here? I have also checked every single fuse, in Engine Bay & inside cabin, drivers side??? I am in trouble here, need this truck to run. Thank you in advance guys....
    1rooster likes this.
  2. Mar 26, 2020 at 6:54 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome from Ontario Canada, I would retrace your steps and see if you inadvertently knocked a wire off or something . Was it running before you did the timing belt and water pump ?
  3. Mar 26, 2020 at 7:49 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    How do you know you have no spark ?
  4. Mar 26, 2020 at 12:02 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    and do you smell gas filling up in your piston? or coming out your exhaust when cranking?
  5. Mar 27, 2020 at 8:07 PM
    namib
    David
    Well, it was running 100% before we changed the belt, no issues at all. We pulled the plug on No1 piston, grounded it (connected to it's coil) and cranked it over, no spark at all.I can also hear the fuel pump running. The odd thing is that the "check engine" light does not come on at all when I switch it on. We connected a code reader to the truck, it could not connect to the ECU.
  6. Mar 27, 2020 at 8:30 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
  7. Mar 27, 2020 at 8:38 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
  8. Mar 27, 2020 at 8:39 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    Try those write ups keep us posted
  9. Mar 27, 2020 at 8:57 PM
    namib
    David
    Wow! Man, am I glad I signed up with you guys! Thank you very much eddie! I'm heading out to the truck early tomorrow, will take the day & work through all of this, it is much appreciated.! Feedback will be on here tomorrow night, please keep fingers crossed!
    Yodder J likes this.
  10. Mar 27, 2020 at 9:04 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    Cool man just keep us posted and I will try to help as much as I can
    GODZILLA likes this.
  11. Mar 29, 2020 at 6:37 AM
    namib
    David
    Well, here's my feedback on this thread. The problem got solved, in no time. We nicked the wiring going to the Cam Sensor. Even though we checked when re-assembling, there was a spot we didn’t see, so, fixed it, perfect, no issues, Tundra is purring like a lion! Thanks everyone for contributing, this is a great Forum!
    JimboSlice413, MS22, Kerch71 and 5 others like this.
  12. Mar 29, 2020 at 10:47 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    crazy something simple as that kills the truck with dozen of troubleshooting possibilities
  13. Mar 29, 2020 at 2:28 PM
    namib
    David
    Absolutely! What threw me off balance with this one was the 4L & 4H buzzer going off,warning light coming on, but no engine light coming on. Due to my lack of experience I figured it must be something pretty serious, 'cause everything seemed to be messed up. Just love this forum.!
    JimboSlice413 likes this.
