I’m concerned: popping noises coming from front driveer side
Discussion in 'Suspension' started by Eclipsed & Floating, Feb 22, 2018.
  1. Feb 23, 2018 at 9:18 AM
    #61
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Please keep me in the loop brotha!
  2. Feb 23, 2018 at 9:39 AM
    #62
    Eclipsed & Floating
    Eclipsed & Floating [OP] Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    I told them that if its not CV related and potentially suspension then not to touch it. If its suspension related then I’ll need to come visit you :D
  3. Feb 23, 2018 at 11:47 AM
    #63
    Eclipsed & Floating
    Voluptuous Whitey
    Welllllllllllll, it’s not quite the intense, but yeah. I prolly have a little more of a scenic and tough commute some days rather than most people’s heavy menstruation of rush hour
    TheBeast and Watt maker like this.
  4. Feb 24, 2018 at 4:41 PM
    #64
    Eclipsed & Floating
    Voluptuous Whitey
    Dealer couldn’t replicate and couldn’t find any obvious issues after lifting it up and diagnosing. I drove back down and couldn’t replicate it. Maybe temps decreased viscosity Somewhere and I’ll ty your recommendations. I’ll keep you posted tomorrow after I’ve lubed some joints
    ColoradoTJ[QUOTED] and TheBeast like this.
  5. Feb 24, 2018 at 4:57 PM
    #65
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Any other symptoms, apparitions, typing REDRUM over and over?
  6. Feb 24, 2018 at 4:59 PM
    #66
    Eclipsed & Floating
    Voluptuous Whitey
    Nope
    I’m not sure whether I should feel grateful, pissed, or like there’s “impending doom” like the book says
    831Tun[QUOTED] likes this.
  7. Feb 24, 2018 at 5:02 PM
    #67
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Lose the "impending doom" feeling. I think things will sort themselves out and boil down to something simple.
  8. Feb 24, 2018 at 5:10 PM
    #68
    Eclipsed & Floating
    Voluptuous Whitey
    You know me...as much as I don’t like to give credit to others for being right, I’m gonna concede defeat to everyone like @ColoradoTJ.....again :bowdown:
    I will also like to go on record saying that my suspension feels better in Denver (warmer temps)
  9. Feb 24, 2018 at 5:58 PM
    #69
    I’m wondering if something was lose and they just put a wrench on it?
    They may have lightly lubed the spring areas I discussed.
    Time will tell....
  10. Feb 24, 2018 at 6:01 PM
    #70
    Eclipsed & Floating
    Voluptuous Whitey
    I asked them to hit every bolt they saw
    We will see
  11. Feb 24, 2018 at 9:19 PM
    #71
    I hope it is nothing more than that. The Toytec system is a good setup.
    Like I said earlier, I have seen over the years coil over springs get pretty loud with some use. I try and lube my shocks up after every run to minimize rust/corrosion, dirt buildup.
    I pull my shocks out every other year, service them, and toss them back under the Jeep. Every year I test out the limit straps to ensure I’m stressing out the straps vs the shock. When running limiting straps, every 12” of strap will stretch ~1”. Coilover Shocks re awesome when dialed in, but boy are they some work to get there and maintain.
    I’m actually surprised more people aren’t running ORI Struts on their trucks.
  12. Feb 24, 2018 at 9:23 PM
    #72
    Eclipsed & Floating
    Voluptuous Whitey
    Good to hear. I suppose I just need to get under there and learn how to maintain them properly.
  13. Feb 24, 2018 at 9:27 PM
    #73
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    No external coils on those huh. Do they make specific for the Tundra?
  14. Feb 24, 2018 at 9:29 PM
    #74
    I know for the Tacoma they do. Now you have my mind wandering Brian. Let me check.
  15. Feb 24, 2018 at 9:37 PM
    #75
    Looks like the 8” or 10” ORI strut would work on the Tundra, depending on travel needs.
  16. Jun 26, 2018 at 1:18 AM
    #76
    Poseidon 762
    Poseidon 762 New Member
    2008 Toyota Tundra Crewmax
    6" Lift
    My 2008 Crewmax developed a popping noise from the front driver side shortly after installing Rough Country 6" lift. Strange thing is that the popping noise no longer occurs but now the brake pedal gently pops a few times while turning the steering wheel left. I can't see anything strange while the wheel is turning. I'm vexed.
