Hypothetical solid axle conversion
Discussion in 'Suspension' started by Hbjeff, Sep 11, 2019.
  1. Sep 11, 2019 at 8:49 PM
    Hbjeff
    Hbjeff [OP] New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I know how good our ifs system is, but this is just a hypothetical for my own knowledge, if one were to want to swap an SFA onto a gen 2 tundra, could all the brake components and abs sensors be retrofitted onto the new front axle to avoid messing with those systems?
    Mountun Goat likes this.
  2. Sep 11, 2019 at 9:20 PM
    coyote
    coyote New Member
    Which axle would you swap in?
  3. Sep 11, 2019 at 9:22 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I believe Wyatt from RST worked with Curry to make it possible.
  4. Sep 11, 2019 at 9:27 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    There's a couple of them out there. Lots of fab work from what I can tell. All the brackets can be fabbed with some basic fabrication tools, but I wonder how the tone ring is handled.
    Toyotoholic and Mountun Goat like this.
  5. Sep 11, 2019 at 9:29 PM
    coyote
    coyote New Member
    That top pictures is nuts... what the hell?
    Mountun Goat, Darkness and Pudge like this.
  6. Sep 11, 2019 at 9:31 PM
    GravityGear
    Aurora, CO
    There's also a dude with a SAS running the show circuit. All polished and powdercoated with brodozer wheels and stretched mud terrains, but I can't find a picture. Guess he's not doing to well in the show scene.
    Mountun Goat and Rica25 like this.
  7. Sep 11, 2019 at 9:32 PM
    cmack
    cmack New Member
    AZ
    2018 Burrito
    All depends on what axle you swap for the sake of brakes. As far as ABS, doubtful that you’ll easily retain it.
    I did a SFA conversion on a previous truck. Front axle was a dana44 out of a Jeep Grand wagoneer, and no I did not retain ABS. at the end of the day, the possibilities are endless though, it’s just a matter of how much $ you’re willing to pay
  8. Sep 11, 2019 at 9:37 PM
    GravityGear
    Aurora, CO
    I think this is dude. He went over his build somewhere and talked about brakes and other overlooked stuff like that, but I don't remember where. Might have been on TC. Also, thought his tires were more egregious than this.
    Mountun Goat, Hbjeff[OP] and Rica25 like this.
  9. Sep 11, 2019 at 9:41 PM
    GravityGear
    Aurora, CO
    Every time I look at that picture, it looks broken.
    Mountun Goat and Pudge like this.
  10. Sep 11, 2019 at 11:20 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Of course, it’s really simple, but eww, hell no. Ride in a LT Tundra, no need for SAS.
  11. Sep 12, 2019 at 5:45 AM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    Ive owned an LT truck so yes i know how amazing it is.
    Just an idea for something different. Not really looking to rock crawl, just an all around rig. I figure if i could add a divorced t-case then axle selection opens up being able to run driveshaft down either side
    Mountun Goat and Watt maker like this.
  12. Sep 16, 2019 at 7:09 PM
    BreyTundy
    BreyTundy New Member
    Andrew
    Colorado Springs
    2016 White DC TRD
    Look up califabrication on instagram. He's been slowly building a back halfed and solid axle swapped second gen Tundra. To say the thing is nuts is an understatement. The most recent post on it is from August third, with some periodic updates further back
  13. Sep 16, 2019 at 7:16 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Seriously, wtf is going on there
    1UPPER and Mountun Goat like this.
  14. Sep 16, 2019 at 7:37 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Like the front diff and axle out of a civic
    Pudge[QUOTED] and Watt maker like this.
  15. Sep 16, 2019 at 7:58 PM
    NR-J
    NR-J New Member
    Justin
    2015 white tundra
    If you are not specifically building it to rock crawl there’s no way I’d go SAS.
    Seems like a huge waste of money to make the truck ride worse on the street and forest roads.
    snivilous and Mountun Goat like this.
  16. Sep 16, 2019 at 7:59 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Interesting this one has 6 lugs.
    Darkness and Watt maker like this.
  17. Sep 16, 2019 at 8:00 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I think it’s badass. Different is the way to go imo.
    Kiddnapped Tundra and Vizsla like this.
  18. Sep 16, 2019 at 8:11 PM
    Vizsla
    Vizsla ☠️☠️☠️
    And it won’t rock crawl better due to loss of clearance. Used to be the SAS was better due to strength, not the case with our trucks. There is literally no scenario where the solid axle is not a giant leap backwards.
    Baja Mike and Mountun Goat like this.
  19. Sep 16, 2019 at 8:15 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Looks so good! This was one of the trucks used to drool over before I lifted mine :)
    Watt maker likes this.
  20. Sep 16, 2019 at 8:36 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
    AB6F8ADD-0C23-4CF3-B07A-284A9F2188FE.jpgI SAS’d a Toyota once. The older trucks are pretty easy. I never should have sold her. 18” lift on 38’s.
  21. Sep 16, 2019 at 8:42 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    I suppose some tone rings could be fabricated, but then almost everything to do the swap would have to be custom except the axle itself (even then, the brackets would have to be custom). The 5x150mm bolt pattern would add even more difficulties since you would have to deal with the rear axle still. I think that the most fun modifications would be what you have to do to the frame. If I wanted a solid front axle I would sell my truck and buy a F-250/350 or Ram 2500/3500.
  22. Sep 16, 2019 at 8:53 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I too wanted to know and found out.
    Currie Rock Jock 60's front and rear with 4.88 gears and lockers, 4-Link front with full Hydro Steering, 3.1 to 1 Atlas transfer case and a TRD supercharger
  23. Sep 16, 2019 at 9:02 PM
    computeruser6
    Dirk
    Escondido
    It's so tall that I wouldn't want to take that truck off-road. The only thing it's good for is a mud pit...
  24. Sep 16, 2019 at 9:06 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    True for most SAS I've seen, although ive seen some do well off road at low speed with high articulation.
  25. Sep 16, 2019 at 9:31 PM
    GravityGear
    Aurora, CO
    Not sure there are any 5x150 solid steer axles. I don't remember what the whole thing with that build is, so I'm not sure if a rear 6 lug conversion was done. Looking closely at the picture, it might have been.
    Mountun Goat[QUOTED] likes this.
  26. Sep 16, 2019 at 9:34 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Here’s somewhat of an article about it.
    https://tundraheadquarters.com/solid-front-axle-tundra/
  27. Sep 16, 2019 at 9:35 PM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    Of course everything is a custom fab job. Just one of those ideas. I figure if i ever were to spend say 15k on a simple old offroad jeep, why not instead spend 15k on the tundra doing some home fab with the neighbor. In all reality it might be too much of a headache to run without abs in a daily driver
    Looking into how the abs functions i agree it would be a nightmare to get abs to work with the sfa. Fabbing in the tone rings and hubs etc. the wheel pattern is one thing, i wonder if they sell adapters like they do for lots of other trucks. Same thing as wheel spacers lots of us already run. The falken truck runs dynatrack rear axle
    Solid axle isn’t for high speed whoops, that’s ok ive done that before too. It’s just cool. That califabrication truck is super sweet
    Watt maker, Darkness and Mountun Goat like this.
  28. Sep 16, 2019 at 9:43 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    They literally make everything haha. I’m sure you can find a way to get abs.
