Hypertech help
Discussion in 'Off-Topic Discussion' started by teedubbya, Oct 2, 2018.
  1. Oct 2, 2018 at 6:54 PM
    teedubbya
    teedubbya [OP] I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    Hypertech (in-line) installed. I can’t get it to connect to my laptop. Run the program and it says it can’t find device. Open up my computer and don’t see it there.
  2. Oct 2, 2018 at 7:36 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Click the Inline Speedometer Calibrator menu item and select Run Inline Speedometer Corrector Program.
  3. Oct 2, 2018 at 7:38 PM
    teedubbya
    Austin TX
    Yeah, it doesn’t find it. Says not connected.
    On the initial setup/download of the software it says to plug it in at some point. after I did that there was some random error.
    Fuggin annoying. May just call them tomorrow.
  4. Oct 2, 2018 at 7:41 PM
    Sas
    OKC, OK
    Did you install the USB drivers?
  5. Oct 2, 2018 at 7:43 PM
    Sas
    OKC, OK
  6. Oct 2, 2018 at 7:49 PM
    teedubbya
    Austin TX
    Maybe that’s it since my computer doesn’t even seem to try to recognize it. Will try in the morning. Thanks
  7. Oct 2, 2018 at 7:50 PM
    teedubbya
    Austin TX
    We put in 33.25 at the shop and still 2mph high. Trying to figure out best setting right now. 295/60/20 ridge grapplers
  8. Oct 2, 2018 at 7:55 PM
    Sas
    OKC, OK
    Try 33.94"
    teedubbya[OP] likes this.
  9. Oct 3, 2018 at 12:06 PM
    teedubbya
    Austin TX
    Well I can’t get it to connect and neither can the shop. Either it came unplugged or the unit is shit
    ETA: unit still plugged in
  10. Oct 3, 2018 at 12:34 PM
    teedubbya
    Austin TX
    Took dash apart, unplugged from speedo and it works?? So you can’t adjust it with it plugged in? The fuck
  11. Oct 8, 2018 at 10:22 AM
    teedubbya
    Austin TX
    So put in 33.94 and still 1.5-2mph high on GPS (truck reads 60, gps reads 61-62.)
    What should I try next?
  12. Oct 9, 2018 at 1:59 PM
    teedubbya
    Austin TX
    This thing is such a piece of shit.
    Finally have computer reading device and saying program successful. Except it doesn’t change anything. I put in a value change of over 10” and still have the same speedo error I’ve had since the beginning. Customer service just states the obvious.
    I’m at a loss and $200 less richer.
    ETA:
    Uninstalled device and will return it. I’ll deal with the 2mph difference.
  13. Nov 18, 2018 at 1:34 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Anyone get this to work on a CM platinum? Don’t want to waste money if it doesn’t work.
  14. Nov 21, 2018 at 1:03 PM
    mark1212
    mark1212 New Member
    mark
    The Hypertech is not getting to the laptop, it means that this not compatible with the laptop of which the configuration you have. You have to update the laptop and to do that you need to have the accessibility of the windows modules installer worker high CPU
    DOZER505 likes this.
  15. Nov 21, 2018 at 1:06 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I’m still debating. Decisions are install it or have less miles on the odometer at time of trade in.
  16. Nov 21, 2018 at 2:40 PM
    teedubbya
    Austin TX
    I don’t know what the issue was with mine. I’m not mad about not having correct speedo reading, though. Only peeve is not being able to calculate mpg.
