Hyper tech and bully dog
Discussion in '2nd Gen Tundras (2007-2013)' started by ODSteve, Mar 28, 2015.
  1. Mar 28, 2015 at 7:56 PM
    ODSteve
    ODSteve [OP] New Member
    Steven
    2012 Thundra SR5 TRD CrewMax
    K&N Filter, Low Profile tool box.
    Hyper tech speedo and bully dog gt t+ can you run both?
  2. Mar 28, 2015 at 10:09 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Yes, they are for two different purposes.
  3. Mar 29, 2015 at 7:00 AM
    ODSteve
    Steven
    Sweet just installed the hyper tech gonna get the bully dog in the mail Monday
  4. Mar 29, 2015 at 9:42 AM
    Keep us posted on the results u get from the BD
  5. Mar 29, 2015 at 9:42 AM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Let us know how you like the bullydog.
  6. Mar 29, 2015 at 7:45 PM
    ODSteve
    Steven
    Will do guys
  7. Mar 29, 2015 at 7:48 PM
    TruckyTruck
    Gary
    Steve, you still have a warranty on that truck? From what I read, make sure you have a battery charger hooked up to your truck while you load the tune.
  8. Mar 29, 2015 at 9:21 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Why would you need a battery charger hooked up while loading the tune? Doesn't make any sense unless you cant start the truck and the tune takes 24 hrs to load.
  9. Mar 29, 2015 at 11:05 PM
    TruckyTruck
    Gary
    Yeah I know. Everything I've read on it says you need one and if you don't, you run the risk of bricking the ecu.
  10. Mar 30, 2015 at 8:29 PM
    ODSteve
    Steven
    I have the ext. warranty on it
  11. Mar 30, 2015 at 9:12 PM
    TruckyTruck
    Gary
    Well just remember to return to stock before you take it in or they might void that warranty
  12. Mar 30, 2015 at 9:22 PM
    Yep. Or anytime u take it in for service.
    TruckyTruck[QUOTED] likes this.
  13. Mar 31, 2015 at 11:38 AM
    Mike Tread lightly.
    south carolina
    Main reasons for the charger on the battery, is so if the battery does a (DROP or SPIKE) when it has a load goes under it... Battery fluctuate is enough to kill a upgrade ... The charger keeps a straight line of voltage/amps so the firmware/software can be loaded without power loss or amps.
    Anytime your doing any kind of ecm work (tuning also) always have a battery charger on the battery. This is also done in at the drag strip..
    Odsteve: the bully dog adds a line in the firmware on the ECM... The tech would have to look at the lines of code to find if the bully dog added it most cant read CODE..
  14. Mar 31, 2015 at 4:07 PM
    TruckyTruck
    Gary
    Yeah, what mike said!
