Hyper flashing on all blinker lights
Discussion in '2nd Gen Tundras (2007-2013)' started by Tundra118, Sep 12, 2020.
  1. Sep 12, 2020 at 5:20 PM
    Tundra118
    Tundra118 [OP] New Member
    2013 Tundra
    Hi, just bought a 2013 Toyota Tundra. I noticed the RIGHT front and back blinkers would HYPER flash when turning the RIGHT signal light, and the front and back LEFT signal light would HYPER flash when turning the LEFT signal light.
    The front left turning signal light was out (not working). I didn’t think anything of it, I just purchased a signal light bulb from AutoZone and changed it my self. Even with all 4 signal light bulbs WORKING they all still hyper flashed when I used the right or left turning signals, which was weird.
    The light bulb I replaced died out as soon as I turned off the truck and turned on it back on. I don’t know what the problem could be. Anyone know what I can do to fix this issue? Thank you!!
  2. Sep 12, 2020 at 5:44 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    ensure they're pushed all the way down... or it may appear dead at times
    Tundra118[OP] and 1lowlife like this.
  3. Sep 12, 2020 at 5:45 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    Are any of your turn signal bulbs LED?
    Has this been an issue since you bought the truck, or did it just start?
    Some guys install LED bulbs and are too lazy to add resistors.
    This can cause the hyper flash you are experiencing.
    EDIT: Good call @blackdemon_tt that could be it..
    Tundra118[OP] likes this.
  4. Sep 12, 2020 at 6:16 PM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    I have had my 2011 for just under a year, and my turn signals all flash quickly. I have walked around it, and all are working and in sync. They just cycle really quickly.
  5. Sep 12, 2020 at 6:20 PM
    blackdemon_tt
    He didn't mention anything about LEDs.. So, I would assume they're regular bulbs not completely pressed down.... At times it almost feels like you might break the bulb to do it.... I guess bulb lubricant may be required on these bulbs to ensure it slides all the way down...
    1lowlife likes this.
  6. Sep 12, 2020 at 6:33 PM
    The fronts need to be 3157CK bulbs. They will hyperflash with incorrect bulbs. A regular 3157 is not correct. An incorrect bulb in the front will hyperflash the rear on the same side.
    Tundra118[OP] and Thumper_6119 like this.
  7. Sep 13, 2020 at 2:06 PM
    Tundra118
    2013 Tundra
    It was actually not all the way pushed in. Now it works, however, the still flash quickly when turning on the signal lever, for either right or left.
  8. Sep 13, 2020 at 2:07 PM
    Tundra118
    2013 Tundra
  9. Sep 13, 2020 at 2:10 PM
    Tundra118
    2013 Tundra
    I do not have LEDs I was planning on buying some nice looking headlights at HeadlightRevolution that are about 1k, however, having this problem makes m me think twice about buying them and for them not to work.
  10. Sep 13, 2020 at 2:12 PM
    Tundra118
    2013 Tundra
    I think I’m going to buy lights all around. Do you know what the correct model of bulbs I need for the rest? Thanks!
  11. Sep 13, 2020 at 2:14 PM
    Tundra118
    2013 Tundra
    I don’t have LEDs, I bought the truck this way.
  12. Sep 13, 2020 at 2:18 PM
    Tundra118
    2013 Tundra
    I did now the I have all my lights working but the are still hyper flashing.I don’t know what the problem is.
  13. Sep 13, 2020 at 2:20 PM
    blackdemon_tt
    Do you have the tow package?? or do your mirror have the turn signals in them? Do they function?? if those signals don't work, then your issue may be rooting from there....
    Also as stated, ensure its the correct bulb and is seated all the way down... if your DRLs are not coming on or they're intermittent, then they're not pressed all the way down... I do believe its 2 clicks down.
  14. Sep 13, 2020 at 2:22 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Probably low on blinker fluid .
    WILLINH likes this.
  15. Sep 13, 2020 at 2:25 PM
    Tundra118
    2013 Tundra
    tgese are my rear light bulbs, not sure if these are factory
  16. Sep 13, 2020 at 2:32 PM
    blackdemon_tt
    those are LEDs... there is your issue.. you need a resistor
    JohnLakeman likes this.
  17. Sep 13, 2020 at 2:33 PM
    blackdemon_tt
    or swap them out for a regular bulb...
  18. Sep 13, 2020 at 2:34 PM
    blackdemon_tt
  19. Sep 13, 2020 at 3:12 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Jesus Christ I asked him that and he said no...
    @Tundra118 all you had to do was look at the bulb and see they are LEDs..
    blackdemon_tt[QUOTED] likes this.
  20. Sep 13, 2020 at 3:14 PM
    Tundra118
    2013 Tundra
    Thank you guys so much! Buying the regular bulbs today! I didn’t think those were LED since I always thought LED were only white and not amber. I’ll keep you guys posted.
  21. Sep 13, 2020 at 4:07 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Some threads are just more entertaining than others. :rofl:
    Welcome @Tundra118 from the Texas Hill Country. We've all been newbies before...some just longer ago than others. Hasn't been that long ago I didn't know an "LED" was. :D
    HaveFun and 1lowlife[QUOTED] like this.
  22. Nov 7, 2020 at 11:48 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    @Tundra118 if you buy a turn signal relay for your truck that does LED it will make the LED's normal again while flashing , just have to pull the relay out and push the new one in takes 5 seconds. also cheaper than buying all new bulbs , the only time you need decoders is for driving lights like head lights/high beams and fog lights
