Hyper Flash
Discussion in 'Lighting' started by RobN22, Dec 21, 2017.
  1. Dec 21, 2017 at 8:03 PM
    RobN22
    RobN22 [OP] New Member
    Rob
    2014 Tundra SR5 Crew Max
    Level Kit, 33x12.5x18 Toyo M/T, Fuel Maverick wheels, rear air bag suspension
    Put in some LED tail lights and the blinkers hyper flash now. Is there a flasher relay sold for 2014+ Tundras? Sorry if this has already been asked, I can't seem to find any threads on it besides for first gen Tundras.
  2. Dec 21, 2017 at 8:07 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    2019 Silver Sky Platinum Crew Max
    Bed Rug, Tonneau cover, Window visors, Console organizer, Weather Tech's
    Assuming this would be the same as in the front or with switchbacks. Those require a 6 ohm resistor be installed. Look at Headlight Revolution's website. They have how to videos for everything for our trucks. Im sure someone with a solid answer will chime in shortly.
    Backslider likes this.
  3. Dec 21, 2017 at 8:08 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Did you replace the rear brake lights or blinkers?
  4. Dec 21, 2017 at 8:18 PM
    RobN22
    Rob
    The whole housing and just used whatever plug and play connectors they had with them
  5. Dec 21, 2017 at 8:25 PM
    Backslider
    Tooele, UT
    Yeah - you need a 6ohm resistor on both sides.
    These resistors would work fine. Someone will chime in soon and tell you that you need the exact same product, from the exact same manufacturer, but branded with a different reseller's name... These are the same thing.
    https://www.amazon.com/4Pcs-Aaron-6...404&sr=1-1-spons&keywords=6ohm+resistor&psc=1
    I soldered the ones on the missus' 4runner, but a t-tap works if that's the direction you go.
    andy9743 likes this.
  6. Dec 21, 2017 at 9:45 PM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
  7. Dec 22, 2017 at 7:09 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    I used these also. No issues
