Hyper blink 2018 LED headlights
Discussion in 'Lighting' started by Anakin16, Jan 23, 2018.
  1. Jan 23, 2018 at 5:19 PM
    Anakin16
    Anakin16 [OP] New Member
    2016 Black Tundra TSS 4x4
    7” BDS lift 20” fuel wheels on 35’s
    I used the Ballenger Motorsports retrofit harness along with the Morimoto relay and did a fuse tap for the DRL’s. The repinning was done by a local shop and I think they screwed up. Got it home repinned and was able to get the signal lights to work properly. Only when the parking lights and or headlights does it go to hyperlink. Need help please!!
  2. Jan 24, 2018 at 4:00 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    What do you mean by that or what exactly is the problem you have?
  3. Jan 24, 2018 at 5:27 AM
    Anakin16
    Sorry for the typo, meant hyper blink not link.
  4. Jan 24, 2018 at 5:30 AM
    Anakin16
    So my signal lights work when not using the headlights. When the headlights are on my turn signals hyper blink or flash really fast.
  5. Jan 24, 2018 at 6:37 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Did you make sure you have a good ground (paint removed where you connected the ground wire)?
  6. Jan 24, 2018 at 7:57 AM
    Anakin16
    Ground to Morimoto relay?
  7. Jan 24, 2018 at 9:45 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Whatever ground wires are on your conversion harness. I am saying that because it happened to me on another truck I converted to OEM HID where I also had to use a conversion harness and a bad ground caused my problem.
  8. Jan 24, 2018 at 9:50 AM
    Anakin16
    I will check that ground, thanks for the info.
  9. Jan 24, 2018 at 10:18 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Hope this works out for you.
  10. Jan 24, 2018 at 10:34 AM
    Anakin16
    Appreciate it, hope it does. I will let you know.
  11. Jan 24, 2018 at 11:02 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Are you using regular bulbs?
  12. Jan 24, 2018 at 11:09 AM
    Anakin16
    The 2018 headlights have the regular bulbs in it.
  13. Jan 27, 2018 at 3:12 PM
    Anakin16
    Well I redid everything and it worked great for 2 days. Now my DRL’s don’t turn on and my headlights don’t work. Super frustrated!
