Hydraulic cab mounts??
Discussion in '3rd Gen Tundras (2022+)' started by mmurray70, Jul 27, 2022.
  1. Jul 27, 2022 at 9:04 PM
    mmurray70
    mmurray70 [OP] New Member
    I live on a gravel road and im disappointed in the amount of vibration in the chassis of my new SR5 Tundra. Its really not that greatly improved over the last generation at all. Certain combination of very small bumps cause a terrible resonance in the chassis and it happens fairly often.
    I just learned that the Limited and higher trims have hydraulic cab mounts to help with this issue. Anybody ever drive both over a rough road and compare difference? Are these available to purchase from toyota?
    What would be involved with installing them? Could these be changed by just jacking cab inch or so and sliding them in without disconnecting anything or would it turn into a near full blown cab removal? Dont think I want to get into that lol
    W3agle likes this.
  2. Jul 27, 2022 at 9:08 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Welcome from the basin region, my 2006 has oem cab mounts and they have done great, a common mod is jamming backer rod near the windshield to prevent dash rattles, I use a scratchy blanket that doubles as a dash mat.
    Booney likes this.
  3. Jul 27, 2022 at 9:08 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    I think a good solution would be better shocks. I have Fox 2.5 shocks and live on a dirt road. They are great. I have a 2021 which didn't offer hydraulic body mounts. I have no idea which would be more expensive or simpler but it might be worth looking into.
  4. Jul 27, 2022 at 9:18 PM
    mmurray70
    Its definitely flex in the frame. Certain frequency of bumps and it just resonates, happens even with very small bumps sometimes. Not much the shocks can do for this problem. I hate this about body on frame vehicles. Was really hoping for more of an improvement with the new tundra.
    I was actually thinking the other day, if only they had some kind of a damper between the cab and frame it would really help with this vibration... and tonight I see this:
    Fully Boxed Ladder Frame
    Under Tundra’s bold exterior is a fully boxed ladder frame, designed for strength, rigidity, and superior handling. On Limited grades and above, the cabin is mounted to the frame with hydraulic cab mounts for even greater ride comfort.
  5. Jul 27, 2022 at 9:51 PM
    mmurray70
    AND likes this.
  6. Oct 7, 2022 at 12:24 PM
    mmurray70
    Just thought I would post a follow up. I did change out to the hydraulic mounts and its a very noticeable improvement on my rough road. You still feel the bumps, but the vibration settles down much faster now and much less resonance on old cracked up pavement and very small bumps. I could watch the box shaking all over the place in the side view mirror before and there is much less movement now. Well worth the money IMO.
    My dealer ordered me new bolts, the upper rubber mount, the hydraulic damper, and the lower rubber mount. On my double cab I did not need to change the big bolts, and the bottom rubber mount looked identical. I swapped it anyway since it was already paid for, and could possibly be harder/softer rubber. But Im 99% sure its same and you dont need it.
    One other thing, the 2 small bolts that hold mount to frame have the nut spot welded to chassis. Just used an impact gun to pop this off and get it out of the way to install new mount. I loosened the middle mounts (item 2 on drawing) about an inch and it was no problem removing the old ones at the rear.
    Toyota1234, Hilandr, e46_ema and 6 others like this.
  7. Oct 14, 2022 at 11:38 AM
    Grntrd
    Grntrd New Member
    Calgary
    2022 army green tundra CM TRD-OR SR5
    Hey I was wondering if you did the install on your own sounds like you kind of did? I’m interested in getting the hydraulic cab mounts installed on my sr5 as well. I feel like Toyota let us sr5 owners down with this unfortunately!
  8. Oct 15, 2022 at 8:35 AM
    AND
    AND New Member
    Washington, PNW
    Same question.
    Also, do you have a parts list and can you post pictures?
  9. Dec 12, 2022 at 7:53 PM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    Wow this is impressive mmurray70. May I ask how long it took you and how difficult it was? thanks.
  10. Dec 13, 2022 at 11:23 AM
    Ullose272
    Ullose272 New Member
    Boise, Id
    22 Tundra SR5 TRD OR
    is yours a TRD OR? my SR5 CM TRD OR came with hydraulic cab mounts
  11. Dec 13, 2022 at 12:35 PM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    I've got a TRD OR DC. I'll crawl under mine to see if I can get a glance at the cab mounts to confirm. I doubt you'll get an answer from the OP. Doesn't look like he's been active on the forum since October.
    AND likes this.
  12. Jan 1, 2023 at 2:16 PM
    Coulter
    Coulter New Member
    It shows that every tundra should have hydraulic cab mounts. You can find this information on the website comparing the trim levels. And this tundra brochure.
    https://www.google.com/url?sa=t&sou...0QFnoECEAQAQ&usg=AOvVaw0V-jYGmq0EPZKuxtj4ZmCm
    I probably don't know what I'm looking at. I did look at my mounts and from my limited knowledge, they don't appear to be hydraulic.
    These photos are from another user. My cabin mount is all black. The other user believed the hydraulic mounts were as pictured with the aluminum.SmartSelect_20230101_162118_Chrome.jpg SmartSelect_20230101_162101_Chrome.jpg
  13. Jan 1, 2023 at 2:45 PM
    Ullose272
    Boise, Id
    Those are my pics and yes the black ones are standard mounts, aluminum is hydraulic. Ive since looked at another SR and it was standard. Seems SR5 and up has hydraulic mounts
    =JSG= and Coulter[QUOTED] like this.
  14. Jan 1, 2023 at 6:02 PM
    ArmygreenTRD
    ArmygreenTRD New Member
    2022 Army Green TRD, SR5 DC
    I have an SR5 OR. Black cab mounts.
    Coulter likes this.
  15. Jan 1, 2023 at 7:28 PM
    ATXtoyota
    ATXtoyota New Member
    CENTEX
    2022 Tundra TRD OR 4x4
    Took some pics of mine, SR5 TRD OR CM 4x4 w/ premium and convenience package… I wonder if a package or 4x4 or both, add the hydraulic mounts to the SR5
  16. Jan 1, 2023 at 7:35 PM
    ArmygreenTRD
    IDK. Have the 4x4, prem OR, adv tech package. However, mines a DC and not CM. Maybe that’s the diff?
  17. Jan 2, 2023 at 4:22 AM
    Ullose272
    Boise, Id
    That may be? The SRs thati looked at were both DC as well
  18. Jan 2, 2023 at 5:17 AM
    Coulter
    Coulter New Member
    Help a noob out. What is DC and what is CM?
  19. Jan 2, 2023 at 5:20 AM
    DoubleCab/CrewMax
  20. Jan 2, 2023 at 5:20 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    Double Cab vs Crew Cab
  21. Jan 2, 2023 at 5:24 AM
    Coulter
    Coulter New Member
    Interesting. I have a base model SR 4x2 CM has the standard black mounts.
  22. Jan 2, 2023 at 2:33 PM
    ArmygreenTRD
    @Coulter appears based on post 4 above, the hydraulic only come on limited and above trim. I Somehow missed that.
    PNW Tundra Mike likes this.
  23. Jan 3, 2023 at 9:14 AM
    KroppDuster
    Bilstein 5100s
    I totally forgot to look at mine. I'll see if I can crawl under there tonight when I get home to check my mounts.
    I've got a SR5 DC TRD OR 4WD. Based on what people are reporting, it'll be interesting to see what mounts I have. Given the ride, I can almost promise they are standard rubber isolators and NOT hydraulically dampened mounts.
  24. Jan 4, 2023 at 5:19 AM
    therandomsuit
    therandomsuit New Member
    I crawled under mine to take a look and it has the hydraulic cab mounts. It's a 2022(9/20 build) SR5 CM TRD OR 4WD with the premium off road package and the advance tech package.
  25. Nov 27, 2023 at 3:30 PM
    Rocco2Gen
    Rocco2Gen New Member
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    I am interested in possibly upgrading my SR5. I have not been able to locate the Hydraulic Cab Mount part numbers for a 2023 Tundra. I tried the link above but it failed. Can someone help me please.
  26. Nov 27, 2023 at 5:43 PM
    wxman91
    wxman91 New Engine Enthusiast
    Montana
    2022 TRD Sport 4x4 Army Green / 2021 4Runner Limited
    CBI Baja Bumper / BD S2s Falken Wildpeak AT3W 315/70R17 Method 316s TRD Pro Fox Suspension w/Total Chaos UCAs TRD Dual Tip Exhaust TRD CV Axles TRD Pro Flares + Heritage Grille Alpharex Headlights Dobinson Coils RCI Skid
    I have a SR5 CM TRD Sport with hydraulic mounts. I think if it's a CM, it gets them.
  27. Nov 27, 2023 at 7:05 PM
    Rocco2Gen
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    I have the exact same...
    2023 CrewMax TRD Sport 4x4 in Lunar Rock. I hope someone can provide the hydraulic part number.
  28. Nov 27, 2023 at 7:53 PM
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    Subscribed.. need this..
  29. Dec 31, 2023 at 12:33 PM
    Dirk75
    Dirk75 New Member
    Dirk
    2023 SR5 4x4
    Nothing Yet other than bed cover
    Very very intersted as well never knew this was a things. I could swap those out easily. Thank You Everyone...
  30. Dec 31, 2023 at 12:35 PM
    wxman91
    Montana
    That's weird, I do have the premium package so maybe that's it unless you have it too then I've got nothing.
    CHESSIEMAN and Dirk75 like this.
