Hydraulic Bump Stops vs Bags for Towing heavier loads
Discussion in 'Towing & Hauling' started by the_midwesterner, Feb 2, 2017.
  1. Feb 5, 2017 at 6:19 AM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Hey Luis...........It is a Equil-i-zer hitch model 90-00-1000. 10,000 lb model. They have been around forever and it is a WD hitch and dual sway bar all in one. No chains like the old style WD and yes the hitch is included. Search online for pricing, I found it at Dyers RV for $ 443.00, and few more bucks for the ball. No tax and free delivery to your door. Good luck........
  2. Feb 5, 2017 at 8:23 AM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    The Equil-i-zer is awesome mine is the 14k model it makes towing so comfortable.
    CM-LENNY and ColoradoTJ like this.
  3. Feb 5, 2017 at 8:23 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    :humble:
    ColoradoTJ likes this.
  4. Feb 5, 2017 at 8:32 AM
    That is what I have. Awesome hitch.
  5. Feb 22, 2017 at 4:34 PM
    TakesAToyota
    TakesAToyota New Member
    2004 Tundra Double Cab
    New here. I have an 04 Double Cab 2wd. I'm looking to either get air bags our helper springs of some kind to help some with sagging when hauling. I'm not looking to increase my load capacity, just not sag when I have a full load. By reading the above posts, I learned that I should have looked to see how far if any I am sitting on the overload springs. I don't want a stiff ride all the time so I am not sure if I like the idea of different leaves. Air bags give flexibility but can be a pain unless I drop the $ for a pump, not. Is there a medium pressure I could run that would give some extra support and not ride like junk with an empty bed.....thoughts, experience? I'm looking to do this inexpensively, but I don't want to sacrifice ride quality when not hauling. Half the reason I went with a Tundra was because it doesn't handle like a truck.
  6. Feb 22, 2017 at 5:31 PM
    Welcome.
    You are looking for airbags without the internal joists (bumpstop) for the best possible ride unloaded.
  7. Jun 11, 2017 at 10:56 PM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    Solves everything if set up correctly and your not tongue heavy. My Taco could not take very much a tongue load at all even with a 4" lift and an extra leaf. The Weight Distribution hitch worked like a charm. Got one for towing my RV and will adjust it lower for the taller Tundra. No added expense what so ever modifying the rear suspension when you use one. You won't want to pull anything ever again without one.
