Hybrid mpg
Discussion in '3rd Gen Tundras (2022+)' started by Dstrahan, Dec 5, 2021.
  1. Jan 26, 2022 at 5:22 AM
    #151
    Mattedfred
    Mattedfred Toyota Fan Boy Since ‘04
    Ted
    Cambridge, Ontario Canada
    2023 SR5 TRD Sport DC 4X4 in MGM
    TRD Skid Plate/Running Boards, Bison Soft Rollup Tonneau, Thule Canoe Rack, Bedmat, Tailgate Black Insert Badge, Northwest Seat Covers Neoprene Custom Fit Front Row Seat Covers. Tailgate Mat
    We love it. It's our first hybrid. We bought it used September 2020. It's my wife's daily driver and our go to vehicle when the two of us are out together. We leave the gas guzzling Taco in the driveway as much as possible. So far, her best fuel economy has been 2.9 L/100km (81mpg) on a 50 km commute home from work.
    raylo[QUOTED] likes this.
  2. Jan 26, 2022 at 6:22 AM
    #152
    raylo
    raylo not so new member
    Frederick, MD
    None
    I have friends that own a pair of his and hers Prii, as they call them. They also love them. One of these days I'll probably sell my Vette... I love it but it is really just a toy... and get something electrified. Not sure yet if it will be battery or hybrid but needs AWD. Maybe even something like the Mustang Mach E? I dunno.
    Meanwhile I just saw on Car and Driver that the 2023 Sequoia is being dropped soon and of course since it is on the same platform as Tundra it will essentially be a Tundra with a full body. The one interesting point is that it will only come with the hybrid iForce Max powertrain. They also say that MPG is not yet available.
    2023 Toyota Sequoia Arrives with a Standard Hybrid Powertrain (caranddriver.com)
  3. Jan 26, 2022 at 6:36 AM
    #153
    Jonross227
    Jonross227 New Member
    While I don't expect the hybrid to get much over the motor only trucks, I do wonder if we'll see big improvement in mpg with lifts, bigger tires, and towing.
    Say motor only ends up being 16 mpg on 35's. With the way the system adds power it's possible the hybrid could be 18-19. Same when towing.
    DexterL likes this.
  4. Jan 26, 2022 at 8:49 AM
    #154
    xc_tc
    xc_tc New Member
    Let’s assume it takes full power to drive 35 mph, 1.9 kWh will get you 1.8 miles.
    math is (1.9 kWh /36 kW)*35mi/h = 1.85 mi.
    Definitely can drive the Tundra iforce max more than 18 mph in EV mode. The system is completely different than the Prius. The newest Prius drivetrain was redesigned to allow EV mode in higher speeds. The EV mode max speed is a function of the motor speed and power available from the motor. The CVT forces the motor to spin at high speeds and low torque. Whereas the Tundra electric motor will spin at low rpm and keep high torque to maintain speed.
    Saltyhero13 likes this.
  5. Jan 26, 2022 at 9:30 AM
    #155
    raylo
    Frederick, MD
    None
    Sounds reasonable. But you'd never get that in the real world. Battery capacities are calculated to totally empty, a state which the BMS or other firmware will prevent you from reaching to avoid damaging the battery. So about 20% less is a good starting assumption. There is also the matter of max current, say accelerating or going up a hill before the ICE kicks in. Again the truck's systems are going to limit that, especially considering this is a NiMH battery.
  6. Jan 26, 2022 at 9:39 AM
    #156
    xc_tc
    xc_tc New Member
    Yeah that’s for sure. Let’s assume you can use ~40% before the engine turns on to charge the battery, then range is only 3/4 mile. In my experience with F150 Powerboost I found it hard to accelerate with just electric motor. But it was easy to back off and cruise at 40 mph in electric. I expect Tundra to be the same. But after battery is drained, the engine stays on for awhile. Still, electric motor is adding power when it is needed based on what’s shown on the power flow screen.
    Pattington22 likes this.
  7. Jan 26, 2022 at 1:46 PM
    #157
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    This is my hope as well- erases 35's, lift, topper, rack and gets stock numbers.
  8. Jan 26, 2022 at 3:54 PM
    #158
    Blitz79
    Blitz79 New Member
    Yes I meant 0-18 mph. It is not wrong, the Sequoia release has the same information about the iForce Max.
  9. Jan 26, 2022 at 4:20 PM
    #159
    xc_tc
    xc_tc New Member
    Yeah, I know what the Toyota information says. I don’t think it’s right, but we’ll have to wait until someone actually tests this out in a Tundra hybrid. My reasoning is this:
    • F150 hybrid can hold 50 mph in electric only on flat road
    • F150 hybrid electric motor spec is identical to the Tundra hybrid motor spec (both 36 kW)
    • Tundra is heavier but not by much so will require similar driving torque to keep a constant speed on flat road
    I don’t see any reason why the electric only cruising speed can’t be 30 or 40 mph.
    In this video at 5:00 we can see the speed is ~23 mph and the tach is at ~1200 rpm. A few seconds later the tach needle disappears and goes to 0 rpm, meaning electric only driving, and he keeps cruising around 23 mph. https://youtu.be/QjztMrF3mUs
    =JSG= likes this.
  10. Jan 26, 2022 at 4:27 PM
    #160
    xc_tc
    xc_tc New Member
  11. Jan 28, 2022 at 8:53 AM
    #161
    Blitz79
    Blitz79 New Member
    I don't know what to tell you other than that is what Toyota is saying. They can lock it down to 0-18 on the computer even if the motor is capable of doing more. Also, the video is a pre-production Tundra. In any case, 3 more days and we will know for sure :thumbsup:
  12. Jan 28, 2022 at 9:02 AM
    #162
    raylo
    Frederick, MD
    None
    In 3 days we'll have the EPA numbers... finally!... then another typical wait for "real world" MPG data to trickle in as testers and eventually customers get their hands on. More data is good but it'll be awhile for the final answer.
    Mattedfred likes this.
  13. Jan 28, 2022 at 2:04 PM
    #163
    MTRock
    MTRock 1889
    Montana
    2013 Rock Warrior DC
    DC rear fold down seats, decals removed, blacked out badges, complete stereo, ceramic coating, ToyTec Boss 3/1.5, RidgeGrappler 305/70r17, blacked out rock rings and center caps, smoked tail lights, BAMUFFLER Alpharex Pro headlights, TRD PRO Sequoia Grille, DAPtune
    FWIW….Spoke to My Salesman today. He just returned from Tundra Training. Wouldn’t say Hybrid MPG, but grinned and hinted EPA will be 25-27? Also Hybrids will be out sooner than expected..“Early March”
    Bob_Loblaw and skynyrd87 like this.
  14. Jan 28, 2022 at 2:13 PM
    #164
    skynyrd87
    skynyrd87 New Member
    Flagstaff, AZ
    We will also get pricing on Monday, right?
  15. Jan 28, 2022 at 2:16 PM
    #165
    MTRock
    MTRock 1889
    Montana
    He wouldn’t say when pricing and EPA numbers would be available.. And said the Hybrid option was “Less $” than he expected? Again wouldn’t say $$$.
  16. Jan 28, 2022 at 2:36 PM
    #166
    Mattedfred
    Ted
    My salesman said 21mpg after his training.
    We all find out February 1st
    Bob_Loblaw and MTRock[QUOTED] like this.
  17. Jan 28, 2022 at 3:32 PM
    #167
    WPTundra1794
    WPTundra1794 New Member
    Scott
    2022 Tundra 1794
    i called two dealerships in Orlando and spoke with two different salesman. Both were total guesses but one said 25 combined and one said 28 combined. Also told me hybrid availability not until late spring- early summer.
    MTRock likes this.
  18. Jan 28, 2022 at 6:32 PM
    #168
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    Well, apparently every salesman went to a different training session…
  19. Jan 28, 2022 at 6:35 PM
    #169
    Coal Dragger
    Coal Dragger New Member
    2007 White Double Cab Limited 5.7L 4X4
    I wanted a faster vehicle so I also bought a Chevy SS... because 4 door sedans with big V8’s are hilarious.
    None of those dumb asses knows.
    basian99, 9OH1, Pattington22 and 3 others like this.
  20. Jan 28, 2022 at 6:54 PM
    #170
    RavingOx
    RavingOx Member
    WNC
    2022 Tundra Platinum in Black
    How do you like a comment more than once?
  21. Jan 28, 2022 at 7:03 PM
    #171
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2021 Super White TRD Pro
    In progress…
    Quote it more than once.
  22. Jan 29, 2022 at 3:27 AM
    #172
    raylo
    Frederick, MD
    None
    LOL... These salesmen aren't the brightest crayons in the desk... and probably didn't even pay attention to the training.
    trazerr[QUOTED] likes this.
  23. Jan 29, 2022 at 4:41 AM
    #173
    tttrdpro
    SWGA
    In progress…
    Also, anyone who believes a salesman…I have some wonderful beachfront property in Kansas for sale. Call me.
    Henry1jg and 9OH1 like this.
  24. Jan 29, 2022 at 4:42 AM
    #174
    raylo
    Frederick, MD
    None
    LOL... or maybe some nice beachfront on Grand Island Nebraska.
  25. Jan 29, 2022 at 5:31 AM
    #175
    Mattedfred
    Ted
    Hey, all I 'm saying is that my dealership's Sales Floor Manager emailed those of us that signed up for Tundra updates to say that during their training they were told that the "estimated" value for the iForce Max is "11.2 L/100km combined" (21mpg) vs the gas, which is "12.2 L/100km combined" (19mpg). Obviously 4X4 numbers, but he didn't specify.
    I'm not saying that I agree with him. I think we all agree that 21mpg combined is not a great number. Why would he be so keen to share a disappointing number? That said, I wouldn't be surprised if there is some confusion when folks are getting second and third hand information. Some may be quoting city, some highway, some combined, some 4X2, while others could be quoting 4X4 values for either of these scenarios. I'd think that the city 4X2 would provide the highest mpg and the highway 4X4 would provide the lowest.
    I will say, that YouTube sensation Steven Welch's 30mpg is f@cking out to lunch IMHO.
  26. Jan 29, 2022 at 8:04 AM
    #176
    xc_tc
    xc_tc New Member
    If Toyota had released a Tundra with the V6 hybrid system that was in the Highlander, maaaaybe 30 mpg was possible but the truck would be shit to drive.
  27. Jan 29, 2022 at 8:16 AM
    #177
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Don't know if anyone's seen this yet but...
  28. Jan 29, 2022 at 8:24 AM
    #178
    trazerr
    trazerr New Member
    Oregon
    I-Force = gas only
    I-Force MAX = Hybrid
  29. Jan 29, 2022 at 9:50 AM
    #179
    raylo
    Frederick, MD
    None
    Highlander hybrid ICE part is a 4 banger. It doesn't share the V-6 with the rest of the Highlander lineup.
  30. Jan 29, 2022 at 10:11 AM
    #180
    xc_tc
    xc_tc New Member
    The previous gen highlander hybrid, changed to a 4 cylinder in 2020.
