HVAC help
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mike63078, Dec 2, 2021.
  1. Dec 2, 2021 at 6:46 AM
    Mike63078
    Mike63078 [OP] New Member
    2021 SE5 Tundra
    I’ll take this into the dealer but has anyone else had an issue with the HVAC controls on there SR5 blend controls. When I have the selector centered which should be on the floor there is a lot of air coming through the dash vents. Seems like something is wrong with the actuator but wanted to know if this is common.
  2. Dec 2, 2021 at 7:53 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    yeah mine does that too. I just close the vents and adjust the temp. But it is annoying though.
    I've noticed it on other vehicles before but it seems like the Tundra is a little worse.
  3. Dec 2, 2021 at 8:14 AM
    Kung
    KG, VA
    Question - do you have the dual zone climate control thing? If so....when you start your truck, does it automatically display temp, direction, etc. on that little HVAC LCD screen right away? Or does it take 30 seconds or so to show up?
    I ask because this same thing happened to me. A sensor/solenoid would fail somewhere sporadically, and when that happens, it kicks the HVAC system into sort of a 'self-check' for 30 seconds. When it does it, it failsafes the HVAC system into a sort-of 'safety' mode, where air would ONLY blow out the dash/defrost vents.
  4. Dec 6, 2021 at 8:09 AM
    Mike63078
    2021 SE5 Tundra
    I do not have dual zone just the base system. It almost reminds me of an old cable vacuum system that would not divert the air to the right vents.
  5. Dec 6, 2021 at 9:14 AM
    TundyMcTunra
    TundyMcTunra Irrational people are not often convinced by facts
    Lost in the PNW
    2010 Tundra Limited Crew Max 4x4, 2018 Tacoma Inferno TRDORDCSB, 2019 Rav4 Lunar Rock, 1991 4Runner Crawler. Ivan Stewart Edition
    Welcome OP
  6. Dec 6, 2021 at 10:04 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    It's typical to always have air coming thru vents, tho low powered....
  7. Dec 7, 2021 at 6:39 PM
    jclem65
    jclem65 New Member
    james
    2019 cement tundra crewmax sr5 trd off road
    interior led's,fortin remote-start with i linker
    i would like to throw out a me too..... it's like it's not working like it should.
  8. Dec 7, 2021 at 6:44 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    Mine has always done this. Its not blasting out of the front vents but its noticeable.
  9. Dec 7, 2021 at 6:46 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Does it stop if you turn on recirc mode?
  10. Dec 9, 2021 at 5:57 PM
    jclem65
    jclem65 New Member
    james
    im going to check that out tomorrow and post it here...
    boostedtrdpro[QUOTED] likes this.
  11. Dec 11, 2021 at 6:06 AM
    jclem65
    jclem65 New Member
    james
    it's the same in recir mode....... the only time is seems better is when it's on defrost?
  12. Dec 23, 2021 at 8:34 AM
    Kung
    KG, VA
    You may not have the same system, but I’m betting that same solenoid exists in the normal system. If it fails, it “fails” to defrost vents as a safety measure.
