HVAC always blowing?
Discussion in '2.5 Gen Tundras (2014-2021)' started by WXman, Dec 23, 2021.
  1. Dec 23, 2021 at 7:07 AM
    WXman
    WXman [OP] New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    I'm noticing that this new to me truck has warm air lightly blowing out of the dash vents and defrost vents constantly. Even when the dial is in "feet only" mode. Is this normal for these trucks or is my blend door screwed up?
    Monsterb likes this.
  2. Dec 23, 2021 at 7:20 AM
    yamabob
    yamabob New Member
    Chicagoland
    2018 Limited
    Normal. My 2018 does it also.
    WXman[OP] likes this.
  3. Dec 23, 2021 at 7:24 AM
    joe_from_iowa
    joe_from_iowa New Member
    Iowa
    2021 Tundra Double Cab SX
    Peeled off the SX stickers from the bed sides. Tyger running boards. A.R.E. DCU topper
    My 2021 does it too.
  4. Dec 23, 2021 at 7:50 AM
    Toyotaloop
    Toyotaloop New Member
    Pittsburgh
    2021 SR5 Crewmax MGM
    Very little so far
    Same here. Was wondering the same thing.
  5. Dec 23, 2021 at 1:07 PM
    intr3nsic
    intr3nsic New Member
    2016 does it
  6. Dec 23, 2021 at 1:12 PM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Press the recirc button. That will close the fresh air blend door putting the ventilation system into recirc mode.
    15whtrd likes this.
  7. Dec 23, 2021 at 1:28 PM
    intr3nsic
    I will try this tonight
  8. Dec 23, 2021 at 1:34 PM
    Monsterb
    Monsterb New Member
    2021 Tundra Cement Trail Edition
    I just noticed this today about mine. I'll try the fresh-air/recirc tonight.
  9. Dec 23, 2021 at 2:13 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I opened a case with corporate about this very thing years ago.
    From what I was told by Toyota, the ventilation to all outputs remain slightly open on all settings.
    The recirc closes the input through the cabin filter and slows down the flow, but the output vents are always open.
    Their reasoning in doing this was to keep "fresh" air moving through cab at all times to further reduce stagnant air as required by some higher power lawmakers.
    The only way to stop it completely is with the recirc on and you have to block the vents behind the rear seats on both sides of the cab. (In the botton corner of the c pillar). I blocked them and did a test run. The doors would air cushion themselves adjar and not close fully without being whipped closed almost slamming shut. I said no thanks.
    Idk, I shut all the vents on the dash and curse at them when the air is still coming through. Lol
  10. Dec 23, 2021 at 2:36 PM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    Me same I was wondering if anyone else noticed now I know :D
