Husky rear liner ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by GSD, Sep 22, 2019.
  1. Sep 30, 2019 at 8:23 PM
    Niceguy
    Niceguy New Member
    19 Cement Limited
    So a quick update on this. I ordered the Husky Weatherbeater rear underseat floor liner hoping they hadn't changed that one as well, and it's exactly the same as the new X-Act I posted above. It would appear that they've changed the design on both. Bummer. Weathertech hear I come.
    AggiePhil likes this.
  2. Sep 30, 2019 at 8:50 PM
    GSD
    GSD [OP] New Member
    Seattle, WA
    2019 Platinum Crewmax
    I basically un-warped my Weathertech by using one of those torpedo heaters to get it heated up and then molded it back into place. I also attached a couple Eagle Klaws like in the pic PaulROahu posted, so far so good. This will have to work for now until I'm able to find somewhere that makes one out of heavier rubber and has full rear coverage.
    PaulROahu likes this.
  3. Sep 30, 2019 at 8:57 PM
    toyoboyo
    toyoboyo New Member
    You guys could always use the clear plastic film detailers use on new cars.
    I'm a fan of weathertechs because of the hard plastic. They easier to clean and handle. Not sure on tundra fitment but I've seen this work/fit really nice on other cars. Bummer that one member said they slide around. That would piss me off.
  4. Oct 7, 2019 at 1:41 PM
    Niceguy
    Niceguy New Member
    19 Cement Limited
    Update. I purchased another Husky X-Act rear under seat liner, but this time I bought it used (like new) from Amazon Warehouse and finally I struck gold. It’s the older design that covers the side carpet like I originally wanted. Can’t guarantee this will work for everyone, but just wanted to pass along my (small) success story. Thanks for all the help and advice.
    Boerseun, GODZILLA and PaulROahu like this.
  5. Oct 7, 2019 at 1:56 PM
    toyoboyo
    toyoboyo New Member
    Pics?
  6. Oct 7, 2019 at 2:54 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Don’t forget to get the “eagle claw” to secure the rear lip from lifting
  7. Oct 7, 2019 at 4:21 PM
    DoubleJackOnTap
    DoubleJackOnTap New Member
    SW Washington
    2018 Super White TRD Sport
    CoverKing Neoprene Seat Covers, UltraFlex
    Hope it works out for you. I had to return mine to Amazon because it didnt lay flat. I tried leaving it in the sun, hot days and finally a heat gun. It seemed like it was made just a little bit too big. I've seen photos of them that look awesome, but that wasn't my experience. Maybe that is why they changed the design?
  8. Oct 7, 2019 at 8:16 PM
    Niceguy
    Niceguy New Member
    19 Cement Limited
    Was the one you returned the X-Act contour or the Weatherbeater?
  9. Oct 8, 2019 at 6:58 AM
    DoubleJackOnTap
    SW Washington
    It was the X-Act contour.
  10. Oct 8, 2019 at 10:47 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I have the huskys in mine. My rear is actually from my previous double cab. Fits fine, just doesn't cover under the seat and I'm alright with that. Future plans for under there anyway.
  11. Oct 8, 2019 at 10:49 AM
  12. Oct 8, 2019 at 11:02 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  13. Oct 13, 2019 at 8:22 AM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    I'm researching a lot on floor liners and have seen weathertech nows makes a floor liner called 3D, has more of a rubber texture like the husky mats do. I may give them a try. No passenger hold down from Toyota is foolish.
  14. Oct 13, 2019 at 8:34 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Huskys has a passenger hold down screw. One part threads into the carpet, then a threaded cap sandwiches the floor mat. Do the weather techs have something like that?
  15. Oct 13, 2019 at 8:37 AM
    Northern Toyota
    Tires and bilstein
    The digital fit ones do not from what I've read. Weathertech website doesn't show an actual picture of these 3D ones
    I see there is a product called eagle claw I believe that does the same thing
  16. Oct 13, 2019 at 10:46 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Here's a picture of the rear. Originally for a double cab. I didn't want to buy another and the only thing I'm worried is where your feet go.
    Rubberdown likes this.
  17. Oct 13, 2019 at 10:59 AM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Easy instal easy on and off, just make sure you align your spot and tap in each leg separate, don’t step on it like they say and use a rubber mallet. Best thing to hold your mat down
    Paul B and Rockgate like this.
  18. Oct 15, 2019 at 8:25 PM
    GSD
    GSD [OP] New Member
    Seattle, WA
    x2 :popcorn:
  19. Oct 15, 2019 at 9:29 PM
    #49
    Niceguy
    Niceguy New Member
    19 Cement Limited
    Whoops. Forgot to post this. Here ya go. This was a used one purchased from Amazon Warehouse
  20. Mar 25, 2020 at 6:46 PM
    #50
    FiveO Enduro
    FiveO Enduro New Member
    Buffalo, NY
    2020 Army Green Pro
    Son of a... came across this too late.. anyone have any updates on the new weathertechs? Trying to decide if I want to return these or just deal with it.
  21. Mar 26, 2020 at 9:06 AM
    #51
    Northern Toyota
    Tires and bilstein
    My weathertech rear mats cover the side where yours do not. Is that what you're asking?
    FiveO Enduro[QUOTED] likes this.
  22. Mar 26, 2020 at 9:15 AM
    #52
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Which ones on Amazon are these?
  23. Aug 5, 2020 at 2:29 PM
    #53
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Here is what I just got from Amazon.ca, full coverage horizontally but doesn't cover the side portion fully vertical (if that makes sense). They were considered "FULL Coverage".
    I'm still much happier vs the 2pc OEM junkers her didn't even fit together properly. Fronts ad just as everyone else has shown.
  24. Aug 5, 2020 at 3:01 PM
    #54
    7.62X51
    7.62X51 New Member
    Virginia Beach
    I have Husky's in my truck. Almost half of the cost of Weathertech. Read the warranty between the two. Hands down Husky owns Weathertech. I recently had my truck at the detailer. They lost the hold down for my passenger seat mat. I called husky to get a replacement piece fully expecting to pay. Lady on the other end said lifetime warranty. Sent me two for free. They have my business as long as they're in business.
    HulkSmurf14 likes this.
  25. Aug 6, 2020 at 9:34 AM
    #55
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    Maxliner $82.42 shipped Amazon. Kind of hard plastic but fit great and does not move around and super easy cleanup[​IMG] IMG_4146.jpg
    AggiePhil, SuperWhite20 and Hoff like this.
  26. Aug 6, 2020 at 10:22 AM
    #56
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    How did you get that to lay so flat?
    I tried on of those in my DC and it never would lay flat.
    I loved the coverage, but hated the thin PLASTIC material..
  27. Aug 6, 2020 at 10:44 AM
    #57
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    Must have got lucky?? What time of year did you try yours, cold??
  28. Aug 6, 2020 at 10:46 AM
    #58
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    July..
    It was folded twice in the box.
    I didn't like the material anyway so I sent it back.
    I like the rubber Huskey mat better..
  29. Aug 6, 2020 at 10:53 AM
    #59
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    I agree the material is not the greatest but can't beat the coverage. I have Husky exactfit in her Camry and they are awesome
  30. Aug 6, 2020 at 8:30 PM
    #60
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    I bought the Maxliner. It goes past the seat brackets. I tucked mine under the door threshold trim and looks great.
