Humming/Rattle in cab when RPM 1800-2000
Discussion in '2.5 Gen Tundras (2014-2021)' started by JPritch22, Jan 12, 2018.
  1. Jan 12, 2018 at 11:30 PM
    JPritch22
    JPritch22 [OP] New Member
    2018 TUNDRA SR5 Crewmax
    There may be another thread about this already but has anyone had a humming/rattle when accelerating? Sounds like it’s from passenger side dash/glove box. I have tried to figure out what it is and no matter what I do can’t seem to get rid of it. I guess it’s my ocd but it’s all I can focus on and it’s driving me crazy, anyone got any ideas?
  2. Jan 13, 2018 at 5:53 AM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    I had one. It was my .45. Rip rounds jiggling around in the mag.
  3. Jan 15, 2018 at 2:08 PM
    JPritch22
    Hey I actually figured out what it was the other day. ECM vibrating behind glove box. Pulled that big plastic piece off under glove box, tightened the screws but didn’t work so I put a c clamp on it and tested it and noise was completely gone.
    TTund16 likes this.
  4. Jan 15, 2018 at 4:28 PM
    JPritch22
    Inside the cab the ecu comes through and is in a metal casing. There’s enough space in there for it to rattle
  5. Jan 15, 2018 at 4:31 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
  6. Jan 16, 2018 at 3:17 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    Finally got around to dealing with the rattle today...same as the rest.....ecu box under the dash....a couple of layers of sound deadened and the rattle is gone.
  7. Jan 16, 2018 at 9:38 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    E12FA67B-6F07-4512-A319-394D46436784.jpg I just wrapped it around the box the ecu fits into on the inside of the dash behind the glove box. (Not my photo)
  8. Jan 16, 2018 at 10:01 PM
    BamaGuyinTX
    BamaGuyinTX New Member
    2018 Silver Tundra SR5
    I’ve got the same issue—thanks for sharing.
  9. Jan 18, 2018 at 9:43 AM
    YYJTUndra
    YYJTUndra New Member
    Victoria, BC
    2017 MGM Tundra Platinum
    I had the exact same thing--was on the other tundra forum looking for a solution (someone suggested loosening the wires on the engine side). Mine was a buzzing sound that would come on around 1500 rpm- 2000 rpm. It took many trips after removing the plastic covering and getting my kids to feel around for anything buzzing before we found the culprit. I too used sound deadening material (Dynamat) and wrapped the whole ECU with it. Now the sound is gone (thank goodness!).
    BamaGuyinTX likes this.
  10. Jan 18, 2018 at 11:08 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Now that is a really worthwhile thread with a good solution.
    Mine hasn't developed the buzzing sound yet but with the sub-freezing temperatures we have right now there are some plastic creaks here and there but they usually go away once the inside warms up (really good heater in the Tundra). I would consider that normal as all my previous trucks did it as well when it was cold.
  11. Jan 18, 2018 at 1:02 PM
    JPritch22
    YYJTUndra thanks for replying. It is one of the most annoying sounds to listen to in a new truck. I’ll have to try the dynamat. I still have the c clamp on the metal casing around the ECU. It definitely stopped the noise tough. Now it feels and sounds like a new truck. It’s at the stealership right now getting heated leather seats and pocket flares. Ready to see what it looks like when it’s finished.
    Vendeta2k likes this.
  12. Jan 18, 2018 at 1:06 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    Half a sheet of dynamat or sound deadener from a local stereo shop should be more than enough.
  13. Jan 18, 2018 at 1:24 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    If you get the Katzkins you will be very impressed! And the heated seats are really needed right now.
  14. Jan 18, 2018 at 7:39 PM
    JPritch22
    Went and picked it up this evening. The katskinz and seat heaters are awesome. Pocket flares look good as well.
  15. Jan 18, 2018 at 8:24 PM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    It was the most annoying sound, I was bound and determined to figure out where it was coming from. Happy I could help others along the way.
    TTund16, 71_340[QUOTED] and Vendeta2k like this.
  16. Jan 18, 2018 at 9:23 PM
    Lift Gate Gus
    Lift Gate Gus New Member
    Beaverton, OR
    2018 CM
    Vehicle Modifications:
    Had the same issue. Took mine to the dealership they replaced the ecm. No more rattle mine was bad.
  17. Jan 21, 2018 at 10:55 PM
    BamaGuyinTX
    Mine resolved on its own...strange
  18. Jan 29, 2018 at 10:37 PM
    Stuffs
    Stuffs New Member
    Had the exact same issue. Drove me nuts. Some say its because it rubs against the opening but from what I can tell, its the casing itself, its just thin metal on one side so it buzzes.
    I took a piece of radiator hose sliced down the middle and stuck it on the ECU's edge. Noise gone.
    It has to do w the vibrations from the ECU harness under the hood near the firewall. The vibrations go from the engine, down the hardness, to the bracket and on the firewall. I know some people have unclipped the harness from the bracket and zipped tied it instead to stop the noise with success as well.
    I also notice everyone I've read with this ECU buzz is a 2018. Wonder what changed? Did they go w a thinner housing?
  19. Jan 30, 2018 at 6:56 AM
    dsimonl
    dsimonl New Member
    2017 Tundra DC Limited MGM
    Amp Research Powersteps and Bedstep, 2018 LED headlights, LineX Platinum, Baja Designs fog lights, Driver side grab handle, SwingCase
    17s have the same issue
  20. Feb 3, 2018 at 6:30 AM
    JBang
    JBang New Member
    jeff
    2018 Tundra
    I have the same buzzing, dealership tried to insulate with felt, still buzzes,
    I think the excessive engine vibration at 2000 RPM is the issue, not a loose ecm.
  21. Feb 3, 2018 at 6:43 AM
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    I think I hear this buzzing for the first time the other day. Too damn cold outside to mess with fixing it. Its done it a couple times, but if it continues I'll fix it in a few weeks when it warms up.
  22. Feb 8, 2018 at 7:05 AM
    Rbguy90277
    Rbguy90277 New Member
    Seattle
    2018 MGM Ltd Crew TRD
    Can someone post step by step instructions on what I need to do to fix the rattle/buzzing? Got a 2018 and it happens everytime I'm step hard on the gas pedal. It's driving me crazy! I'm like :lalala:
  23. Feb 9, 2018 at 1:10 PM
    Lift Gate Gus
    Beaverton, OR
    2018 CM
    Step 1: Take it back to the dealership.
  24. Feb 21, 2018 at 5:56 AM
    Stig
    Stig New Member
    I finally got around to trying this. ECM was not the easiest to remove. I had to disconnect all the wire harnesses to make space to get it out.
    Unfortunately I don't think this is the source of the rattle I have. I wrapped it completely in sound deadening mat and the noise is the exact same. Going to have to get my wife to drive while I lay under there to find it.
    Still have a buzzing or humming sound in the rear headliner at low rpms under medium load.
  25. Feb 21, 2018 at 6:20 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    I didn’t remove mine to fix the buzzing. I was just able to apply some small sections of sound deadener while it was still installed. Hopefully you get your buzz figured out.
  26. Feb 21, 2018 at 6:22 AM
    Stig
    Stig New Member
    I see. I thought I read somewhere one person did remove it, mentioning the 4 bolts that take a 10mm socket. The buzz is not as bad as the rattling noise under the dash as rea since that happens almost constantly.
    Vendeta2k[QUOTED] likes this.
  27. Feb 21, 2018 at 7:56 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    Yep PNW Husky did remove to wrap....I went the lazy route and just wrapped it in the truck.
  28. Feb 21, 2018 at 8:43 AM
    YYJTUndra
    Victoria, BC
    I too just wrapped while still installed. SOrry to hear that the sound deadener didn't work. Your best bet is to have a good look and feel with someone driving as you suggest. Just curious--for all those who have had issues, do you have the TRD dual exhaust?
  29. Feb 22, 2018 at 5:51 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    Yes
  30. Feb 26, 2018 at 11:14 AM
    Rbguy90277
    Seattle
    Yes, I have the TRD dual exhaust and the metallic vibration at 2k rpm. Driving me :annoyed:
