Huge Tundra Lean
Discussion in 'General Tundra Discussion' started by ChopperJ, Dec 19, 2020.
  1. Dec 19, 2020 at 7:58 AM
    ChopperJ
    ChopperJ [OP] New Member
    Jon
    2014 DC 4X4 SR5
    My Tundra has a 2 inch lean to the drivers side. I am familiar with the Tundra lean but this seems excessive. It's a 2014 DC 4X4 that I bought used 2 years ago, it had a 3/1 lift with strut spacers that I recently removed. I installed Toytec/Eibach Complete Front Coilovers to level it and removed the rear leaf spring blocks. It was leaning so I replaced the rear leaf springs and it leans just as bad. The measurements from ground to fender well are as follows. Front: Left 38 3/4, Right 39 1/4 Rear: Left 38 1/2, Right 40 1/2. I tried lifting the left front corner with floor jack the see if would level, it did not so I don't think a coil over shim would work. Is my frame bent?
    Blue Thunder and YardBird like this.
  2. Dec 19, 2020 at 7:59 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    I hope someone can help you with this issue.
    ChopperJ[OP] likes this.
  3. Dec 19, 2020 at 8:18 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Assuming it didn’t have a lean prior when you bought it something changed when you swapped out your coilovers. I know the OEM coilovers are different from left to right presumably to account for the lean (more weight on drivers side). If it didn’t have a lean before then your frame is probably OK. I was going to suggest shims, why don’t you think they’ll work?
    Suggest calling ToyTec, they may be able to help you out. Try measuring from the center hub of the wheel to the fender and not from the ground to rule out uneven ground and differences in tire pressure too.
    Edit: I have 6112s on front set at 1.9” with 2 shims on drivers side and 1 on passenger and my front measurements from hub center to fender are both exactly 24.5” front and 25.5” rear (I put ToyTec shackles at the 1” setting).
    TheBeast likes this.
  4. Dec 19, 2020 at 8:21 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  5. Dec 19, 2020 at 8:27 AM
    ChopperJ
    Jon
    2014 DC 4X4 SR5
  6. Dec 19, 2020 at 8:33 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    That is one of the most noticeable leans I have seen. There has to be something with the work that you did if it wasn’t like that prior - hopefully someone can help you troubleshoot and get you straight
    Tundyfundy and Cpl_Punishment like this.
  7. Dec 19, 2020 at 8:37 AM
    ChopperJ
    Jon
    2014 DC 4X4 SR5
    I think the lean was always there it was just hidden somewhat with the previous lift. Pretty sure the Toytec coilovers don't have a left or right, they weren't marked if they do. I don't think a shim in the front would work because I raised the left front with a jack and it didn't level out (read that was one way to check). Pretty sure the rear work is good, worked on twice- once when rear shocks were installed and second time when I replaced leaf springs.
  8. Dec 19, 2020 at 8:38 AM
    shawn474
    MoCo, Maryland
    Is the lean as pronounced in the front?
  9. Dec 19, 2020 at 8:40 AM
    ChopperJ
    Jon
    2014 DC 4X4 SR5
    No, less than 1/2 inch difference.
  10. Dec 19, 2020 at 9:09 AM
    Kanobi13
    Kanobi13 New Member
    Hmm same amount of leafs on both sides? Remove blocks on both sides?
  11. Dec 19, 2020 at 9:11 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    When you changed the leafs did you torque the shackles in the air or on the ground? Did you change the leaf spring bushings?
    Piki likes this.
  12. Dec 19, 2020 at 9:14 AM
    mb6355
    mb6355 New Member
    2006 Tundra DoubleCab
    Has it been in any accidents?
    Elduder likes this.
  13. Dec 19, 2020 at 9:34 AM
    Elduder
    Elduder New Member
    Take some pictures of your frame just behind the rear bumper, near where the leafs attach.
    I only have a poor photo of it but here’s a frame hop mine had after it’s accident. Unfortunately from the bottom it’s hard to tell, from the open side of the c framing you could see it bent up like an inch or two.
  14. Dec 19, 2020 at 9:43 AM
    ChopperJ
    Jon
    2014 DC 4X4 SR5
    Bushings were replaced and not sure about the torque, I had a shop replace them.
  15. Dec 19, 2020 at 9:44 AM
    ChopperJ
    Jon
    2014 DC 4X4 SR5
    When I bought it the Car Fax said no accidents, but you never know for sure. I haven't wrecked it.
  16. Dec 19, 2020 at 10:40 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Is your tailgate color really that far off or is it the light in the photo? Would be a good clue of a rear end collision.
    Terndrerrr and PhysicZ like this.
  17. Dec 19, 2020 at 12:12 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Good eye:thumbsup:
    Tundyfundy likes this.
  18. Dec 19, 2020 at 12:14 PM
    Tundyfundy
    Bay Area, CA
    Good eye
  19. Dec 19, 2020 at 12:14 PM
    Tundyfundy
    Bay Area, CA
    Beat me to it.
  20. Dec 19, 2020 at 12:32 PM
    Tundyfundy
    Bay Area, CA
    OP can you post some pictures of your suspension. Is you show where the leaf springs connect to the axle, where they connect to the bed, and where the shocks connect on to and bottom maybe we could give you some insight.
  21. Dec 19, 2020 at 5:35 PM
    ChopperJ
    Jon
    2014 DC 4X4 SR5
    No, it looks the same in person. I’ll try and get a few more pics of suspension.
  22. Dec 19, 2020 at 5:51 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    jack up the front of the truck on level ground, set each frame rail on a jack stand of equal height then examine the rear looking for the lean. If the truck ie the rear bumper is level then you have a problem with the LT front strut or coil over. If after the front of the rails are supported on the stands and you still have lean in the rear bumper then it’s in the rear leafs. It’s important to get the front tires off the ground and it the stands be level as possible.
    glowblue and ChopperJ[OP] like this.
  23. Dec 19, 2020 at 5:54 PM
    Omohundro
    Jody
    McMinnville TN
    Did you count the threads on the coil overs to make sure that they were the same on each side in the beginning?
  24. Dec 20, 2020 at 9:04 AM
    ChopperJ
    Jon
    2014 DC 4X4 SR5
    We might be getting somewhere. I put the front end on jack stands and it more or less leveled out the back (1/2 inch lower on right). I checked the front suspension and couldn't find anything out of the ordinary. I guess I'll call Toytec tomorrow.
  25. Dec 20, 2020 at 9:41 AM
    Omohundro
    Jody
    McMinnville TN
  26. Dec 20, 2020 at 9:49 AM
    Omohundro
    Jody
    McMinnville TN
    If yours are made like these, measure both sides from the coil to the bottom. See attachment red lines. If that measurement differs from side to side I’m willing to bet the perch locking rings are in different slots. I’m thinking there was a problem a while back with the springs themselves but I can not fully remember what spring it was 7D5A7D4A-8414-4A91-9833-D7F8ABBF776E.jpg
  27. Dec 20, 2020 at 10:27 AM
    ChopperJ
    Jon
    2014 DC 4X4 SR5
    I measured them and verified they were on the same perch, bottom one.
  28. Dec 20, 2020 at 11:17 AM
    Omohundro
    Jody
    McMinnville TN
    What about the springs, do they measure the same? I was really hopeful it was just simply the wrong perch.
  29. Dec 20, 2020 at 11:41 AM
    ChopperJ
    Jon
    2014 DC 4X4 SR5
    Right side spring measures 3/8 inch taller.
  30. Dec 20, 2020 at 11:43 AM
    Tundyfundy
    Bay Area, CA
    Any shots of the rear?
