Huge puff of blue smoke
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bentarm13, Apr 26, 2022.
  1. Apr 26, 2022 at 6:49 PM
    Bentarm13
    Bentarm13 [OP] New Member
    21 limited crew 4x4. Wife drove it 4 days ago for the first time. She sat in the school line for 20 minutes, total truck run time of 25 minutes, 3 miles driven. After she got home I had to run out, started and a huge puff of blue smoke came out of the exhaust. Never happened before, has never happened again. No warning lights, all gauges correct, truck is running absolutely fine. Thoughts?
  2. Apr 26, 2022 at 6:51 PM
    BIGUGLY
    Paul
    2018 Limited
    Had the same thing happen on our 2018 Tundra. Never happened again and no issues
  3. Apr 26, 2022 at 6:57 PM
    biebs96
    PA
    These trucks run heavy (meaning not so lean)
    Any time there is idle time in traffic, etc. this will happen.
    Don’t be alarmed. It’s been happening to me since 2010.
    NWPirate and Metro14536 like this.
  4. Apr 26, 2022 at 7:22 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Weird - blue smoke is oil yet why? Usually cats burn it off so its not even visible...this must be a whole lot. Check oil level?
  5. Apr 26, 2022 at 7:39 PM
    NWPirate
    Zach
    WA
    It's happened to me a couple times after I run it hard then shut the truck off pretty soon after.
    You're not alone, more of the same below.
    https://www.tundras.com/threads/5-7...-after-hard-acceleration.102307/#post-2624289
  6. Apr 27, 2022 at 4:09 AM
    Retired...finally
    My 21 did this just once that I knew of. Figured it was fogging for skeeters.
    NWPirate likes this.
  7. Apr 27, 2022 at 6:20 AM
    Wallygator
    Has more to do with these piston rings than anything else. Your truck should be on the severe duty maintenance schedule noted in the manual.
  8. Apr 27, 2022 at 6:25 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Have had it happen a few times on my 21 limited. I live with it.
  9. Apr 27, 2022 at 7:27 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    My 2020 has done it once. It was after a sort of hard drive and then sitting for two cold winter days. Once large puff of light blue smoke right with it fired up.
    As others have said it seems "normal". I figure it has to do with how the PCV system operates in certain circumstances. My guess is sometimes the oil builds up in intake and if you shut the truck down and let it sit, that oil collects and causes a puff of smoke. What specific operating conditions cause this is not entirely clear though. Running it hard, quickly parking, and let it sit seems to be one way to induce it. Another could be light load, lots of idle time.
