Hub centric rings for 2022+ Tundra
Discussion in 'Wheels & Tires' started by minh, Oct 8, 2022.
  1. Oct 8, 2022 at 12:59 PM
    minh
    minh [OP] New Member
  2. Oct 8, 2022 at 2:12 PM
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    Thanks. Ordered a set of 112 for my Rays.
  3. Oct 8, 2022 at 6:36 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Nice been looking for some 112 to 95 for my gramlights.
  4. Oct 9, 2022 at 1:39 PM
    2000army
    2000army New Member
    CT
    Ordered
  5. Oct 10, 2022 at 6:13 AM
    X42069
    X42069 New Member
    M
    Southwestern Ontario Canada
    23 SR5 CrewMax TRD Off Road 6.5ft box
    Forgive my ignorance.... What are these? Wheel spacers?
  6. Oct 10, 2022 at 6:27 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    It is a ring that goes between your hub and your wheel if your wheels are not made for the specific vehicle. i.e. if the wheel bore is larger than the size of the hub, then it fills that gap to make the wheel center perfectly on the hub.
  7. Oct 10, 2022 at 6:29 AM
    X42069
    X42069 New Member
    M
    Interesting. Thank you!
    Boerseun[QUOTED] likes this.
  8. Oct 18, 2022 at 10:11 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    These came in yesterday. Just waiting on wheels still.
  9. Nov 5, 2022 at 7:48 AM
    vinnychase
    vinnychase New Member
    2022 Tundra Platinum
    leveled
    Thanks, these were hard to find
  10. Nov 16, 2022 at 6:47 PM
    HooahMP12
    HooahMP12 New Member
    Justin
    2022 Tundra
    I just ordered method 305s and they spec at 108 hub size. Do they come with these rings or do they have to be purchased separately?
  11. Nov 16, 2022 at 8:30 PM
    minh
  12. Nov 16, 2022 at 11:59 PM
    mass-hole
    mass-hole New Member
    I thought the new wheels were not hub centric? Why would these be needed unless your wheels didn’t use conical nuts?
    SWB Tundra likes this.
  13. Nov 17, 2022 at 5:36 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Toyota wheels are hub centric and conical nuts to top it off. At least the previous gen is. I would venture to say that aftermarket wheels are not hubcentric to the new gen tundra. Also I feel alot better knowing I have hub and lug centric supporting my wheels.
    Soupbean77 likes this.
  14. Nov 17, 2022 at 5:48 AM
    mass-hole
    I know my GX and 4Runner wheels are not lug centric. The lug nuts are straight sided and all they do is clamp the wheel on. There is no cone to the nut or wheel. The 2nd gen Tundra nuts look the same to me.
    That said, I could see these helping with installation of the wheel by getting it lined up before installing the nuts.
  15. Nov 17, 2022 at 11:05 AM
    HooahMP12
    Justin
    2022 Tundra
    I was able to find 108 to 95.3mm. Is that close enough or does it have to be exactly 95.1?
  16. Sep 13, 2023 at 10:57 AM
    TitleFight88
    TitleFight88 New Member
    Really glad I found this! I just put some method 318's on my 22 tundra and had some wobble. Went back to the shop and they said I need some hub rings. Found that strange because method said the wheels are lug centric. Turns out the shop did not put the conical ET lugs on, but rather put on ball seat.
    The method support team was fantastic and helped me troubleshoot this very quickly. Even texted me pictures of what to show the shop.
    That being said, I am going to put on these rings and use the conical et lugs. Might as wall ensure there is no play at all!
    Boerseun likes this.
  17. Sep 19, 2023 at 4:11 PM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    You know...I've got to give credit to the OP (I can't tag people any longer...odd). I've never used hub rings before, even with aftermarket wheels. I've never really needed to since, even when the bore size was different, the conical lug nuts were enough. Because of that history, I had pretty much dismissed these.
    Since I put on wheels & tires about 15k miles ago, I've been chasing a vibration that I never could solve. I've had my Coopers road force balanced multiple times trying to solve it and that never fixed it. At my last rotate & balance, the tech told me that Coopers were "hard to balance", so I just dismissed the vibration. Fast forward to today and my mind has totally changed on these. They have solved my vibration issues. Best $30 that I've spent in a long time. haha
    Boerseun and minh[OP] like this.
  18. Sep 21, 2023 at 6:45 AM
    TundraRod5
    TundraRod5 New Member
    Rodney
    2023 Tundra TRD Sport Lunar Rock
    The Fuel Wheels I just bought have the rings in them. But if they are not right I will no doubt be getting these. The quality looks incredible.
  19. Sep 23, 2023 at 10:04 PM
    Shave Ice
    Shave Ice New Member
    j.robert
    2022 Tundra Sport
    I’ve been running these for awhile. Fit perfect and good quality.
  20. Oct 24, 2023 at 5:40 PM
    B5114
    B5114 New Member
    I have method 312s. Method states 106.25mm, did you confirm yours are 108? I’m looking for ring that fill the 106.25 to 95.1 void. The ones lost on Amazon are 106. I’m not sure if the .25 makes a difference
  21. Oct 24, 2023 at 8:12 PM
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    You want the 106mm ones. The .25mm is like .009 inches and negligible. The rest of us are using the 106mm to 95.1mm just fine.
  22. Nov 13, 2023 at 12:52 PM
    Keadog
    Keadog New Member
    This is interesting. I bought Method Racing wheels mounted with Blizzaks from Tire Rack. They can with red colored rings but they almost feel like plastic (?).
    I guess I'll put the calipers on them and see what the numbers are for these.
    Thanks for this info.
  23. Nov 13, 2023 at 2:55 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    I have 3D printed rings with my methods, it’s fine.
  24. Nov 13, 2023 at 3:41 PM
    KroppDuster
    Bilstein 5100s
    Definitely advantages to both. If I lived in the rust belt, I would definitely go with the PVC/poly plastic hub rings to avoid problem down the road. I've got my aluminum rings coated with anti-seize as a preventative measure.
    Yaboy[QUOTED] likes this.
  25. Nov 14, 2023 at 3:18 AM
    Keadog
    Keadog New Member
    Good to know. We live where it's cold and salt is used. Guess I'll stick with what Tire Rack sent. Thanks.
    Yaboy likes this.
  26. Nov 14, 2023 at 4:17 AM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Very good. They are either hub or stud. One or other.
  27. Apr 17, 2024 at 10:17 AM
    PhearCVBz
    PhearCVBz New Member
    2021 Black Tundra DC, 2024 Black Tundra CrewMax
    Hey there. In the off chance you see this (or anyone else that can help), do you have an drawings for the 3d prints for 106.1 to 95.1 ?
    Thanks!
  28. Apr 18, 2024 at 1:51 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Hey, I don’t have the print to make them but I’ve been meaning to reach out to the shop that sent them with my method wheels so I can print more myself for future use. When I do I’ll post it
  29. Apr 18, 2024 at 4:29 PM
    PhearCVBz
    Thanks! I’m likely going to create them, I just don’t have any in person to check on a couple things I’m not sure about. I will look closer at some of the pics.
  30. Apr 25, 2024 at 5:59 AM
    PhearCVBz
    So, I did 3d print some rings and I test fit them in the rims and they fit perfectly, however I received my Amazon order before the shop was able to get my truck back in so I likely won't need them. I'm attaching the STL file here for anyone that may need it in the future, and a photo of the 3d printed ring next to one of the production ones (Note: I had not done any finishing cleaning up of the burs and stuff since I'm not going to be using them). I put them side by side and they are the same dimensions inside and out.
    Yaboy and *D* like this.
