How?
Discussion in 'General Tundra Discussion' started by Lee, Dec 12, 2019.
  1. Dec 12, 2019 at 1:24 PM
    Lee
    Lee [OP] New Member
    Lee
    2006 Tundra
    How does a front differential just f shatter out of the blue!!? 2500 to fix
  2. Dec 12, 2019 at 1:47 PM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    New truck? Older model? Conditions it was used in?
  3. Dec 12, 2019 at 1:51 PM
    Low oil
    Kerch71, Tiamat and Sas like this.
  4. Dec 12, 2019 at 3:40 PM
    Lee
    Lee [OP] New Member
    Lee
    2006 Tundra
    2006 168000 miles
  5. Dec 12, 2019 at 3:45 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Wouldn't there be signs of that? Leaks, grinding noises, rough shifts? Trying to learn :monocle:
  6. Dec 12, 2019 at 3:52 PM
    Sometimes there is an indication (leaks, etc), but having low oil might not sound bad. Could be enough to keep quiet but still get really hot.
    TXMiamiFan likes this.
  7. Dec 13, 2019 at 7:24 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    If you did a lot off-roading or stressed it in other ways, with 168,000....
    Plus was did you ever change the oil in it?
  8. Dec 14, 2019 at 2:05 PM
    Lee
    Lee [OP] New Member
    Lee
    2006 Tundra
    Had just bought it. Showed no indication. Oil was fine. 3rd time engaged started clicking then banging. Then just gone.
  9. Dec 14, 2019 at 2:09 PM
    Sounds like there was a lot of abuse with the original owner.
    Black Wolf likes this.
  10. Dec 14, 2019 at 4:12 PM
    Lee
    Lee [OP] New Member
    Lee
    2006 Tundra
    Could this have been the cause of leaving it in 4wd accidentally? i.e. original owner drives it in 4wd home from work , takes off in morning for work in 4wd over dry pavement? Just trying to figure it out
  11. Dec 16, 2019 at 1:12 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Yes. All that stuff is bad for your diffs.
