How to verify 38 gal. fuel tank
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Oct 13, 2021.
  1. Oct 13, 2021 at 4:21 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    Lets says for argument sake that my truck is sitting in my driveway and a meteor hits it and destroys the tank....wait, sorry it has been a LOOOONG day at work.
    FlyingWolfe and MadMaxCanon like this.
  2. Jun 8, 2023 at 10:48 AM
    EML8E
    EML8E New Member
    Simple as this? Currently looking at a 18 DC SR5 with 40/20/40 seats. Can't figure out if it has the 26 or 38. Want to save myself the drive if it's the 26.
    MadMaxCanon[QUOTED] likes this.
  3. Jun 8, 2023 at 10:56 AM
    Do you have the VIN? It can be looked up that way.
  4. Jun 8, 2023 at 10:59 AM
    EML8E
    EML8E New Member
    I did that but says nothing about the tank.
    Just says the Grade is SR5 and it has the SY TRD Convenience Package.
  5. Jun 8, 2023 at 11:26 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Column shift and bench seat? small tank. It's that easy.
    EML8E[QUOTED] and MadMaxCanon like this.
  6. Jun 8, 2023 at 11:29 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Simple as that sir.
    EML8E[QUOTED] likes this.
  7. Jun 8, 2023 at 11:49 AM
    EML8E
    EML8E New Member
    Ran the vin and it comes up 40/20/40 but the pics are bucket with center shifter.
    Dealership said it's 38 gal also.
  8. Jun 8, 2023 at 12:27 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Buckets and center shifter = 38 gallon.
  9. Jun 8, 2023 at 2:00 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Sierradevil likes this.
  10. Jun 8, 2023 at 3:13 PM
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    Ground clearance. I scraped the crap out of mine, a bunch of times, the first time out.
    Not interested in costly, heavy skid plates that reduce capacity and ground clearance even more.
    If I keep my 2021 Tundy, I’ll be swapping the tank for a smaller one that does not hang below the frame.
    What were they thinking calling it a TRD off road, then installing a tank that hangs below the frame?
    AgileTundra likes this.
  11. Jun 8, 2023 at 4:05 PM
    AZBoatHauler
    So.Arizona
    I’ve smashed my diff way more and harder than my 38g tank skid. Pretty sure @Cruzer wheels the fuck out of his with the stock tank.
  12. Jun 8, 2023 at 4:34 PM
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    I’m sitting bone stock, so that may be part of the issue. A lift and tires may help.
    But I’m pretty sure I would rather wheel a truck that can do most everything I do, bone stock. Then the mods go a lot further.
    This truck is just too long, low and heavy for what I do.
    Love the Tundy, but I might run back for another Taco. I may even take a chance on the new turbo 4 banger that comes with 33’s stock.
    The truck is a 2nd vehicle that sees dirt almost every time it’s used.
    Sorry for going way off topic, but the info may help if the OP wants the truck for mainly dirt. I wish I had the small tank.
  13. Jun 8, 2023 at 4:55 PM
    MadMaxCanon
    Does the 38 gallon tank sit lower? I thought it was just longer.
    Where are you located because I'll swap you tanks lol
  14. Jun 8, 2023 at 4:57 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    exactly. I believe you’re correct
  15. Jun 8, 2023 at 4:58 PM
    MadMaxCanon
    Aftermarket options like the 46 gallon tank 100% hang lower though, by alot if I recall.
  16. Jun 8, 2023 at 6:05 PM
    DenaliLess
    DenaliLess New Member
    rob
    2019 CrewMax 4X4
    46 gallon transfer flow tank
    Dont let it slip away just cause of the tank. I love my aftermarket tank and the bench seat
    MadMaxCanon likes this.
  17. Jun 8, 2023 at 6:07 PM
    MadMaxCanon
    6th seat and column shifter is the only way to go
    DenaliLess[QUOTED] likes this.
  18. Jun 8, 2023 at 7:12 PM
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    You misspelled Tacoma.
  19. Jun 8, 2023 at 9:48 PM
    #49
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    Understood.
    24 years in my 97 taught me the Taco will do anything I want it to do. And a lot more. Never broke anything and never proved to be fragile. Plenty of power, at least for my uses. It looked and ran like new when I sold it.
    Light, agile and climbed like a mountain goat.
    I go alone and rock crawling is not on the menu. Making it home is and I trust a Yota before any Jeep product.
    I’m sure the Jeep is nice.
    But for the OP, get the truck if it’s a good deal. The tank can be changed.
  20. Jun 9, 2023 at 9:14 AM
    #50
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    This is my biggest complaint with my 2016 Tundra. Can’t have the bigger tank and SR5 upgrade package stuff with a bench seat, and it looks like swapping to a bench is a fairly huge endeavor. I bought it anyway but it still bugs me.
    Johnmatrix likes this.
  21. Jun 9, 2023 at 10:00 AM
    #51
    EddieBolt
    EddieBolt New Member
    David
    2020 CM SR5 4x4
    Verify by getting a full gas tank and see if you got that tundra lean.
  22. Jun 9, 2023 at 11:09 AM
    #52
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    97 Taco is a gen 1. Mine was a 5 speed manual.
    I think is has a minivan engine from the Siena. Worked great. Sold it in 2021 when I got the Tundy.
    Good man, helping your son. We need more like you.
    For the OP. have the seller send you a photo of the tank.
  23. Jun 9, 2023 at 12:36 PM
    #53
    MadMaxCanon
    Ya the shifter is what ruins it.
  24. Jun 9, 2023 at 6:43 PM
    #54
    mgrs
    mgrs New Member
    '20 OR
    Have gotten over 600 several times on the 38 gallon tank filling up when the light comes on.
  25. Jun 9, 2023 at 7:36 PM
    #55
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    (As previously stated) For 2021 in the SR5 trim Doublecab/Crewmax the bigger tank is tied to removing the column shifter and bench seat. From the brochure:
    SR5 Upgrade Package — adds larger fuel tank; replaces
    front bench seating with front bucket seats with power driver’s seat with power lumbar support; adds front center console with floor-mounted urethane shift lever and knob, tilt/telescopic urethane steering wheel, three front cup holders, and an anti-theft system with alarm and engine immobilizer
