How to turn a 5 min job into a 3 hour job ...
Discussion in 'Lighting' started by rockjockey, Oct 29, 2016.
  1. Aug 28, 2021 at 7:35 PM
    #91
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    man, was replacing my map and dome lights a PITA. I thankfully didnt mess too much up and blow any fuses. I did happen to screw up the metal reflector on both front one lights and also mess up the white button stitch the cover pushes.. Thank goodness that's all over without bigger issues. I wish luck to everyone, haha.
  2. Aug 28, 2021 at 8:07 PM
    #92
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    What did you end up going with over the GTR LEDs?
  3. Aug 28, 2021 at 8:11 PM
    #93
    Blang805
    Blang805 New Member
    Build in Signature
    So headlight revolution sent me the wrong LED door kit. So I emailed asking if they sent the right bulbs vs the ones in their video. I was right so they sent me the correct bulbs and had 4 extra “map and dome lights” vs the 6 way lights that are meant for the door.
    edit: so now I have all their map, dome, door and exterior mirror LEDs and it’s awesome.
  4. Aug 28, 2021 at 8:20 PM
    #94
    Shanet421
    San Diego,CA
    Ah I see. My truck is just the base model so I’m missing most of those lights. I am happy to have found your post since I only need to replace map and dome lights.
    Edit: Just need one of those T5/74 single diode LEDs for the footwell light to complete the interior.
    Blang805[QUOTED] likes this.
  5. Jan 20, 2025 at 1:44 PM
    #95
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Anyone have this happen……
    had a led swap on our 21 Seqouia- no problems. One led started flickering so replaced it and boom- everything blown. Replaced fuse, didn't work. Pulled overhead console and nothing seems wrong with it, tried bending tabs and reinstalling- still zero lights coming on throughout the whole car.
  6. Feb 4, 2025 at 8:26 AM
    #96
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Can you use a meter, verify if there is voltage at the lights. Odds are you took out more than just a fuse, there are multiple fuse boxes as well as relays etc... under the hood. Flickering could be an indication of a ground problem, if your sure you've installed the light correctly, I would remove the light to see if you regain the rest of the lights, if that doesn't work you'll need a electrical diagram of your vehicle to see if there's something else that could of failed and affected the circuit.
