How to turn a 5 min job into a 3 hour job ...
Discussion in 'Lighting' started by rockjockey, Oct 29, 2016.
  1. Mar 6, 2019 at 8:59 AM
    #61
    BradWils
    BradWils New Member
    7” Procomp lift Procomp MX2.75 Coilovers SPC UCA’s Plus 3” Rear Shackle 35x12.50 R20 Duratracs Pro Com 20x9 0 offset rims Bora 1.5” wheel spacers OEM LED Headlight and Fog conversion LED interior lights TRD Pro Grill Borla Touring true dual exhaust AFE Magnum Force Stage 2 SI Pro Intake Bushwacker Fender Flairs Colour match door pulls, mirror caps and hood buldge Weather Techs Remote Start Factory Match Tint Toyota Bakflip Tonneau cover Line-X
    This post is the best... I broke my metal reflector too but I was able to get it up and in place. Now if I can figure out where my dash is creaking in the cold I’ll be back to 100%. Thanks for the great write up and pics
  2. May 11, 2019 at 2:59 PM
    #62
    Cthulhu
    I know you wrote this up a long time ago, but it helped me fix my map light today, so THANK YOU very much @rockjockey !!
    NewImprovedRon and JMB like this.
  3. May 11, 2019 at 9:31 PM
    #63
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    I think this has happened to everyone who’s replaced those bulbs, it happened to me too:annoyed:
    Tom Sleight likes this.
  4. May 12, 2019 at 8:48 PM
    #64
    rockjockey
    rockjockey [OP] Per ardua ad astra!
    Spring, TX
    2016 White Tundra TSS
    Glad it helped! Just trying to pay back all the invaluable help & tips I’ve received from this forum.
    NewImprovedRon likes this.
  5. May 14, 2019 at 12:48 PM
    #65
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    Similar thing happened to me when I went to install my last Pioneer Double Din. I'd been upgrading to newer versions of the same brand every couple years to get new features. It had always basically been a plug and play affair with the last 2 or 3, just un-plug HU from old Pioneer harness for the last unit and plug new one in. Took about 10 minutes each time. But some time before this last one, the AVH 501EX, I realized they had change the wiring harness. Nothing significant that I remember, just tweaked the shape and put the clip on the opposite side so the plug on the radio wouldn't marry up with the harness in the truck anymore. Had to run to Best Buy and get a new one once the dash was apart and I realized it.
    No biggie, I figured. Can't be hard to cut and splice a new harness in. Well, the first double din installer did from years ago and other work that had been done in the dash to connect things to the radio after that left a few different wires configured in a way that I didn't quite understand and had trouble tracing. I didn't realize it wasn't looking like the diagram until I dug into it a little bit. I tried to match everything up exactly as before but couldn't get sound after a few days. Had to go swallow my pride and go into Best Buy to get them to clean up the wiring under my free install. Was done in an hour. When I picked the truck up they had cut out a few things that apparently were determined to serve no useful function in there and everything has been perfect ever since.
    What was normally a 20 minute job had me fumbling around under the truck in my spare time for a couple days before giving up and taking it in. If I had started from stock it probably would have been easier but the extra stuff under there threw me off.
    aperezsh and JMB like this.
  6. May 14, 2019 at 1:08 PM
    #66
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    Just wrap some tape around the bulbs and yank them out.
    jmdaniel and sundance like this.
  7. May 30, 2019 at 8:22 AM
    #67
    Mcb ZX225
    Mcb ZX225 New Member
    Mark
    2019 TRD Limited
    So this just happened to my on my 19. I just found this thread and my freak out factor is somewhat toned down. Won't have a chance to tackle it for a few days but after reading this I do feel a little better. If it gets bad and still can't figure it out I might want to reach out to a local DFW metroplex forum member that has done this to assist?! Thanks
  8. May 30, 2019 at 8:26 AM
    #68
    Cthulhu
    I promise you, I'm decently proficient with tinkering but not an expert by any means, and it only took me about 30 minutes to pull down the map light housing, fix the backside connections, and put it back.
  9. May 30, 2019 at 11:19 PM
    #69
    shhernandez74
    Samuel
    Really simple, I’m in Dallas in case you need any help!
  10. May 31, 2019 at 4:01 AM
    #70
    sundance
    sundance New Member
  11. Jun 18, 2019 at 8:21 AM
    #71
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I call that Saturday morning.
    Then when the grass dries out I can mow it.
    That is after I try and fill the mower with gas that I dont have, run to the station to fill up the can..... Saturday afternoon
  12. Aug 23, 2019 at 4:35 AM
    #72
    Chevyjlewis
    Chevyjlewis New Member
    Missouri
    2019 Barcelona Red Tundra sr5 trd offroad
    This happened to me last night. I pushed the connector up into the console. I will be taking it off this weekend to fix it. It made me sick to think i just screwed up my brand new 45k dollar truck to have a brighter light bulb that costs pennies
    Tom Sleight and NewImprovedRon like this.
  13. Aug 23, 2019 at 5:01 AM
    #73
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I remember reading this when the OP posted it a couple years back, and I'm pretty sure I laughed just as hard just now as I did the first time I read it. :rofl:
    aperezsh likes this.
  14. Aug 23, 2019 at 8:40 PM
    #74
    Chevyjlewis
    Missouri
    Now i think i fixed it. But i also think i blew the fuse. So now i get to mess with that. Just to see if the lights work. If that doeant work. I guess back to the dealer
  15. Nov 17, 2019 at 1:11 PM
    #75
    TundraNationalist
    TundraNationalist New Member
    2008 BASED CrewMax 4.7L
    The LED upgrade got me too. I managed to blow the fuse on the first light I tried to change, the drivers side door. I'll start with the easy bulb, I said. The youtube videos made it look so simple.
    Well after blowing the fuse (probably my fault) I had to get a $5 assorted pack of fuses at the local store to get one replacement 7.5a. I put the original bulb back (which still worked thankfully) and installed the new fuse - everything came back on like it was before.
    Now after reading all the stories about messing up sockets for the dome and map lights, I am thinking I will probably stick with the originals until one burns out. The LED light kit I ordered was $20 on Amazon. Might just return for a refund and cut my losses.
    Pinay likes this.
  16. Nov 20, 2019 at 8:26 AM
    #76
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Give it another go and pull the fuse this time. Now that you've messed up once you know what to do, don't quit so easily!
  17. Nov 20, 2019 at 3:05 PM
    #77
    TundraNationalist
    This has crossed my mind many times. I haven’t returned the LEDs yet. My fear is I am going to mess up one of the sockets in the overhead lights, like some reported in this thread. I know I’ll be kicking myself if that happens.
  18. Nov 20, 2019 at 3:53 PM
    #78
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    It's really not that difficult to pull the plastic unit out if you do push one of the socket in. Like 4 bolts I think.
  19. Jun 1, 2020 at 10:55 AM
    #79
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    jrquist likes this.
  20. Jun 1, 2020 at 12:00 PM
    #80
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    It's funny.....only if happened to someone else...lol. I rarely use those lights, so I leave them alone and not to go through what OP went through..lol
  21. Jun 1, 2020 at 12:26 PM
    #81
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Rothflmao, i got tears coming out of my eyes and my side ache from laughing while reading.
  22. Jun 1, 2020 at 2:56 PM
    #82
    CaptainGrumpus
    Maine
    Thank god their not cheap or Id probably have some light bulbs rolling around in between my headliner and roof
  23. Oct 2, 2020 at 6:13 AM
    #83
    MNTX TRDPro
    MNTX TRDPro New Member
    '17 White TRP Pro
    Rolling Tonneau
    Great post for a morning read! LMAO with my coffee!
    Question, the LEDs appear significantly brighter/whiter cooler color temp, are they so much so to be distraction if the passenger used theirs while driving?
  24. Oct 31, 2020 at 10:04 AM
    #84
    TMF
    TMF New Member
    Dave
    2019 tundra
    Thank you for this post. It saved me a ton of time and a trip to the dealership.
    You are the real MVP!
  25. Apr 16, 2021 at 5:05 PM
    #85
    ToyYota
    ToyYota New Member
    #85
  26. Jun 20, 2021 at 6:31 PM
    #86
    SHAKA U F4KA
    SHAKA U F4KA New Member
    HONOLULU
    Thank you for this. Still saving someone’s ass in 2021 lol
  27. Jul 5, 2021 at 1:57 PM
    #87
    Jlmonti
    Jlmonti New Member
    I just joined this club while installing Headlight Revolution LED replacements. Up went the socket as I inserted the bulb. Blew the 7.5A fuse as well. I had a few choice words. This thread was a super big help. Removed the console, pushed the socket back onto the posts and used a little epoxy to hold down the runs and form a new weld head. Updated all my interior light to LEDs after fixing the map light side show. Thanks again for taking the time to post the fix.
  28. Jul 22, 2021 at 11:41 AM
    #88
    J. Urrrk
    J. Urrrk New Member
    Erik
    WA
    2012 dark gray Tundra Platinum
    Okay, count me in as another victim of map light led replacement syndrome, along with the trip to three separate stores to find the elusive 7.5 amp lo profile replacement fuse.
    This is a very useful thread, wish I'd read it first.
  29. Jul 24, 2021 at 6:51 PM
    #89
    Tom Sleight
    Tom Sleight New Member
    2018 Tundra
    Hello, My name is Tom and I made the same mistake that some of you have. I wish I found this support group before. I Am an Electrician and should know better but I blew the fuse installing the map lights also.
    I was looking for the fuse under the hood and pulled the first 7.5 amp fuse I found. ((While the motor was running)Again, I should know better)This made my motor very unhappy and the engine started surging and a organized group of warning lights came on the display.
    I sat down my beer and figured I should stop for the night before I burn this thing to the ground.
    this morning I found the fuse box under the dash and replaced the 10 amp fuse that was blown then hooked up my code reader and cleared all of the faults that I had caused.
    Thanks for your help and good luck.
    TILLY likes this.
  30. Aug 28, 2021 at 6:41 PM
    #90
    Njbuffington
    Njbuffington New Member
    Nathen
    2021 Tundra limited CM 4x4
    None
    This is wild! I have the same issue. I removed the console, pushed the tabs back down flattened out the plastic weld. Now the bulb does fit snug with everything reinstalled almost perfectly. The problem I’m having is that when turning the switch on/off I get only flicker and the other lights are sometimes affected. Does anything think this is related to the switch button being fried?
