How to: Throttle Body Coolant Bypass with Ball Valve
Discussion in 'Performance and Tuning' started by JeffMac, Feb 10, 2021.
  1. Feb 10, 2021 at 2:17 PM
    JeffMac
    JeffMac [OP] 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    Throttle Body Coolant Bypass with Ball Valve Mod
    3 Way Ball Valves
    The ones I purchased below came with all the clamps I needed.
    Joywayus 5/16" ID Hose Barb, Y shaped Type 3 way Union Intersection/Split Brass Shut off Ball Valve Fitting https://smile.amazon.com/dp/B07HRKN...abc_925CF7Z939DHY30MG2FZ?_encoding=UTF8&psc=1
    You will also need about 4 inches of 5/16 tubing for the bypass for non winter months.
    Start off by taking off your intake tube and unbolting your Throttle Body. Unplug the electrical harness and be careful not to lose the rubber seal inside.
    From here you can disconnect the 2 radiator hoses going to the TB.
    Determine where you want to place your 3 way Ball valves and cut the tube and in goes the valve. I decided to use 2 valves to be able to prevent fluid from seeping back up because eventually the fluid will all equalize thus warming up your TB.
    Attached are pictures of what I did. Be cautious of how close your bypass hose is to the radiator fan and don’t mess with it while the truck is on and fan is spinning.
    BE9D8939-8A23-4472-A4B4-2F2EA39ACAB9.jpg 11223AE1-15F6-4535-8ED5-6782D30A9416.jpg
    farnsrocket, Bob, MTRock and 4 others like this.
  2. Feb 10, 2021 at 5:35 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Badass! Thank you!!
    JeffMac[QUOTED][OP] likes this.
  3. Feb 10, 2021 at 5:44 PM
    Not surprised a Jarhead did this right! Black Tunny too! Semper Fi:thumbsup:
  4. Feb 11, 2021 at 12:15 AM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Where did you get the caps to close off the pipes?
  5. Feb 11, 2021 at 3:26 PM
    JeffMac
    Jeff
    South Florida
    After this I snacked on some crayons too lol. Semper!
  6. Feb 11, 2021 at 4:41 PM
    Uhhhh.... and TundraTRD08 like this.
  7. Feb 15, 2021 at 11:11 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    What Benifit does this serve?
  8. Feb 15, 2021 at 11:14 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  9. Feb 15, 2021 at 11:40 AM
    Tundyfundy
    Bay Area, CA
  10. Feb 27, 2021 at 2:09 PM
    mass-hole
    mass-hole New Member
    Why couldnt you just splice a single valve into one line and just turn the flow on or off? Is there something critical that the coolant goes through before or after the TB?
    Tundyfundy likes this.
  11. Mar 25, 2021 at 10:06 AM
    mass-hole
    I did a little reading and it sounds like, in a lot of cases, the heated TB's are to prevent freezing. I would guess its pretty rare, but if water pooled in the TB for some reason and froze, the plate could get stuck, which is probably why the coolant only passes through the bottom of the TB housing where the water would pool.
