How to stop brakes from squeaking?
Discussion in '2.5 Gen Tundras (2014-2021)' started by greg8765, Feb 27, 2021.
  1. Feb 27, 2021 at 9:13 AM
    greg8765
    greg8765 [OP] New Member
    Greg
    Utah
    2021 Cement Tundra
    Done a fair amount of searching on the forum for a fix. I have a 21 with less than 2k miles on it and my brakes squeak so bad. I've cleaned them out really good and it stops it for a few hours, but goes back to squeaking very fast.
    Anyone else have this problem? Any fixes without going back to the dealership?
    Metro14536 likes this.
  2. Feb 27, 2021 at 1:44 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    You just got the truck, take it back to the dealer. Guessing the pins did not get lubricated when they truck was built.
  3. Feb 27, 2021 at 1:45 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    What do you mean, you cleaned them out? You’re not physically spraying or putting anything on the pad material themselves huh?
    BravoDeltaRomeo likes this.
  4. Feb 27, 2021 at 6:20 PM
    greg8765
    Greg
    Utah
    2021 Cement Tundra
    spray them out really good when washing the truck to make sure they are free of dirt and brake dust
  5. Feb 28, 2021 at 9:45 AM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    I'd say either one of your pads is missing a shim from the factory (not sure how that would happen) or the pins are dry. Every brake squeal problem I've run into has been missing or crappy shims. Regardless take it back to the dealer. It's under warranty
    Rocko9999 likes this.
  6. Apr 26, 2021 at 2:43 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Did you ever get this resolved? My 2020 does the same thing, when first backing out of the garage. Looks bad to the neighbors.
    Metro14536 and Rocko9999 like this.
  7. Apr 26, 2021 at 2:47 PM
    Corrosivetendency
    Corrosivetendency New Member
    Nate
    2016 plain-jane d-cab
    My 2016 with 80k miles does it after sitting for the night. Within one or two stops it quits. I also make sure to spray the calipers out well when I wash, seems to help?
  8. Apr 26, 2021 at 2:51 PM
    AggiePhil
    College Station, TX
    Not good! Like I said, looks bad to the neighbors when the brand new Tundra sounds like a hooptie backing out of the driveway!
  9. Apr 27, 2021 at 10:48 AM
    JMB711
    JMB711 New Member
    2020 Trunda SR5 Crewmax TDR offroad
    Running boards. Shaved vehicle emblems. TruXcedo low profile tonneau cover. LED interior lights along with cargo bay and reverse lights.
    Ha! Mine does the same...But only just that one time.
  10. Apr 27, 2021 at 11:17 AM
    Rocko9999
    Rocko9999 New Member
    My 2014 with 158K does this too when backing out. So annoying. Only happens once.
    AggiePhil likes this.
  11. Apr 27, 2021 at 11:45 AM
    Merkopac661
    Merkopac661 New Member
    White 2018 Tundra Sport 4x4
    Mine too,only backing up first time then it stops 2018 4x4 16,000 miles
  12. Apr 27, 2021 at 1:01 PM
    Rocko9999
    Strange. I wonder what causes this.
  13. Apr 27, 2021 at 1:03 PM
    greg8765
    Greg
    Utah
    2021 Cement Tundra
    haven't resolved it. look like a tool in front of the neighbors for sure. $50k+ truck, 3,000 miles and it sounds stupid.
    AggiePhil[QUOTED] and Rocko9999 like this.
  14. Apr 27, 2021 at 1:05 PM
    Rocko9999
    I know the feeling. I often leave early 3-4am and the sound just travels all over the neighborhood. A real crappy feeling.
  15. Apr 27, 2021 at 1:12 PM
    greg8765
    Greg
    Utah
    2021 Cement Tundra
    Has anyone had this problem, upgraded brakes, and rotors and it has stopped? Are they just shit parts that come stock?
  16. Apr 27, 2021 at 1:14 PM
    frichco228
    no they are not crap parts. I would not replace brakes on a brand new truck because they make noise. Dealer will take care of it under warranty. It really is that simple.
  17. Apr 27, 2021 at 1:16 PM
    greg8765
    Greg
    Utah
    2021 Cement Tundra
    I've had it in twice. They've deglazed the pads and lubed moving parts. No change.
  18. Apr 27, 2021 at 1:17 PM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    Have a 2020 with about 9k miles, never heard one squeak from the brakes. Should be something the dealer can fix on a new truck.
  19. Apr 27, 2021 at 1:43 PM
    Rocko9999
    Well what's the solution?
  20. Apr 27, 2021 at 1:48 PM
    frichco228
    2-3k miles on the brand new truck- the solution is to have the dealer fix it
  21. Apr 27, 2021 at 1:51 PM
    Rocko9999
    Multiple people say they can't.
  22. Apr 27, 2021 at 2:00 PM
    15whtrd
    15whtrd Mr. Blonde
  23. Apr 27, 2021 at 2:07 PM
    frichco228
    OP said dealer deglazed pad and greased pins- issue still there
    Brand new truck under warranty- dealer needs to fix it. If they need to replace the calipers, rotors and pads to fix it, then they will need to do what it takes.
    The truck has a warranty for this kind of issue. NO ONE should feel like they have to replace parts to chase issues on a brand new 50K truck, well unless maybe they purchased a Ram. :boink:
    The only thing I may suggest that OP can do yourself is bed in the brakes. Noise can come from uneven material transfer from pad to rotor. Bedding in the brakes will burn that off and if done correctly could stop the noise. But again, OP should not have to deal with any of that on a new truck.
  24. Apr 27, 2021 at 2:21 PM
    greg8765
    Greg
    Utah
    2021 Cement Tundra
    how hard do you push to get those things replaced? i don't want to be an ass, but it's a brand new truck
  25. Apr 27, 2021 at 7:36 PM
    AggiePhil
    College Station, TX
    Not worth taking it in, dealing with the service people, being w/o the truck, etc. Guess I’ll just live with it. Like everyone has said, it goes away as soon as you leave the driveway.
  26. Apr 28, 2021 at 10:57 AM
    Merkopac661
    Yeah I don’t trip too much. The noise sucks for 5 seconds a day but my truck is badass and definitely better than any of my neighbors trucks.
  27. Apr 28, 2021 at 10:59 AM
    Rocko9999
    Does anyone with aftermarket pads and or rotors have similar issues?
  28. Apr 28, 2021 at 12:17 PM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    I just replaced pads and rotors on my fiancee's mazda 3 in 2019, and now there's a constant grinding/rubbing sound persisting no matter how much I grease the slide pins, or anti-seize on the pad guides, etc. Took it to the mechanic and they stated that if the car's been sitting a lot outside (which it has) then the pitting on the rotors could be to blame. It's basically unavoidable if it sits a lot, and you would need new rotors to fix it; which is only a temporary fix!
    That being said, there's a video about the Tundra platform circling this forum citing that if you're in the rust belt, you should lube the front caliper guide pins every year. Makes me wonder if the dealer actually did that for the OP or not.
