HOW TO: Retrofit Install Guide (by EleDobleU)
Discussion in 'Lighting' started by eledobleu, Dec 9, 2016.
  1. Feb 20, 2017 at 10:27 AM
    #151
    Tundra4us
    Tundra4us New Member
    "D"
    I am also doing the eledobleu retros, my question is if I want only my DLR's to have the switch back function do I need to do the DRL delete mod? I have a Platinum edition and the DRL is "clear"lower strip and NOT the amber turn signal. From reading over all of these post it appears that the retros come set up to splice any configuration that you want, is this true? Or do you still need to tell eledobleu what configuration you would like to have light/blink?
    LKSR5-14 likes this.
  2. Feb 20, 2017 at 11:16 AM
    #152
    LKSR5-14
    LKSR5-14 New Member
    Chicago Northwest suburbs, Illinois
    2016 Tundra SR5 DC
    Tundra SR5 DC 2016 Upgrade: pro wheels, headlights retrofit, head unit Kenwood 694s, bed cover, lineX, Viper security and starter system, pro grille, tinted windows, LED lighting, black wrap on all end chrome corners, ceramic coating
    I would suggest to talk with eledobleu
    Send from gym Galaxy 7E
  3. Feb 26, 2017 at 10:30 AM
    #153
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    Your stock DRL's dont have the switchback capability. But if you have halos, panamera drl shrouds etc that have the switchback function, you do not need to do the amber delete mod as your DRL configuration is different than the other trims.
  4. Mar 26, 2017 at 10:22 AM
    #154
    HUTCHJ
    HUTCHJ I can ride my bike with no handlebars
    J
    Where did you ground it to? I'm putting mine at the moment and am stuck
  5. Mar 29, 2017 at 4:49 AM
    #155
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    Did my install last night. Pretty straight forward. Need to go back and tighten up the wiring. But WOW. This may be the best mod I've done on any car. My wife wouldn't drive the truck at night, and I hated to. We've been spoiled with her mdx and everything else we've owned for the last few years has had hid's. This is amazing.
    HUTCHJ and SouthBoundSteve like this.
  6. Mar 29, 2017 at 6:23 AM
    #156
    HUTCHJ
    J
    Awesome! I know just how you feel. Now my fiancee wants me to get her cx5 done (she has everything but the high-end tech package) lol.
  7. Mar 29, 2017 at 9:31 AM
    #157
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    btw, should I adjust the beam pattern at all?
  8. Mar 29, 2017 at 10:34 AM
    #158
    RollMGM
    RollMGM New Member
    Either left side move up lil bit or right side come down. What projector is it?
  9. Mar 29, 2017 at 10:39 AM
    #159
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    mini d2s 4.0
  10. Mar 29, 2017 at 10:43 AM
    #160
    eledobleu
    Orlando, FL
    Your took close to the wall to tell. Back up minimum 25ft. Then make adjustments from there.
    MakMurph likes this.
  11. Mar 29, 2017 at 10:51 AM
    #161
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    I'm a good 1.5 truck lengths away. But ultimately i looks like they are slightly off and I need to line them up together a bit more?
  12. Mar 29, 2017 at 11:40 AM
    #162
    RollMGM
    RollMGM New Member
    You can do it bro it not that hard as you think.
    HUTCHJ[QUOTED] likes this.
  13. Mar 29, 2017 at 12:51 PM
    #163
    eledobleu
    Orlando, FL
    Just make sure you align them with enough distance. You need more than 1.5 trucks length to properly align them. The further you are the closer the cutoff's will get together. So you want to make those adjustments like I said minimum 25ft. Ideally you want to be about 50-100Ft away from a wall.
    HBdirtbag[QUOTED] and MakMurph like this.
  14. Mar 29, 2017 at 1:42 PM
    #164
    HUTCHJ
    J
    At 50' how high up the way should the cutoff be?
    BillE likes this.
  15. Mar 29, 2017 at 1:54 PM
    #165
    BillE
    BillE New Member
    Billy
    2017 White Tundra Platinum
    None so far
    I have the same question.
  16. Mar 29, 2017 at 2:16 PM
    #166
    eledobleu
    Orlando, FL
    On a flat road, you should barely see the cutoff on the road. Rule of thumb is, if you can see the cutoff on the road very clearly and sharp, its too low! If its pointing straight and wont touch the road at at least 100ft, its too high!
    You want distance but without blinding oncoming traffic. I aim most headlights pretty spot on where it needs to be. This obviously varies depending on stock height levels or lifted.
    I cant get a picture here in GA as there are too many hills. Soon as I find some flat ground I will post a night shot of the distance of the beam. This goes for all projectors.
    Tundra_Dawg, iHacker and HBdirtbag like this.
  17. Mar 29, 2017 at 2:21 PM
    #167
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    You the man!!! Very impressed!
  18. Mar 29, 2017 at 2:54 PM
    #168
    BillE
    BillE New Member
    Billy
    None so far
    Ya thanks Leo, if the truck is lifted does the same rule apply or do you want to go a little higher as to not blind people?
  19. Mar 29, 2017 at 4:44 PM
    #169
    eledobleu
    Orlando, FL
    Depending on how much lift you have. 1-4 inches same rules apply. Higher than 5 inches and you want to lower the lights as it will be too high! You will loose distance with high lifts.
  20. Apr 5, 2017 at 5:35 PM
    #170
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Is there a way to shut off the regular blinker? It's way out of sync with the led strip. I figured doing the drl delete would do this.
    Question. If I want the strip orange most the time is that possible?
  21. Apr 5, 2017 at 5:38 PM
    #171
    eledobleu
    Orlando, FL
    There is currently no way to turn off stock blinker. How out of sync is your LED strip with your stock blinkers?
    Only way to have the LED's amber all the time is to re-connect the DRL wire.
  22. Apr 5, 2017 at 7:26 PM
    #172
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    It's not that bad. But it's out of sync. Drives me bonkers when I notice it
    Can the blinker bulb be removed and not show any errors?
  23. Apr 5, 2017 at 8:26 PM
    #173
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Interesting. I'm doing my install tomorrow and maybe I won't do the blinker switch back if its way out. I already did the DRL delete today. What you think.
    HBdirtbag[QUOTED] likes this.
  24. Apr 7, 2017 at 9:33 PM
    #174
    jmcolejr
    jmcolejr New Member
    James
    BRONZE 2015 TUNDRA 1794
    Will this DRL Mod work on a 1794 model? I'm about to do retrofit with Mini D2S w/3.0 shroud. The high beam wires brown/white, which one is neg or positive? thanks
  25. Apr 8, 2017 at 3:42 AM
    #175
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Curious what our led strip options are. If I want it orange all the time, is that possible? If I want it orange only when headlights are off is that possible (I'm thinking this may be how they work now, as I feel I saw it like this as my wife was driving one day).
  26. Apr 10, 2017 at 6:34 AM
    #176
    Stig
    Stig New Member
    Have a question about the daytime running lights...
    I noticed last night that my DRL is on when my headlights are on. I tried putting it in drive and releasing the parking brake.
    I had already cut the gray wire and that worked to keep the DRL coming on with the headlights off.
    I have vled switchbacks.
    Are the DRL normally on when the headlights are on? And is that a separate switch than what tells them to turn on as a DRL?
  27. Apr 10, 2017 at 8:12 AM
    #177
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Parking lights, mine do the same I know the 1794 and Platinum models don't do it just work as blinker, by the way I like to have them ON with the parking lights, there's is a way if you want to disable it but is another wire you will have to cut or disconnect I think is the purple wire in the center, I hear a guy that just broke the center pin in the bulb to not damage any factory wire, I can suggest to try insulating the center bulb pin using liquid tape or plastidip doing this steps should work as blinker only
  28. Apr 11, 2017 at 6:47 PM
    #178
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
  29. Apr 11, 2017 at 7:35 PM
    #179
    Y0TA PR0
    Rafael
    2017 TRD PRO
    That doesn't look to bad.
    Almost looks like they are blinking at same time no?
  30. Apr 12, 2017 at 7:08 AM
    #180
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    You'll see the led is faster so they will catch up with each other. It's not bad. Just drives me bonkers.
    TRD15559 and Y0TA PR0 like this.
